Thanks Mike. I view the tank as a Jerry can basically. Depending upon the situation, it should add between 50 to 70 more miles of range... As far as how I plan to fill, well the photos I'm about to share will show that.
I wonder what that black line is in the bottom of the photo? Doesn't look factory with electrical tape securing it...
Ok, access to fill the tank and the storage area...
Four holes just big enough for the blade. I ultimately used the jigsaw again...
The opening is not quite 12" x 12". I filed all four sides so there are no sharp edges or points.
I reinstalled the plate and was pleasantly surprised that the 3rd bolt on the driver side went in beautifully. On the passenger side, the exhaust pipe has enough play to get the bolt in place, but the hole I made does not line-up. Drat. I can't use the rat tail file when it's installed because of the exhaust pipe, so I'll need to remove the plate, file, then re-install. A bit of a pain. Something for tomorrow or Saturday...
Time for the tank. As yesterday, I simply loosened the bolts a little and the tank squeezed into place.
The vented cap comes-off easily below the floor, so no need to trim a semicircle into the flooring to get it out.
I have maybe 3/16" space to slide the tank more forward, but the hole I made for the outlet is preventing such. So, that's on the list for tomorrow also. Minor, but having even a little bit more open space to get bags in and out could make a difference. I will then mark the holes for the mounting brackets. They looks to be about 3 1/2" center-to-center.
Then she'll be set for welding. Here are the four pieces that I want to have welded. This is the bottom.
[MENTION=271883]T4topher[/MENTION], is that something you'd feel comfortable doing? If not, no worries, I can use a local weldor on Monday before I fly to LA.
This came today and this is what I might ultimately use to transfer gas into the main tank, through its fill neck. I have another non-electrical solution coming in the next two days though (Fri and Sat deliveries).
A note from my oldest on the yard white brought a smile to my face.
I will start experimenting to see what size tool bags (fabric) I can get in/out of that opening. I think 8" wide max, up to 8" tall will work, with some decent length. I will try to fit various boxes and bags that i have to get an idea. I'm already compiling a list of onboard tools.
Yes, I will have a sealed cover for the opening, and while not yet determined, I have a couple ideas that I'm pondering... Since the storage area below the floor is quite open, I'm not overly concerned about fumes.
