How To: AEM F/IC-6 Install, Tuning, and Help Thread
I had Injector Dr. do mine - local to me - the old owner was cool and I watched when he did my last few sets - he past since -. But he would check and note ohms reading of coils, then set them up into beakers set fuel pressure, then run them 15 seconds -and note the spray pattern and volume, then pull all the seals, screens off and clean them - ultrasonic cleaner??? - install new seal and screens, test again and note. I had 2 that were about 2ccs less so he ran them longer and retested them andthey were all the same.
It was pretty cool but cost $20 each = $120 no shipping since local. But without testing you can even be sure what a new one is doing. This last set of 3.4s I did I just dropped and picked up the next day with a info sheet.
They just did a write up on Dr injector in the Toyota Owners Magazine. They spoke very highly of this place. The next time my rig is down for maintenance...I'm going to pull my injectors and send them off to the Doctor!
I met the "Dr. Injector" of Sacramento, I dropped them off since he lives close to me. He really did a great job and knew his stuff. He was the one who gave the idea of changing from a stream pattern to a spray pattern in another vehicle I owned at the time.
The injectors worked perfect after getting them back and he even numbered them to optimize even fuel combustion. Top notch.
hi guys - just installed my AEM fic and am wondering where the manifold pressure hose "after throttle body" tap location for the boost hose is. Does this look right?
Yep that is it. that will be the same place you have to tap for the
S/C as well
S/C as well
Hey guys! So I got my S/C installed so its tuning time. Can can anyone send me a map or point me in the direction for a starting place for a 1996 auto? I am having some pinging with the stock pulley at high gear/low rpm's. Thanks!
You might have already read this in the supercharger thread but be sure you use the highest octane available. For CA, that's 91 but other states have 92 & 93. Takes out a lot of ping and is required by Toyota as part of using the charger (the new kits even came with stickers to remind you).
Other than MTD I don't think anyone has a base tune for the AEM controller yet but definitely ask around. Maybe try PM'ing those who might have the AEM on their rig (check this thread). Or, bring it to a dyno shop for professional tuning, the F/IC-6 should be well-known at most shops because of its popularity.
At WOT most people are shooting for the 12 AFR range.
Well I'm done with finals today at nine, this next week I will work on putting up my tuning guide. In the meantime pm me I can get ya started with some vids I used from aem
Tune off the WBO2. Your base map is the one toyota has given you.
Oh wait, do you have anything installed other than the supercharger dunktap? You need a piggyback controller on your 4Runner to do any tuning. Our ECU's cannot be flashed or tuned directly.
He has an AEM FIC thus the reason. He is here lol.
Pm me
As of right now its me dunktap, and then Dylan.
Yes, I have the AEM FIC installed. Looking for a 96/automatic/4spd/stock pulley OR 2.2 pulley map. Sorry should have been more clear.
I can get you my map later tonight. It's a 5speed map but is a good starting point.
Hey,
I just got my supercharger installed (Thanks again SCRunner12) and am looking to jump onto this AEM bandwagon :)
Maybe a dumb question, but probably the first of many hehe. I'm looking to purchase the AEM extension harness with the fic, but I see two different part numbers. I have a 96 auto, but AEMs fitment list doesn't show it.
I've tried emailing them, but never got a response.
Hey,
Hahaha good to have you, come to the dark side we have cookies!!!
I'm not sure to be honest, I would call them, but before you do take a look at your ecu and count the number of plugs and pins in each. They should be able to help you from there.
Just had a mistake pointed out on the wiring for the resistor for the cam circuit. The resistor should be on the MAGI+ wire not the MAGO+ wire. I updated the opening post.
Cpn2mss
