Inv4drZm's Build Thread
One of the guys in our group that we met in California has a Youtube channel named Offroad Hub. His latest video is our group run of Fordyce trail with some nice shots of my 4Runner.
Check it out, Ken's a cool Toyota guy, and his Rubicon video should have lots of the 4Runner in it too, from what I've heard.
Fordyce Trail // Toyota FJ Cruisers // A 4Runner // A Lexus // Oh My!! - YouTube
<iframe width="560" height="315" src="https://www.youtube.com/embed/GD5u8rGgxG4" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
I had a solidworks license for school last year. I just checked and I have 1 day left lol, so I can try to help out before end of day tomorrow if another format is needed.
I wish Solidworks personal licenses were so absurdly expensive.
The next video is out, Signal Peak trail.
<iframe width="560" height="315" src="https://www.youtube.com/embed/RSDTSV_bsVM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Wow I now have 1,000 posts in my build thread.
Here's to 1,000 more.
:cheers:
To 1,000 more!
I saw you're using stoptech pads and rotors which I'm looking into as an alternative to the power stop z36 kit but was wondering which calipers you're using and If you're running the 319mm or 338mm rotors. Thanks!
To 1,000 more!
I'm just using the stock calipers my truck came with and the 338mm rotors. Can still lock up my 37s so I saw no real reason to swap to 5th gen parts.
Not had many problems with the calipers? I know I've seen you post something about calipers but I can't seem to recall what or where it was.
Sorry for the double post but just thought of this, you could still use the stoptech parts and upgrade to the 5th gen calipers right?
Not had many problems with the calipers? I know I've seen you post something about calipers but I can't seem to recall what or where it was. &#55357;&#56852;
One side was seized but I used a clamp to free it up and it's been working ever since, around 4,000 miles now.
The 4th gen rotors are thinner, but I guess I probably could still swap to 5th gen calipers. I just don't have the need to right now, and like I said braking performance is fine even with how heavy my truck is.
Part 1 of our Rubicon vid is out. Grab some popcorn.
<iframe width="560" height="315" src="https://www.youtube.com/embed/OaBudWR3IfY" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Part II is out.
<iframe width="560" height="315" src="https://www.youtube.com/embed/Pq3LSlpK--Q" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
This is going to require a lot of work some day.
Tall enough to fit 14" coilovers flush with the axle tube once I chop into the body a little. Won't interfere with the rear seats if I weld them behind the axle and cut into the rear of the wheel well. Anyone want to donate me some coilovers?
You could start a Go Fund Me account.
I thought about starting a - Brett needs a Trophy Truck - account.
But then I figured I wouldn't have enough money to tow it any where, or the money to fill it up with fuel, so I gave up on that one.
I know Kevin Berthelot's Mega Lex has the rear seats removed for his rig with COs and Bypasses, but it's not a daily like yours. Curious how your gonna do your geometry. The Sherpa Motorsports crew welded support hoops inside the wheel well which I'm curious about as well. Love my truck the way it is, but you know, you always want more travel.
<iframe width="560" height="315" src="https://www.youtube.com/embed/nw9unmQigxQ?start=1112" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
It'll be fun, I'll need to chop into the body a little and re-plate the wheel wells around the towers to re-seal everything. 14" of shock travel will be nice, but I'm betting the main benefit will be from raising the lower mounts to flush with the axle tube. I swear I hit those things on every rock.
The Sherpa truck has an identical rear setup to my brother's FJ which is pretty nice too. :eyebrows:
Which coil springs is your brother using? Does he have a thread somewhere? Curiouser and Curiouser...
Don't do it man.......
Jk it's about time you match that wicked front end!
Sent from my SM-G986U using Tapatalk
I'm already itching to go +3.5" in the front and go full insanity in the rear lol. Actually I have close to the same wheel travel front and rear. My rear smoothies are custom length at 28.25" but the standard lower mount only gives it 9" stroke. Looking at moving the upper mounts up higher and adding some bump cans. I want more up travel for my speed addiction. No real rock crawling here in swamp land, so droop is not as crucial.
I still need 4:56s and a locker before any of this suspension gets worked on. Damndemic screwed my plans this year.
