With the vehicle turned off, none of the USB or 12V ports in the 4Runner work.
Any way to change this? I'll be installing a dual battery set up this year, and want to be able to run a fan out of the far rear 12v and phone chargers with the vehicle off.
Thanks in advance!
I'm sure you've considered this but run a line directly to the house battery and add a new 12v port. Off Grid Engineering makes a kit for this or you can DIY fairly easily. I thought this was easier than rewiring existing ports
Good info. Was hoping there was an easier way, but I can always do this. Thanks
Personally I added a second fuse block and ran all my auxiliary circuits off of that, including a new power panel in the rear controlled with a switch back there too.
That's the more common solution. This way you also isolate any of your added electrical systems from the factory wiring. Way easier to maintain and troubleshoot that way too.
There is a how-to in the stickies for running constant power to the 12 volt outlets.
You have pics and details on this??
easiest way for me to do this was run the ARB fridge wiring kit from battery to a marine socket panel (kill switch, 12 volt meter, USB, and cigarette plug).
Using the ARB fridge wiring kit made it really easy, no splicing, no guess work on fuse placement, all wiring and fuses included, etc.
Then attach whatever accessory socket panel you want to it. You can go super fancy or super simple. Again no splicing or anything.
Here is the pic of mine, but yeah all i needed was the ARB wiring kit and a panel.
I did not wanna hack into existing vehicle wiring.
This is what I did, Cig lighters and USB power all the time
I found it online somewhere searching how to have constant power, I’ve had it for about 4 months with zero issues.
Basically built jumper from hot source to dc power circuit.
