"Rumble Strip" Transmission issue
Taking the rig in tomorrow afternoon to the dealer. 09 V6. Getting the shudder @25-30 mph under slight acceleration (under 2k rpm). Only happens on cold starts. Once I'm driving for a good while, it's gone and I can't replicate it. Warranty ends soon, so I want to get his checked out, along with some other things. Will report back.
Mine was oposite. Never did it cold, only warmed up. Curious what they find.
I have 100k on my 05 v8 but dont have the rumble strip issue. I am going to be doing a trans fluid change but was wondering if I should add the shudder fixx fluid for good measure?
The dealer did not find anything the two days they had it. This morning I tried and nothing. It looks like intermittent thing. If it happens again, which I'm sure it would, I'll add the SF.
Got an update, I've been following this...hope you have some good news.
I had the rumble strip issue, had the dealership do a full flush and fill and had them add the SF, it's been a while and still running strong. Nearly had me sh$t my pants when it first started, even got to the point where I was gonna sell it.
The rumble issue started again a few days after the dealer visit. I ended up putting SF and it has not happened since. I'm gonna do a fluid drain/fill by the end of the year because I have a road trip in December and I'm getting close to 100k miles. I'm glad everything worked out for you.
Just wanted throw my hat in the "shudder fixx fixed the issue" group. Really glad I came across this thread. Took about 40 miles of driving for it to fully take effect, but can't beat the results for $6.
How has everyone's truck held up after using it? Is this something I will continually have to use?
__
__
I don't know, but I have a spare tube on the shelf!
__
I'm still shudder free. Loving it. Great question. I plan on changing my ATF again in about 50K miles. I do plan on adding a tube just to be safe. I can't imagine hurting the tranny doing so. Can anyone chime in on this?
Anyone just put in Shudder Fixx without changing the fluid? Just curious.....
I guess you could, but why not change (or least a drain and fill) the ATF. This tranny isn't known to blow up after a fluid change.
236,000 and having this issue and some harsh shifting. I plan on having a drain and fill done (unfortunate part of living with a gravel driveway and a well pump head right next to it,) but once that's done I'd like to add shudder fixx - are people adding it through the fill plug hole or another way?
Is there a drain hole or do you have to drop the pan?
Like I mentioned before, there is a drain hole, but you can drop the pan. Not 100% sure, but dropping the pan will involve removing something else. I'll check back. If you drop the pan (and go through all the trouble, you can replace the "filter" (metal strainer). Also dropping the pan you can get more ATF out. Most use the drain hole.
Photos Courtesy: [MENTION=22558]CJ3Flyr[/MENTION]
DSCF0043.jpg~original
DSCF0045-1.jpg~original
Even if you do it through the lines, the amount of the antishudder is very small. I would think the only way is through the fill hole.
Sorry, how many quarts of new fluid will I need, and what type?
If only draining, I thought I saw 2-3 quarts. If you use the "line method", expect more (12 quarts). See pic:
Photo Courtesy: [MENTION=56345]thirstyturtle[/MENTION]
IMAG0325.jpg~original
Good thread on how to drain/fill tranny on 4th gen:
http://www.toyota-4runner.org/maint...ission-fluid-servicing-sealed-non-sealed.html
hope this helps!
[IMGhttp://i266.photobucket.com/albums/ii246/CJ3Flyr/DSCF0043.jpg[/IMG]
[IMGhttp://i266.photobucket.com/albums/ii246/CJ3Flyr/DSCF0045-1.jpg[/IMG]
[IMGhttp://i70.photobucket.com/albums/i113/ThirstyTurtle/IMAG0325.jpg[/IMG]
hope this helps!
Thanks for the pictures. Very helpful!
044runner4
