URD 7th Injector spraying fuel into engine bay
Lamer
I have just installed my 7th injector and TRD supercharger and was very much excited to roll around town only to discover the 7th injector is spewing fuel into my engine bay.
shut it down immediately, and proceeded to check out the injector.
it was leaking where the screwdriver is pointing. badly. the whole black section can be slid in and out by hand, and it can rotate by hand quite easily. is there any advice out there?
You might get more replies on the Facebook group named “3.4 Supercharged (Toyota)”
Lots of people on there with experience with the 7th injector.
Contact URD. I bet there's an o-ring missing or something.
ended up taking it apart, and cleaning the sealing surfaces, nothing appeared damaged, so I reassembled, and its good to go. ill probably buy new 14mm orings (standard injector size as per URD Tech) and replace both of them for peace of mind.
erinobr2000
