CV Boots Leaking...
[MENTION=42699]brucemoose2[/MENTION] how are your amazon clamps working? I just ordered the Precision Brand 25-40mm from amazon as well. Both inner boots on the small side started slinging grease within 5 miles of installing my lift.
Great! No leaks.
How tight did you torque yours ? I see the Mcmann ones had an in lbs torque rating
Just lightly with a nut driver. Enough to snug them and stop the dripping but not risk tearing the boot. You can always snug them more if they leak, so don't go nuts at first.
Mine have been torn and split completely for the past 6,000miles or so
Lazy to replace the axle
Say a prayer for me..
Ps, what's the worst case scenario? Snap and lose a wheel?
Front driver side of that makes a difference
The west marine clamps are discontinued, but may be special ordered. I just did this. Unfortunately, the clamps they supplied are not correct. They're now substituting a clamp that is both too wide and also not smooth on the inside.
You need a smooth clamp that's 9mm wide. The 25-40mm size is about perfect. I found a new supplier on Amazon. I ordered them and with my prime shipping, they were very reasonable. $7.10 for a pack of ten. I installed this morning and they're great.
Search for this on Amazon: Precision Brand Smooth Band Metric Worm Gear Hose Clamp, 25mm - 40mm (Pack of 10)
What size do I choose for the smaller diameter side of the cv boot? And are these clamps smooth like the west marine kind?
I think I'm getting confused by "25mm-40mm" is that a range of size they can go or the range of sizes that they sell?
Thank you
Had my state inspection done at Toyota of Richardson (TX). Going in I knew my boots were leaking. They said that I needed the CVs replaced for $1200. Needless to say I am going to get a syringe, grease, and some clamps and cross my fingers.
If that doesn’t work I might try a local mom and pop shop.
find some OEM toyota remans on eBay and do it yourself or with the help of a friend. I'm sure there are users on this board who would be willing to help you for the cost of some beers or a few bucks. don't just squirt more grease in there and throw some hose clamps on. dirt and debris could have made its way in and there's no telling how worn out the internals are. if they've already torn or ripped or cracked, no clamp is going to work.
also, if you plan on doing any type of wheeling, just but the OEM remans i mentioned earlier. i learned the hard way by purchasing "premium OEM replacement" CVs. they both snapped while wheeling.
Not to revive an old thread. But, last weekend I lifted the front end of my new to me 4R with some OME and 885's. Luckily I had the presense of mind to order the worm clamps ahead of time. Just from the drive home from the alignment shop, the boots started to leak from the inboard boot at the axle. Removed the OEM clamps and replaced them with the ones I purchased. Didn't over tighten, and seems snug enough. Time will tell if I need to snug them up a little more.
Everyone’s situation is different, but If you have the time and money, just replace the boots and repack with grease. These vehicles deserve the proper repair. I just had both of mine done.
Just an update.. Over two years later and still no grease!
There telling me I need stronger after market CV boots
Its leaking from the inner one (closest to motor) I think.
20120419_183041.jpg~original
Is the boot cracked?
On my 1999 Suburban K2500 4WD, the OEM boots last, but few if any of the aftermarket boots do. Most use neoprene boots and they don't last but 2 to 4 years. Rockford makes aftermarket Thermoplastic boots and they do last. Probably have to call them to check the fit.
Rockford Constant Velocity - C.V. Dura Boot Kit
I would appreciate the link to supplier selling the crimp on clamps. Need some for a reboot job on my Son's Suburban.
Almost 170K miles on my wife's 2014 SR5 and the boots are holding up so far.
You'll break the axle for sure. Pretty boneheaded move.
I just changed my axles with OEM reman's. Decided to keep my originals and reboot to have spares. Honestly though, looking back (and knowing what I know know), I'd just reboot. It's not really that much extra work like some indicate. Sure, that assumes no stubborn nuts, bolts, screws, parts, etc...
I'd say if it's a recently torn boot (w/ little miles driven in that condition), a reboot is a totally viable job for a moderate DIY'er. I got spooked and went with new axles. That's not to say I think I decided wrong, just that I don't think it's too much more involved. Just make sure you get all your parts.
If the axle has been run with a torn boot for a while, then grit and grime could have damaged the joint surfaces or the tripod bearings. That would be more involved and a straight axle swap is way easier. With the prices of axles, I'd still keep the OEM and try to rebuild it, or at least make a decent assessment of how worthwhile it would be.
Look at these videos:
YouTube
YouTube
Agree completely. If it's a recent tear in the boot, I would reboot. Use the Rockford thermoplastic boots. The reboot job is pretty easy.
Has anyone experienced a chronic CV boot clamp failure? In my case it's the small clamp of the outboard boot on the driver's side. I noticed the OEM clamp failed at ~90k and I replaced the axle with a Cardone and now the exact same clamp has failed again. Neither time did I find damage to the boot.
My suspension is completely stock except for harder front sway bushings and a heavier rear sway bar. I turned the steering full left and full right and it looks like I've got miles of clearance between the affected clamp and everything else.
Anyone have any theories as to what's happening? Thanks.
Not sure why the clamp is failing, but you could try replacing with a worm drive clamp. That way you can monitor and tighten them up as needed. I used these when I rebooted my CV axles: Set of 8-Toyota 4Runner CV Axle Repair Clamps Kit, Leaking Boots after Lift Kit | eBay
CV Reboot Tutorial with Boot Stretch (80+ Pictures)
^+1 on the worm-gear clamps.. I just rebooted both of my axles and elected to not go with the factory clamps (firstly didn't have the right tools to to them properly, secondly I like the ability to tighten them down to a degree that I like).
When I first lifted the front end (wayy to high) my factory clamps did not hold too good and the boot started oozing. After installing the worm gear clamps the issue went away until I did a full reboot job.
I got my clamps on mcmaster as all the ones I found in the store looked too cheap and were too wide.
These were the 2 clamps that I ordered that worked out well for me:
McMaster-Carr
McMaster-Carr
My inner boots started seeping grease.
I just slaped a stainless steel wormgear clamp from Orielys right over the top of the OEM clamp, and no more leak...boot kit collecting dust in the garage.
freddygino
