Phone holder solution without disrupting wireless charging capability
benjamin247
I'm looking for a good solution to mount my phone on my 3rd gen. I originally had a mount stuck on my windshield, but the heat melted the suction cup and left this nasty goo on my windshield. Anyone know of another way where I won't need to make any modifications to my phone since adding extra plates or covers interferes with wireless charging...
I just finished installing my new PanaVise inDash/RAM mounts combo. Love it. I sure you could put a wireless charging head on the RAM ball mount.
Sent from my SM-G965U1 using Tapatalk
I was playing with an idea of removing the clock putting a block of wood then bolting a mount. Then using the circuit for the clock and tapping in for wireless charging.
Just a FYI, slightly OT: Properly formulated suction cups, like those produced by Garmin or RAM mounts don't melt in the hot sun.
I went through several setups before ending up with an Anker wireless charger/phone holder (Amazon.com: Anker Wireless Charger, PowerWave 7.5 Car Charger with Air Vent Phone Holder, 7.5W for iPhone 11, 11 Pro, 11 Pro Max, 10W for Galaxy S10 S9 S8, Note 10 Note 9 (Quick Charge Car Charger Included): Home Audio & Theater $50) and a proclip center dash mount (Center Dash Mount | ProClip USA $30). The picture on the proclip website shows it covering the left vent, but I positioned mine to the right of the clock which covered the right vent for me but the passenger was still able to use it and I can still see the clock. I tried using the panavise side mount as pictured in jerbrun0515 posted but found it had a little too much vertical bounce to it for me. It was distracting for me when I had google maps up. The anker wireless charger is ball mounted so you can use it with any 17mm size ball if you want to use a RAM mount or something similar.
Here's another option to consider too: https://www.toyota-4runner.org/2690618-post41.html
The proclip mount looks promising. The instructions mention peeling off the cover of the adhesive. Does this use adhesive to stay on or is it just more like a clamp? I want to avoid sticking anything in case I want to change/remove it later on...
It's to prevent it from sliding left or right on the top edge of the trim piece. I left the cover on the tape while I tried out a few positions to see where I liked it best. You could probably leave the tape cover on indefinitely and it would be fine. I forgot to mention that I had to buy a 17mm ball from tackform (AMPS Mount | Metal | 17mm Ball - Tackform) to mount the anker phone charger on. Proclip has wireless chargers similar to the anker wireless charger. If I were to do it all over again I would get the proclip mount and a wireless phone charger holder from proclip as well. If you want I can take a picture of my setup.
I just picked up the Aukey Wireless Car Charger from amazon. Only thing I didn't like about it is that it attaches to the air vent but it attaches very securely and automatically closes when I put my phone in it and opens just by tapping the side.
[MENTION=386688]jerbrun0515[/MENTION] is correct. A wireless charger fits on the RAM mount perfectly. I've using one for a year or so now, and it's great!
This was my solution. Ram makes a mount that let's you wireless charge. It's a piece of 3/4 plywood shaped to fit, then construction adhesive into the hole. Then the two hole mount ram ball is epoxied and screwed in place.
Sent from my SM-G955U using Tapatalk
Do you know what the power is coming from the clock circuit? Haven't spent time to research it but if it was decent I wonder if fast charging could even work
I didn't use that power. What I did was I ran a fused hot wire into my charging ports so that they would be constant on instead of keyed, I use a small inverter to power a quick charger set up. So I just run my power up from there. My clock wires are still connected behind. Mine would randomly turn on while driving down the road, but never stayed on very long.
I just purchased this cd magnet mount. I hope it works well for me. I just got it in the mail and getting ready to use it.
SCOSCHE MPQ2CD MagicMount... Amazon.com: SCOSCHE MPQ2CD MagicMount Magnetic CD Slot Mount Holder Charger for Vehicles
Ahh okay. I had asked because from what I understand the clock circuit is usually fine its a spring within the clock itself that goes bad.
Clock shares the 15 amp dome fuse with a lot of other things for it's main power source. I wouldn't recommend tying into it for power for a fast charging power supply due to fast charging pulling 7-10 amps depending on the fast charger and phone.
seltzernator
