Another Bilstein 5100 question
A spacer lift and a coil lift are different because coils will actually give you more travel and often times a higher (stiffer) spring rate in order to compensate for load & thereby NOT sag. Spacers are nice and cheap and easy because they simply stretch out your strut and coil, but fail to compensate for load & do not provide any articulation benefits
Instagram @tcr_89 2016 SR5P 4wd 3rd row - FN wheels countersteer X - 265/70 BFG KO2 - Bilstein 5100 (1.75 setting) - NFab side steps - TRS Morimoto 4300k HID kit - NOKYA yellow fogs & DRLs - AVS hood visor
Thanks for explaining.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Yesterday I had my Bilstein 5100's installed. I went with the 2.5" setting up front and added a Daystar 1.5" spacer in the rear. Ditched the stock Dunflop tires for 275/70R17 KO2's.
MAJOR improvement in looks and ride quality!! No more major nose dive during breaking and it soaks up bumps better. Absolutely zero rub and I get to leave the mud flaps on!
I was worried about it looking "goofy" with that amount of lift on 275's, but I actually love the look!!
Looks sweet. Does anyone know the part# for the correct daystar 1.5 spacer for the 5th gen? So many options on amazon. Looking to raise mine from 1.75 to 2.5. Thanks.
Something that i can't comprehend - what is the difference between 1.5" days and 1.5" coil spring? By numbers both delivers the same lift.
Given 1.75 front.
you asked it anyone was running 1.75"/1.5" and I was just saying for reference someone was but used SAW coils. with that said, coils have a higher spring rate that can yield more lift and hold stable under load
These 2895E coils and 10mm trim packer should compliment my 5100 setup rather nicely! SO STOKED.
Shout out to Total Automotive Performance for the best deals and really awesome customer service!
Anyone interested I listed my brand new Cornfed 1.5" rear spacers. Totally unused.
After 5 posts in 5 separate threads in one day including the For Sale one, yes, I believe the word is out that you have a pair of Cornfed spacers for sale....... :deadhorse:
My wife said I need to sell them before I buy the new "springy things" I want. I can't argue. I just ordered my Gobi stealth today, too bad it's going to take 8-12 weeks to get here. But they threw in a free ladder and took $100 for the Fire/Police/Military discount.
So, I've got TRD wheels with 275/70/17 KO2s on and I have Bilstein 5100s and daystar that I'm planning on setting at 2.5" up front with the 1.5" spacer in back.
My question is this: I bought 1.25" Spidertrax and I'm curious what to expect in the rubbing department? Or should I leave them off?
I have spidertrax on my 4th gen and the rubbing was a pain to fix. Thanks!
Not a great pic but I did some flexing with my 5100 + OME coils the other day. Super happy with the way it handled.
This rig looks amazing! I'm new on this forum. And I'm not sure if I'm posting correctly. I came across the the problem of installing the 5100 Bilstein 2.5 inch front and stock on the back. I now have a nose high lift. Which I dislike. Do you like the Daystar 1.5 spacers? any problems?
I'm trying to find out the best way to fix the problem. Would coil overs be a more durable option than spacers?
Question for the 1.75" front bilstein and 1" rear setup... Is there any rear sagging with full load inside and cargo on roof?
Sent from my LG-D850 using Tapatalk
Yeah, what he said ^^^^?
What happens with this set up when you are loaded up and/or pulling a trailer with couple hundred pounds tongue weight?
Anyone rolling with 285/70/18s? Bought a 4runner with these installed but I'm 99% sure it doesn't have a lift. With the wheel cut all the way I have about 1/4 inch to the fender.
I'm wanting to do 5100s set at 2.5 with 2" Toytec super flex coils in the rear. Any recommendations or issues I'll run in to? I wouldn't mind putting some spidertrax spacers on the wheels to sit them out slightly as well.
So I'm going to get 1.75 in the front and a 1.5 in Daystar spacer in the back installed tomorrow. I know someone asked last page in the thread but there was no real answer. Will I have any issues with the rear? It says I will be ass high but does that effect anything?
5100s, 1.5" rear spacer - Cooper 255/80R17
This is 5100s all around (2.5" front) and Daystar 1.5" rear. I can't see why 1.75" and 1.5" would cause a problem. You will be "ass high" as you say.
tuṣṭāva
