Solutions for FOB banging against dash?
4Runner4Leon
Senior Member
This may be a small nit, but with the key in the ignition, the FOB keeps banging against the hard plastic below. I'm thinking of adding a strip of foam or silicone to the dash to reduce the noise, but was wondering if anyone has a better suggestion. Another option could be to get a silicone FOB cover, but I couldn't find one for our FOBs.
Thoughts?
Well, the obvious would be to get rid of the chain, and keep the fob in your pocket. :pop2: :cheer2:
I thought about decoupling the FOB from the key, but that doubles the likelihood of losing or misplacing the key or the FOB :).
I also thought of some kind of a holster, but I hate to take on another project and I can't find a premade one.
The radio might be a solution :).
So far I think the best near term solution is to glue something soft to the dash - a bit lame, but effective.
Go to home depot in the door / window section. Get a roll of adhesive foam. Cut a small strip. Place there.
I would say you clip that chain off and use a normal size key ring. Or you could get real crazy with it and convert your ignition to a push button start and not have to worry about a key
SOB!!!! I'd get some velcro and stick that to that SOB FOB and also some on the dash underside and adhere it there while driving. Not at all bo jang...
Yup, that's along the lines of what I was envisioning, thanks! I rounded up some leftover adhesive weatherstrip foam in the workshop, so this is what I did for now. Not pretty (though not very visible to the driver, so who cares), and ahhh, the sounds of silence :). Maybe I should patent it :).
I can’t believe this is an actual topic: remove the long chain, use a simple key ring. Done.
That was the original configuration, the FOB still banged against the dash.
Now you're talking!
mmmmmmmmmmm OEM PARTS
bobdjr41
