Look what I ordered today!
You think I bought under-powered speakers for the amp that i bought.
Will this cause me problems?
Thanks again!
Lastly I was on the phone with crutchfield and they said the 6.5 for the rear that I got wont fit. Can I modify the speaker grille without cutting it?
Thanks again!
Those speakers will be overpowered for sure. That amp will put out at the minimum 75 RMS. It will probably be doing in the 80's or 90's to be honest because that's a good amp.
I don't think that there will be problems, but you will just have to check your gains and make sure you set them right.
I guess that the stock speakers in the '07 is the same as '98. They are like a 5 and a quarter or 5 and a half. I think that there is a baffle or something in there that you can take out or buy or something to make a 6 and a half fit. If you didn't want to do this I would just buy a smaller size.
If you have to cut the auctual grille part, I personlly wouln't do it. It would probably hurt your resell value if you didnt' do a good job.
JL is likely conservative in terms of the power its speakers can handle - like Clemson said, however, watch the gain and you'll be fine.
The stock speakers are 6.5 - although Crutchfield seems sure 6.5 can't fit in the rear, my installers got some 6.5 to fit without much problem.
By the way, this entire thread reminds me why I love this site so much - knowledgeable, helpful people willing and able to help!
Yeah. I meant to say that the speakers should be able to handle the amp.
Word!
Thanks guys!
Should be installing this next weekend. Just waiting for my HU. I put my iPhone on eBay to fund it LOL so that I could get it earlier. Also Ill prolly get the iPhone 2 next week when it comes out.
eskimochaos said:
Word!
Thanks guys!
In my opinion Blackberry > iPhone. :).
Depends on the user. I dont like the Blackberry interface. It just seems so rudimentary. On my cell phone, I like all the eyecandy. However, XP Pro all the way. **** vist!
Anyway little change of plans.
Because I really want things to go bump in the trunk.
I decided on getting these!
http://www.crutchfield.com/App/Product/Item/Main.aspx?search=pdx&i=500PDX1600
And 2 of these:
http://www.crutchfield.com/App/Product/Item/Main.aspx?search=alpine+type+r&i=500SWR1242
I should be able to wire them in parallel correct?
Now am I getting to the point where I need 2 batteries. I have no interest in running dual batteries.
Thanks again clemson!
The two w3's would be underpowered if you only ran 300 RMS to two of them.
The w3's and R's compare very favoribly to eachother. I personally own two type R's and love them. They are just right for what I want. I didn't have to upgrade the battery or change the altinator (sp?), yet people still know when I coming. Some people at school have said that they can hear me at the stop light, which is at least 100 yards away. That is with the volume half way too!
So I would say no to running two w3's off that one 5 channel amp.
I got my subs from ebay for a lot cheaper than that price.
I also got an amp to power both of them for half the cost of that one amp.
If you want the R's get a amp that puts out at least 1,000 RMS. I think the 12" R's could handle at least 600 RMS.
If you want a sealed box I'm not quite sure what size you should order. Maybe 1-1.5 cubes per woofer.
If you are going ported, which I did, I would get 2-2.5 cubes per woofer.
I'm just running one amp that is 1,100 at 2 ohms and 1600 watts at 1 ohm. I have the subs wired to 2 ohms.
I have not had to replace my battery yet, knock on wood. At night with the AC running I have no dimming.
I don't think that with running two amps and about 1,300 RMS you will have to get two batteries. You might need to upgrade that battery under the hood, but I think that would be all.
Alright. That PDX mono sub is 600RMS at 2 and 4ohms. If I wired the R's together they would each be receiving 600watts correct?
So that would be a theoretical total of 1200 watts right?
I plan on getting a set of them and the amp off ebay for half that price.
eskimochaos said:
OK I understand what your saying. How bout this setup.
2 of these...
http://www.crutchfield.com/App/Product/Item/Main.aspx?search=alpine+type+r&i=500SWR1222
and this amp
http://www.sonicelectronix.com/item_9552_Hifonics+TXi+1508D.html
now running the subs in parallel will create a 1ohm load correct?
meaning each sub will get 750watts of RMS power correct?
Two 4 ohm subs can be wired to 1 ohm and a 4 ohm load.
Two 2 ohm subs can be wired to a .5 ohm and 2 ohm load. You will not find very many cheap amps that will handle .5 ohms.
I would first pick out the amp and then pick out the subs that can be wired to get the most out of the amp.
Here is a link to how to wire you subs: http://www.the12volt.com/caraudio/woofer_configurations.asp
That amp is ok. I would say that the amp would really be putting out about 1,200 to 1,300 RMS at 1 ohm. That still isn't bad.
You might also want to check out Cadence amps.
Alright Clemson. Sorry for the run-around. Not good at making decisions that require a lot of $$. Anyway I decided on this setup. Got everything from eBay from reputable sellers w/ warranties and good history. (I'm a good ebayer LOL)
So here is everything I got!
4 Channel amp for speakers:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=280232015493&ssPageName=STRK:MEWN:IT&ih=018
Monoblock amp for 2 Alpine Type R's
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=280232734898&ssPageName=STRK:MEWN:IT&ih=018
Sub Box:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=190224578915&ssPageName=STRK:MEWN:IT&ih=009
Talked to someone who ordered from them and said it was great quality!
Front Components:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=250252152348&ssPageName=STRK:MEWN:IT&ih=015
Rear Coaxial:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=280231203454&ssPageName=STRK:MEWN:IT&ih=018
Dual Alpine Type R 12" 2ohm impedance to be wired in parallel for a 2ohm load:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=360058481875&ssPageName=STRK:MEWN:IT&ih=023
All in all, very happy. I am sure that 800RMS @400x2 will make the Type R's thump. I am sure it will be VERY audible LOL.
This amp wiring kit w/ 250A fuse:
http://www.knukonceptz.com/productDetail.cfm?prodID=KLM-AK0
This distribution box with 2 150A fuses. (Hope this is alright)
http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-12
And 3 sets of RCA's.
Going to get this HU when my iPhone sells:
http://cgi.ebay.com/KENWOOD-DDX512-...ryZ79834QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I dont need a 7" screen just want a touch screen with ability to add nav at a later date.
Just remembered I didnt get 4gauge power wire for amps.
You think I can get that at like Lowes or something.
I also plan on picking up some speaker wire there as well.
Anyway, to all that helped me, especially Clemson, I could have not have done it without you!
In the end, I am sorry I spent some extra $ for that 5 channel amp but oh-well. It has great reviews!
I plan on doing this install myself and will take pictures to log the entire thing.
Hopefully next weekend.
Now that my wallet is empty especially since I took out a "loan" from my dad and gas at $80 a tank, im gonna have to start to put some in the piggy bank.
Furthermore, I knew my buying habits and that the more I learned about car audio the more expensive shit I was going to buy. Its a real bad habit of mine; however, I do know how to save.
Anyway Im done ranting, cant wait to get this installed.
Thanks again to all those that helped me. I honestly could not have done it without you!
Sub Box:
Front Components:
Rear Coaxial:
Wow man! That list is impressive. This is what I want to eventually do to my car, but of course money is an issue.
Car audio gets to be VERY expensive.
I'm just going to comment on the products now:
With the wire for the amps I would go to a local car audio shop and buy it from them or try to find some welding cable. With the speaker wire make sure that is is big enough. Don't get like 18 gague.
I noticed that that distro is 1/0 in and 4 or 8 gauge out. This isn't a huge problem, but you will have to strip your wire down a little bit.
That HU looks nice. I think you will need a wiring harness.
The prefab box will work and I'm sure you will like it. It looks like it is solid quality and is at a good tuning. It is a little too small, in my opinion. You WILL be happy with it though. That's the size that I have right now. I want to upgrade, but don't want to pay for a new box. :).
You are getting one amp for both the subs? I don't think that you will really notice a difference with that amp compared to a 1,000 RMS amp. 200 RMS is not a huge difference. To be honest, both the Alpine amps are underrated. They are going to put out more than what is listed.
Of course your going top of the line with the wire from kunconceptz. Nice buy there too.
Just take your time with the install and double check everything. It is going to be super hard to wait for everything to arrive, but it will be WELL worth it. I'm kind envious of you right now, spending $1,773.93. Dang!!!
I suggest that while you are waiting you read up on how to install everything. Use caraudio and other websites to their advantage.
Once again nice buys. Your 4runner is going to sound awesome. How are you going to position your box? I heard that port back and subs up is the best way, but I don't think it really matters that much and I don't think you can do that with that box.
Make sure to take pictures and videos of before, during, and after.
If you have any more questions just ask. :).
spending $1,773.93
having not added it up that hit me like a ****ing hot chainsaw right through my heart.
just looking at the calendar and my remainder work...ill be able to put 2.2k in the bank. The parents wont be THAT pissed!
what year 4r do you have?
this is probably a silly question but to mount the sub just drill holes deep enough for the screws provided with the subs?
do I need to seal the box with anything?
ughāḍiyā
