DIY: Interior LED swap (cluster, HVAC, switches, window, *steering wheel)
on the superbrightleds, can u change the resistor on the neo4 hp led, i know the resistor has to be changed to make it work and light up. if you can do that, ill pay for 4 bulbs. its for the lcd display on the hvac.
I have a few extra Neo-5 hp bulbs here I think, I'm not using em so I'll see if I can get them apart. Do you know which resistor you would put in to make it work?
Check out this post from a little while ago on resistors for the HVAC LCD lighting and NEO bulbs from superbright;
http://www.toyota-4runner.org/931384-post337.html
Basically 50-180ohm depending on the colour and brightness you want.
Hey Alex, I'm assuming you are painting the back of those needles white after you remove the orange paint. What are you using? I ended up using nail polish (not mine I swear) which seemed to do the trick, but curious to know what you did.
Thanks for the info on the resistors! I'll take a look.
As for the needles? Tis a trade secret my friend. ;)
But if you MUST know, here's a hint, LESS is more... As in, I didn't paint them, just used fine sandpaper to make them opaque.
Does it matter which side of the holder you put the resitor/ wire in?
I guess just figure out which is the resistor and which is the diode and swap the resistor only. How it's put back in the bulb holder doesn't matter because the holders screw in both directions
How about NAV units?
Gentlemen! T4RGaugeSwaps.com | Home of the Emelianenkov Fade! is alive, all thanks to core212!
There will be more pictures going up soon.
Get your name on the list for a badass LED swap!
-Alex
Alex, have you swapped out the LEDs on a factory NAV unit? Mine light up green, I would like them to light up factory orange. Just wondering........
Here's a Link to give you a better idea: http://www.toyota-4runner.org/audio...nge-backlight-camry-solara-nav.html#post18369
As much as I think that would be a really cool swap, I also have tremors and think that swapping those TINYYYY LEDs is too much of a risk for me. I'd feel horrible if I damaged your nav unit :/
No NAV LED swap? Inside I'm crying....... :(
Appreciate it, thanks. I'll be in touch, I'm considering the white LED gauges.
Well I'm about 1/3 done. Contrary to what Darkie said, I started with switches/ hvac first to brush up on my soldering without scrappin my gauge cluster :hello:
Got a few hotspots to try and fix but overall I love it so far!
Lookin good! :bigok: Keep up the good work!
Hey man, did you use a 5mm for the lcd screen? Trying to figure out why yours is way brighter than mine.. Cause I'm an amateur I assume but thought I'd ask.
The neo-4 is a drop in replacement. Darkie made his own bulbs by reusing the OEM bulb holder and soldering a 1.2 ohm resistor onto a 3mm flat-top LED. Though the neo bulbs are good for quick swapping, and I prefer them because of my shaky hands and short attention span, they sometimes cause hot and cold spots, especially with the white bulbs.
Hope that helped! Good luck!
-Alex
I figured out the equation with darkie's help! Yay teamwork!
So you're good to go for soldering the 3 - 3mm leds for the big HVAC buttons that normally take the drop-in Neo3's that cause hotspots? ;)
What about the 2H-4H-4L button? I think that one also causes a hotspot when you swap in a Neo3 LED.
What about the DAC and Differential buttons and any others that need soldering because the Neo3 cause hotspots - can't remember which other ones do that now as I have not swapped any others out other than the HVAC buttons.
The Reset/Mode buttons don't have any hot spots with the swapped in Neo3.
What about the AirBag on/off buttons - those need to be soldered in right?
Yea, I'll give it a shot!
I can solder the 3 hvac knob LEDs, the DAC, diff locker, and rear window switch.
Even with a darkie-made LED for my H2/H4/L4 switch, I still have major cold-spots. Maybe if I feel up to taking out my radio trim, I'll see if I could modify the light distribution inside the 4WD switch. I'll save that for a rainy day :D
The airbag on/off, seatbelt warning light, and vehicle security light require being soldered in (quite a pain and I just figured out how to make that swap work
NVBASSJUNKIE
