Greddy info meter touch (Michigan)
silver4est
I don't have mush use for this Greddy info meter as I don't do any serious off roading or towing. The Info-Touch is ideal for most vehicles, from stock cars to highly-tuned street machines. Depending on vehicle, the unit can display from a large list of factory ECU signal Items, estimate Power with a weight/acceleration run, estimate Fuel Economy and Cost in Eco mode, Data-log up to 15 minutes of info, and read/reset DTC (Diagnostic Trouble Codes,)
good condition, plugs into and powered by the OBD II port, works with toyota, nissan, lexus, honda, acura, not sure on subaru.
was being used on my 2002 4runner
asking 275/best
any idea if you could use this for temp with the 3rd gen 4 runners? I got an 01. I know you could buy the optional harness for the coolant temp, but didnt know if it worked with our runners.
I'll dig through it tomorrow and see. theres a few things it does that I haven't got around to setting up. It came with the 4runner I recently purchased. Have to assume that engine/water temp can be read through the OBD.
No extra harness, I get intake temp, water temp, tach, battery voltage, throttle %, ignition timing, o2 reading, speed, long and short term fuel trim etc.
This is on my 02, so you should not need an extra harness for temp.
