Another Bilstein 5100 question
I'm thinking about doing the Bilstein 5100's all around but the rears are currently on backorder so I can only do the front for now and then in two months I can do the rear.
My question is, should I do 285/70/17 or 275/70/17? I want to increase my ground clearance more than anything because I have KDSS and my front skid plate scrapes too often as a result. How high do I need to adjust the front to clear 285's? If I leave the rear alone for now can I keep the fronts set at .85 and still clear without major rubbing?
I am also planning on installing total chaos UCA's.
I'm a complete novice when it comes to lifts in general. This will be my first time modifying any vehicle so I'm having the local dealership do it. I just want to do it right the first time.
In Stock?
https://www.amazon.com/gp/product/B...e=as2&tag=thblwhli-20&linkId=4ELP2JIUPGWWY4KN
Nothing in the ad says it's for the set, does it? I hope I'm wrong, but clarify if you can.
I don't see anything that says SET or PAIR. But you can call them up and ask, very friendly customer service. 1-888-244-6166 good luck!
I sent them an email since they're closed today but they're local to me anyway so I might just swing by Monday and ask. If I only get one, maybe they'll match the Amazon price for the second shock.
I also ordered a Daystar 1.5" spacer on Amazon
OME 2895E rear 2" coils and front 5100's set to 1.75. This is the rake I have with that setup. I love it but I want to move the fronts up to 2.5.
Also, the 5100/OME coils do some decent flexing.
Yesterday I had my Bilstein 5100's installed. I went with the 2.5" setting up front and added a Daystar 1.5" spacer in the rear. Ditched the stock Dunflop tires for 275/70R17 KO2's.
MAJOR improvement in looks and ride quality!! No more major nose dive during breaking and it soaks up bumps better. Absolutely zero rub and I get to leave the mud flaps on!
I was worried about it looking "goofy" with that amount of lift on 275's, but I actually love the look!!
This has probably been asked before...but at 2.5 inches up from are you running the stock coils? I'm planning on ordering a set of 5100s and setting at 2.5" front with 1.5" Daystar in the rear also.
Spacer
I'm really enjoying my 4Runner so far. I've been looking around on the forum if I need spacers in the rear if I install 5100's in the front and back. I know that there are millions of comments out there about it but I can't seem to find it. Can someone help me or point me in the right direction of where to find the information. Also, what will be the best height to set them for a DD and a little bit of off-roading. I want a little lift and I'm thinking around 1.75 all around.
What part number did you use for the rear daystar spacer? I have a 2016 sr5p and would like to get the same set up but I don't see just the rear available.
Assuming he used the same spacer I used for the rear, it is: Daystar KT09127BK Comfort Ride 1.5" Rear Coil Spring Spacer Kit
erinobr2000
