5th Gen Wheel & Tire Thread
I had 1.25" spacers on my 17x8.5 -10s and the fitment of 17x8.5 -10 with 1.25" spacers is almost the same as 17x9 -38 so I didn't need to do a whole lot. If I didn't upsize to a 295 M/T tire and stayed with my 285 KO2s, I probably couldve gotten away with no additional cutting or trimming at all.
17x9 -38 and 295 M/Ts aren't that hard to fit as long as you have aftermarket UCAs and a good amount of caster.
What I've done so far:
- Lots of front bumper trimming and fender liner relocation
- Very aggressive BMC
- Trimmed black fender end cap and bent the metal tab behind it
What I still need to do:
- Upgrade bump stops: Found out after my last trip my tire is hitting the top of my fender at full articulation
- Upgrade to aftermarket UCAs: Only have 2 degrees caster, need more because the tire is rubbing the inside of my fender. You might not need to trim the black fender cap or bend the metal tab if you already have UCAs and lots of caster
Honestly, if you do all this, you could probably go even bigger than 295s and get away with it.
cool thanks. how much lift do you have?
Fuel D689 17x9 -12
Wildpeak AT3W 285/70/17
Bilstein 1.75" up front, 1" spacer rear
Got a little bit of rubbing I'll have to take care of
10 ply tires have nothing to do with the shaking. Balancing is usually the issue on any tire. Occasionally I think it is a wheel problem. 4Runners are very finicky when it comes to balancing. They have to be done almost perfect. Get a road force balance and make sure the people balancing them know what they are doing.
I’m having issue with my Pro after adding new Falkens 10ply. My tire guy said it should not matter being a 10ply. No issue before I removed my Pro wheels and tires. I’m taking it back in to my tire guy. I stayed with stock size tires but he is going to put another new set of tires on the front. When I hit about 50 or 55 wheel shakes just a little bit it will not go straight. Soon as I leave go of the wheel it want to pull to the right. I deal with the same tire place for years. Not worried he will get it corrected. Just not sure if it is the wheel and tire is not balanced or if I have a bad tire on the front. My other Pro wheels and tires no issue.
I’m having the rubbing issue here as well. Just put 1.25” spacers on and have 285’s. Are you saying to get an alignment with max caster (I have aftermarket ucas) and a little trimming up front and I should be good?
You should be good. I ran 1.25" spacers on 17x8.5 -10 with 285s on stock UCAs and only 2 degrees of caster and did not have any issues with the tire rubbing the plastic fender, only the body mount. How much caster are you currently running?
anyone have experience with Summit Offroad?
21 pounds and $175.
for the record, I haven't been able to get a single response from this company via their website, email, or instagram in over a week. Just asking about basic fitment before I purchase. They are very active on their instagram, posting marketing photos constantly, but have yet to respond to either comments or messages asking basic questions. Doesn't exactly instill confidence about buying their product. Also, one of their main "influencers" (guy that owns the above white 4runner) posted a video today showing that he runs spacers to get the stance width I wanted, for whatever that's worth.
Any 5th gens on here running the new(ish) Kenda Klever 35x10.5x17? Good reviews so far, plus Walmart has them for like $750 out the door after tax and some Tacoma guys seem to like them.
Would love to see some pictures if anyone has them.
2015 4Runner Limited
Removed XREAS
Bilstein 5100
OME 885 Fronts & 889 Rear springs
SPC UCA's
SCS Ray10's
Falken Wildpeak AT3's 265/70/17
I'll upgrade to 275's or 285's when these tires run out.
My caster is currently set at 2.7. Alignment done 2 week ago before spacers
hey, by any chance, do you have a front or rear photo that shows how far the tires stick out from the sides with the -38 SCS wheels?
2019 TRD ORP Non-KDSS
Wheels: Stock 17” TRD Pro wheels with 1.25” G2 spacers
Tires: Nitto Ridge Grapplers 285/70/17
Speed Rating: 116Q
Load Range: SL
Suspension: Front = Bilstein 6112 with medium duty springs, 3” lift / Rear = Bilstein 5100 with Bilstein heavy duty springs, 2” lift
Body Mount Chop: None
Tire rub: Before installing the wheel spacers, it only rubbed when backing up at a hard turn. With wheel spacers no trimming wasn’t an option.
Front Bumper: Trimmed about 1/2" on the lower corner.
Fender Well: slotted the bolt holes and pushed forward about 1.5”.
Mud flaps: Removed fronts for now, they were rubbing
I’m at about 2.5 lift front and 1.5 or 2 for the rear. Currently running the pro wheels but switching to the scs f5 -38 offset. If I keep my current ko2 in 275 I’m think I should be good to without rubbing thoughts?
