What's your EDC firearm? And Everything Gun related.
I carry a Ruger 380 LCP either IWB or on the ankle. I replaced the recoil springs on it (something I'd recommend) with heavier ones, which reduces recoil impulse and makes it easier to hang on to. I also have a Glock 42 that I carry on occasion as well. Looking to add a Glock 19 soon, more for target shooting than carry. I had a Glock 27 in 40, but that was my first handgun, and I couldn't shoot well with, so instead of practicing, I sold it. I thought it was a mite thick for a carry gun. Also had an XDS- they are great guns, if you like carrying a 45.
Anyone carry a sccy? Thinking about getting one
When I took my CCW class, a lady had just bought one to use to qualify (we have to load and fire 40 rounds in MO) and she was unable to either rack the slide or pull the trigger, they were both so rough. A buddy of mine shot a magazine through it, and he was able to shoot it with some accuracy, so if you have some patience and hand strength, it might not be a bad gun. Definitely not one to give to the wife though. I believe you get what you pay for with guns for the most part, and Ruger and S&W both have similar options for about $100 more. I'd be inclined to stick with what I know is quality. Just my .02.
Sent from West Virginia
Ruger LCP here as well, always IWB. Philly can be a weird place at night...
what force springs did you get? I never thought to replace them to help out with that kickback. luckily i have small man hands, but she still packs a punch. thanks.
Glock 19
SAI threaded barrel
Gold plated Extended takedown / mag / slide release and pins.
Dove tail
Sure fire X400U
It's not my edc, just sharing.
What force springs did you get? I never thought to replace them to help out with that kickback. luckily i have small man hands, but she still packs a punch. thanks.[/QUOTE]
The 13 lb set here I used I bought here:
https://www.gunsprings.com/Semi-Auto Pistols/RUGER/LCP .380/cID1/mID52/dID422
Midway usa also carries them.
They ship with 9lb springs, so it does make it slightly more difficult to rack the slide. I noticed a significant reduction in Muzzle flip, and a reduction in follow up shot time. And let's face it - with a 380, you are most likely going to have to shoot more than once to stop the threat. I also read that due to poor design, after about 250 rounds, the recoil springs wear out and should be replaced for reliability puposes. My gun had 500+ rounds through it, and the old springs were shot, so that may have been part of the reason for the vast improvement. Hope that helps!
Sent from my SM-G900R4 using Tapatalk
thanks, i figured going full 13lb wasn't too bad.
well shit. i shoot mine regularly, probably have well over 700 rounds through it and i haven't noticed an issue. perhaps i'll replace and see what i feel. good to know. thanks again.
Not a problem. If it was any other gun, I wouldn't worry about replacing them until they hindered function, but if it's your EDC, it's probably worth the 15 bucks or so to know that it will go bang when it matters. Plus it's super easy to change out. I could tell my old springs were a little mangled on the ends when I pulled them out. Best of luck, and I hope you never have to use it!
Got my alien gear pro tuc today honestly first impression I didn't like it. I'm not use to this large of a holster but made myself wear all day we'll still on now and I have to admit after 5mins forgot it's on my side. Day one will give you updates as go along.
We'll be changing belt clips to the c-clip
Duty Carry: Glock 22 gen3 (department issue - not pictured)
Backup (soon-to-be - not pictured): Glock 43
Depending on the weather/clothing:
Kahr P380 in .380ACP (soon-to-be - not pictured)
(1) Sig Sauer P225-A1 Two-Tone in 9mm
(2) Sig Sauer P229R in .357Sig (former duty firearm)
(3) Sig Sauer SP2022 Two-Tone in 9mm (only sometimes)
(4) My leather holster for my P229R (w/ my old P229R before I sold it)
(5) My duty belt set-up (when I carried my P229R)
(6) My badge. :thumb3:
Noveske Gen2 Full flare lower
Noveske monolythic upper receiver (rebranded VIS-2)
14.5 pinned Noveske Barrel
Magpul UBR STock
Magpul MIAD Grip
Magpul BAD lever
Wilson TTU Trigger
BAD ASS Short throw safety
Spikes Nickel boron BCG
Rainier Raptor Charging handle
Magpul OD MBUS Sights
Eotech 552 Holo sight
Primary Arms LER magnifier
Elzetta Flashilight.
