Come to MD- I'll cut -em! LOL
And i'll take pictures...
I'm thinking I may do this AFTER my warranty tho, since if something goes wrong with this NAV unit (another member here has already had it eat his cd's and not let them back out) I'd be in serious trouble.
Apparantly LOTS of wires go into making that camera function.But, the system still needs a trigger to turn it on, and my suspicion is it's that red wire (reverse sensing) in the gray plug. The switch at the shift mechanism sends a signal via this wire when you shift into reverse. So- basically I am thinking you need to "trick" the camera into thinking it's in reverse to turn it on. Isn't this fun? I love this stuff!!! Good Luck, wish I was there.
Ok, I think I will try it. This one doesn't even have the entune though, it is the "upgrade" from the entune with DVD nav and 7" screen. I will looke for the connector... and hopefully not break anything! :bash:
Looking at your 12v outlet mod now and the dash removal looks really easy!
I was a little worried cause I worked on a 4th gen a couple years back and the process was way more convoluted, involving taking apart the drivers side plastic under the steering wheel, etc.
Cool! Please share your findings :thumb3:I'll do it, just need to DL the wiring diagrams to make sure no other system uses the reverse sensing signal. (I'm guessing there are)
