Blacking Out the Runner's Chrome
Took the plunge with Plasti-Dip. Love how it turned out. Ran out of time on Saturday during my 2 year olds naptime, but I got 3 more cans in the garage! Chrome strips are next...maybe a TE conversion w/ Plasti-Dip.
This looks amazing on blizzard pearl! I think I'm gunna do mine in plastidip
Plastidipped all the emblems on my '12 trail and something didn't feel right everytime I drove so finally git rid if the smallest chrome emblem ! same procedure as before except took a sewing needle to carefully break the plastidip in the emblem to tear and remove !
i have had my 14 a couple weeks now and have already noticed water drip marks from the sr5 badges. i think i'm going to take them off and leave them off.
edit: on the 14 they are on the side post between the back door and rear side window.
I have a week's worth of vacation coming up and this is the project I've chosen for that week. The plan is to remove, paint, and reattach as much of the chrome on the Runner as I can. It will all be painted either Matte Black or Satin Black, probably the latter.
Does anyone know or have suggestions how to remove the chrome pieces and strips from the truck? There are 4 chrome strips: under the doors on the left and right, on the front bumper, and on the rear bumper.
The main chrome pieces I'm curious about removing are the roof rails, the piece on the grill with the toyota emblem on it, and the pieces surrounding the fog lamps. Any ideas or suggestions on how to remove any of these pieces?
For the roof rails, I'm assuming that I would just pop off the 4 plastic end-caps and unbolt the roof rails, but I am not sure if this will work.
(I'd also like to remove and paint the large, chrome 4RUNNER logo on the rear hatch, but I can't think of a good way to paint it so that I can leave the 4RUNNER lettering and space inside the Toyota emblem the same color it is right now.)
Suggestions on specific paint would be appreciated as well.
I figured I would just use Krylon Fusion Satin Black and Satin Clearcoat for the plastic pieces and use the same for the roof rails AFTER I've rust primered it.
doodman, can you confirm how you removed the roof rails? i think i missed it in the thread. was it just like you said; pop off the end caps and unbolt the rails? i have got to do this as my first mod. tx.
I took mine off... looks better!
Funny, nothing left to do on my bikes so I'm starting on the 4runner, namely plastidip.
I was also looking at the roof rails an hour ago, wondering how they come off.
...I believe I read people have plastidip the rear emblems by just spraying it on, then peeling off the paint, anyone confirm?
Front emblem is easy, I guess I'll just get stuff off that is progressively harder.
Blacking out Chrome
As a lot have posted as well I am not a huge chrome fan. Starting painting these last week. Going to go ahead and paint the end caps on the roof rails tomorrow. Can't quite get the feel for the two tone. Anyway its been done many times on here but wanted to share my pics.
After reading this thread, I have two questions:
1) I am torn between the Krylon Fusion and the Plastidip, but leaning more towards the latter. What are you guys liking better?
2) With the front grill, if I want to entirely black it out (chrome strip and emblem) does this involve removing the piece? If this is the case, how difficult is it?
[MENTION=104688]Lenny33[/MENTION] I think he was replying to the guys who were wanting to remove and dip the roof rack.
Probably easiest to leave the chrome strip on and plasti dip. For the chrome emblem on the grill it is also easiest to leave it on the vehicle but you will want to mask off the honeycomb portion of the grill and behind the emblem as you would not want to plasti-dip the radiator. I would take off the pieces and plasti dip them individually.
I have removed the entire front grill and it is not that bad. I made a write up when I swapped the headlights and grill and bezels for trail versions.
http://www.toyota-4runner.org/5th-g...headlight-fog-bezel-write-up.html#post1288029
Plasti-dip = non permanent, removable, forgiving if you make a mistake (run,drip, overspray)
Fusion = permanent, more durable but you would have to sand down to fix a mistake.
I would have like to just permanently paint mine but my painting skills are not up to my own standards.
Good luck
Thanks, Shogun - I will give it a read! Kinda leaning towards the Plastidip for my first painting try to see how I like it.
I did the Fusion and like the look better. It still has a chrome effect but black. If you put too much, the chrome pretty much turns completely black so a little trial and error involved.
I don't think it's all that durable though. I probably should have done more surface prep. I just cleaned with alcohol cause I didn't want to roughen the surface and lose the chrome. I put a couple of coats of clear over the Fusion. The surface is hard and durable but it does not adhere that well to the chrome. I "gently" bumped the lift gate on my garage entry and it cracked off in several places. I'm pretty lazy about fixing things. I like doing it the first time but not the corrections. This weekend I'm just going to spray some Fusion into the cap and use a small brush to touch it up. Then I guess I'll do the same with some clear coat.
In the garage right now plasti dipping the chrome handles and skirt on the limited.
I've posted a pic of my first coat below, is it too thick a layer for 1 pass?
Prepped:
1st coat:
I'm thinking it's a bit on the heavy side so I'll make the next ones lighter, but it's always nice to have some reference points.
Keep us up on the progress...
Ordered a case of the Krylon fusion at the local hardware store and waiting for it to arrive ( had to order a case to get it)
Finished up around midnight last night
I decided to do 7 light coats on the handles and side skirts, which is in contrast to the 10 coats I put on the front and rear chrome. 7 light coats gives it more of a satin look up close/ matte look from far, while 10 coats makes it look like rough rubber from both near and far.
Pardon the shotty pics, which reminds me to order a new memory card for the DSLR today
Hmmm, should I do the wheels now too?
wow those pics came out a lot worse than I thought.
Laredotx
