(Video Comparison) XenonDepot XtremeHID + XtremeLED lights against Stock Bulbs
noticed getting flashed quite often on dark roads when oncoming cars are further away.
Did the lowbeam adjustment with a Philipps screwdriver. Will see how it goes.
I checked the alignment of my low beams when I installed the HIDs and was shocked at how high the halogen lights had been aimed. Evidence to me that the output of the stock lights really is so bad that Toyota has them aimed higher than they should be.
I purchased the HID for low beams and LED for high beam w/ DRL during the black friday sale and finally got them installed last weekend.
Huge difference, especially the HID. Can't believe how bright the HID are compared to the old ones.
My only issue is with the DRL LED flickering. Not very noticeable in the day and from far, but up close and in the dark it is noticeable. Should I have purchased the PWM to avoid the flickering?
[MENTION=12905]XenonDepot[/MENTION]
Yes, you may still notice some minor flickering up close or in the dark but the Daytime running lights are not meant to be used in the dark.
Danny
Danny
For those of us with OCD does the PWM option available on checkout help with the minor flickering?
Yes, the PWM module will fix the flickering issue but then the daytime running lights will be on at full brightness which defeats the purpose of getting the DRL LED Drivers instead of using the regular ones that come with the LED kit.
Danny
Crookedcat
