Another Bilstein 5100 question
5100 all the way up in the front.
Rear 5100 on day star levlers.
Stock rims and tires:-)
Parked next to a TRD Pro so took a pic for comparison....I'm happy with my results!
5100s with 1" Cornfed in rear, 275 BFGs on ICON wheels
My buddy just installed some 5100's and NO spacers or other lifts. He set the front to the max height setting (2.2 I think) & he has a nearly perfect level truck. He's on 275 KO2's and stock wheels and it looks amazing. I thought for sure he'd have some reverse rake with the 2.2 setting up front but he doesn't, not even with his hitch bike rack and mountain bikes sitting on them (which would pitch the nose up additionally).
Because of this, I'm sold on doing the max height setting for the 5100's up front and not doing any spacer in the rear. It looks really good on his truck and as I said... level.
Truck may look level but no way frame is. I bet with the trunk full it would look silly. I am at 1.75 with cornfeds and am very happy. Looks killer and no nosedive
Any additional pics of your setup @TikiJoe? What are the billy's set at? Thanks!
Sorry for the delay I haven't been on here. Here's one with the boat hooked up so the rear is sagging a little bit.... 1.75 upfront
New 4Runner owner here. Traded the Tacoma in yesterday, so I’m trying to learn my way around this 4R suspension.
Are you guys using the ride height adjustable 5100’s in the front with the stock coils?
And does anyone make a rear coil to achieve 1” lift? Does Old Man Emu make one that short?
I too utilized the front coils for my setting at 1.75'' and for the rears I used a RC 1'' spacer.
To each his own; you are more than welcome to try/do it.... But I'm telling you, somethings not right with that. Either he isn't on the highest setting, or something else is going on. TONS of us have all done this mod, and you WILL HAVE NEGATIVE rake with that setup. Heck, there is approx 1/4 inch negative rake at the 1.75 front setting and nothing in the rear (tho the fenders will look level).
The pics below are 1.75 front (which is NOT the highest setting) and stock rear... And it's level to the eye, but slight negative frame rake.
Again, do as you please, it's your rig, your time, your money. But with a completely stock 4Runner, 5100s at all four corners, and the fronts set to the highest, you will not be level.
Hi
Where do you take measures to make sure it is level ?
New 4Runner owner and new forum member, first time posting. This thread has been invaluable, I've pretty much read it front to back. I just ordered my 5100s, front and rear, and 1" Cornfed spacers. Plan to go 1.75" up front. For those that have asked about install cost, I called around to three different shops (I'm not much of a mechanic) and was quoted $530, $430, $470, all including alignment. Each was 4 hours of labor plus alignment, so just differing rates per hour and different alignment cost, I guess.
For the time being I plan to black Plasti Dip my stock wheels and leave the tires until they're worn out. It's a 2016 SR5 with about 23k miles, so I've got some time before I'll have to get new/bigger tires, and maybe wheels at that point too.
I'll post some before and after pics in a couple weeks. Glad to be here!
Just finished installing 5100's all around, and swapped Dobinson's 302's up front and 325's in the rear. Fronts are on first (stock) setting. Initially gained 3" in the front and 2.5" in the rear. A bit more than I initially wanted, but I'm sure it will settle a bit. Big thanks to Mike at Dobinson's for his help in picking the springs based on my current and future needs.
Love the stance, and will try and get a pic up soon.
AndiGarage
