Eibach Pro-truck lift
Sell the rear springs you have. Buy the adjustable rear kit.
I'm waiting for our marketing folk to get them on the web site right now. They are in stock and ready to ship. I'll hopefully have a thread with data and link up before I leave today.
any way to exchange or retrofit with the springs I have?
kit remains unopened currently.
So assuming I'm the dummy I am. Stock runner and no extra weight what spring weight should I get. Looking for 1" lift passenger and 1.5" driver's side. Thanks
Awesome, thanks! I saw that link had a bundled set with shocks. Will that be available on Eibachs site? Or is that an eibach company
Should be on Eibach's site soon, but not sure when. They are available for order from us today. We are close with Eibach and a direct dealer for them.
Ryan,
Any benefit to using those massive axle bump stocks with my Level 1 kit?
So not quite the pro kit, but mostly Eibach parts so thought I’d share! Finally pulled the trigger. Eibach Pro shocks all around, fronts assembled with Wheelers (Eibach) T1 springs, rear coils are OME 2985E. Should be good for 2.5” front and 2” rear. I tow a boat often in the summer, and was concerned with reverse rake, so I pieced together my own budget setup. I’ll follow up with pictures this weekend as some 285s are also going on.
Ok Ryan,
How is that 4runner doing testing the new coil springs for the Pro fox suspension. Updates. Ready to release yet? Thanks.
Hi! The pro lift kit from eibach says it will give a 1" lift in the rear, which gives the truck a level look. With the OME springs you have does that keep the truck in it's OEM rack? I'm looking to swap out of rear eibach coils due to added weight that has it lean backwards now.
That’s why I pieced together my kit. The OME springs should give about 2” of lift. This would leave a .5” less rake than factory with a 2.5” front lift. (I think factory rake is about 1.5”, at least on my limited). It’s not installed yet but I’ll take a picture when I’m done, I’ll also take a picture with my 3500lbs boat hitched up.
Crookedcat
