Post your LIFTED pix here!
New guy here from AZ... Just brought her home!
Bilsteins all the way around.
1.75" on front and OME 10mm spacers on the back. Also put on a 3/8" spacer on driver front and an additional 10mm on driver rear to account for the lean. I have a 0.75" rake after all said and done.
Sent from my HTC One M9 using Tapatalk
this might be a stupid question, but did you plastidip your fenders or is that a part that you added on? and if you plastidipped them, how's the durability been?
I do not have them plastidipped. That is how the 2010-2013 Trails come. Some people on here do paint or plastidip them though. I would assume that it holds up well.
Bilsteins 5100 (fronts at 1.75) and rear OME 2895e coils in the rear & 1 OME trim packer on the drivers side rear to compensate for the lean. In all honesty I would like to set the fronts to 2.5 because it looks a little "too raked" but I think I'll just leave it for now... Unless adjusting the front struts can be done easily without too much work.
Instagram @tcr_89 SR5P 4wd 3rd row - FN countersteer X - 265 KO2 - OME 2895E rear coils + Bilstein 5100 (1.75 setting) - gobi stealth - NFab side steps - TRS Morimoto 4300k HID - NOKYA yellow fogs & DRLs - AVS hood visor
Mine - still in the process of modifying the mud flaps, using a combination of trim and heat gun.
ICON Stage 2 suspension, Motometal 951B wheels (17 x 8), bridgestone ATK's 285/70/R17
The sliders are on order, but a 4-week lead time (Demello Hybrid bolt-on)
New and need a little help. I have a 2016 TForce. Basically a SR5 Premium 4x4. I would like to lift my truck. I dont need any thing vrazy as I live on the MS Coast and do light camping. What is a system I can go with for small lift?
My .2c is the bilstein [email protected] setting with toytec top plate spacer and for the rear toytec 2.0 coils. Very Mild lift mild price
I finally get to post in this thread with a picture. It was definitely harder than the old 95 bronco but finally got the billys and ome coils on.
Sent from my XT1254 using Tapatalk
