DIY: Interior LED swap (cluster, HVAC, switches, window, *steering wheel)
yeap u got that right,
You meant right to 3 of my questions below?
1. That means I need 14 and I only ordered 3.........
2. These are not the same as the oznium PLCC-2 LEDs for the guage cluster are they?
3. For the recirc and defrost button, do they also need 2 leds each? One for the button itself and the second for the indicator strip of light that comes on when you depress the buttons themselves?
riceandpho; said:
also my color they are blue, blue on the arrow and blue on the background lighting, no white. only the interior map and dome and door is white, i dont want to do blue, since u cant really see it.
Interesting. In the pics you posted they look white on the arrows but blue on the background. But then you mentioned that you didn't do blue because you can't see it? What are you referring to now? The dome light? I get that is not blue, but the lighting for the HVAC background is blue and the arrows look white, but you said they are blue. Please clarify what you mean. :D
riceandpho; said:
dont forget to solder an led on the off button, everyone should know that theres no led on the off selector arrow.
Like
Which off button are you referring to?
SilverG,
for the indicator arrows, they are not the same as the PLCC leds for your dash.
Here is the breakdown of the 3mm LEDs (non-Neo3's):
1 - window switch
4 - Fan speed (5 if you want the off arrow lit up - what riceandpho was referring to)
2 - A/C
5 - air selector
1 - Recirc indicator on
1 - Defrost indicator on
Which means you'll need 11-12 more depending on what you want to light up.
Hi darkie3495, here's my attempt of clearing this up for everyone else having the same questions as me. Please edit this post if I've made any mistakes or left out anything. I know I may have not covered everything for the Limited 4Runners, so please add those into this list so that you don't get bombarded by newbies like myself asking the same thing over and over again. :D
HVAC knobs (3 big black knobs beneath the HVAC LCD screen
  1. Fan speed (5 3mm LED's if you want the off arrow lit up) for the selected speed and 1 neo3 3mm LED for the background color of the Knob
  2. A/C (2 3mm LEDS - one for the "Auto" selection, 1 for the "A/C" selection and 1 Neo3 3mm LED for the background lighting)
  3. Air selector direction - 5 3mm LEDs for the buttons and 1 Neo3 3mm for the background light)
HVAC LCD screen - 2 Neo5 5mm LEDs
Recirc button (1 3mm LED for the "ON" state and 1 Neo3 3mm LED for the button itself)
Defrost button (1 3mm LED for the "ON" state and 1 Neo3 3mm LED for the button itself)
Rear Power window Switch (1 Neo3 3mm LED)
Driver side power window switch - 1 3mm LED
DAC, Seat heater, Diff Lock, RSCA, VSC Off - 6 3mm LEDs
2H-4H-4L knob 1 Neo3 3mm LED
Gear Shifter lights in center console - 1 #74 small wedge LED
Glove box - 1 #74 small wedge LED
Cup holders - 2 7-xHP LEDs
Gauge cluster roughly 40 PLCC-2 LEDs
Volume button on steering wheel ?
Mode button on steering wheel ?
Lcd screen is neo4
2h 4h 4l is neo3
Gear shift use a #74 its a small wedge type, glove box also use that.
also if you have dual climate control, its gona be differnt.
SilverG,
1 - window switch
2 - A/C
5 - air selector
darkie, if i mailed you just my instrument gauge cluster, tach, speed, etc, and payed you and for the parts would you be willing to hook me up with the same sexy white LED setup you have? Im going out of town next week and wouldnt be driving my T4R and greatly appreciate it.
I'd do the swap for ya! I know darkie is busy often
Getting ready to do a white and red swap for mrpanic7! Giving his gauges the signature 'emelianenkov' treatment, but with red accents. :D
Will post pics when I finish things up, and I'm sure he'll post some more when I send em back!
Can't wait to see it Alex! To change the background lighting on the rpm gauge, you just change the 3 center LEDs right?
No, those three center LEDs just light up the needle. You need to find which LEDs illuminate the perimeter, and that all depends on what trim model you have. Sr5 and sport are the same, limited is different.
2012-01-31_04-01-43_512.jpg~original
That looks so damn good!:bravo:
Mine is the sport. I guess that means all the gauges backlighting have the LEDs on the perimeter of the gauges?
No, I'll post pictures when I get mrpanic7's gauges in 2-3 days.
Thanks Alex. Please mark up the pics with circles around the perimeter LED's and the center LED's that need to be swapped out. I won't be swapping out any other LED's other than perhaps the background lighting for the gears. I'm deliberately excluding all the warning light LED's that are in the RPM gauge as well as the gauge on the right hand side.
Oh, I'm not doing the swap for you? :D
I'll doctor the pictures, don't worry!
:D One of my carpool buddies at work is an Electrical Engineer and he offered to do the soldering for me. Thanks again for your offer. He goes on vacation 3rd week of March, so if it's not warm enough by then, I may have to take the gauges out before he comes back (1 month later) and send them to you instead.
U DA MAN regardless! :D
Sounds good man! Let me know if you need any help or maybe a swap. Almost always here to help!
7ron
