Official Wheel Paint Thread
I'll play along...
So I'm getting ready to paint my LC rims, but was looking for some advice. Should I paint them before putting the tires on or after? I'd rather not have them get scratched and chipped when the tires get mounted, but it also is a lot easier to paint them without the tires on.
Also anyone have any suggestions for a drill mounted wire wheel to scuff up the paint?
Sc,
I would do it without the tires on cause you can get to the spots you can't reach once the tire is mounted.
For roughing up the paint, I ran an air compressor with an scour pads (3m ones). I did also use the drill with an metal cup wire brush but found out the air compressor way was better.
If you need an assistance or any questions, feel free to pm me.
Thanks Supra, I've done it with the tires and it's annoying. No air compressor for me, but I will try the scour pads and get a wire brush as well. Hopefully I can get the rims done this Sat and get the tires Sun.
Just painted mine too!
@SC
I just painted my rims this past weekend and had them off. I took them to lyods tire downtown santa cruz and they have a machine that wont touch the wheel as the tire goes on. They did a great job of installing them with no scratches. However there is some pressure that is put on the rim when the tire goes over it, but it did not take any paint off. I hand sanded allfour wheels with 400 grit wet sandpaper and some scuff pads. I was told that when sanding make sure to get all the shiny gloss off so that the paint will stick to it. I tried a drill but it was way too harsh on the wheel. Maybe a different bit would have worked better but i didnt experiment. Also , one tip i would give you would be to sand the lugnut wells good. I didnt and when i tightened my lugs the paint chipped off.
I painted 3 coats of self etch primer 3 coats of rustoleoum gray metallic, and 3 coats of clear.
Thanks Sierra, how much was your mount and balance at Lloyds? I think I will just do the same method as you as it worked good before.Thanks.
done!
updating my previous reply in this thread. painted my tundra wheels and i lov em. they were alot of work.
i hope they last for many years to come! thanks to all that have painted before me and posted pictures.
i am grateful!
summits
Oh wow! Speedy, quality service right there.
Thanks so much. I'm thinking black might be a little too dark due to the fact that the truck is silver with all the chrome, clear corners, etc.
Hyper silver looks really slick on her, IMO.
Don't know how I missed that one. I even posted in your thread. Do you have any close ups to see the texture? I think this will help with my rims.
