5-Speed Swap Wiring Diagram
'98 has very different wiring through the whole chassis from a '00. Unless you are changing the rest of the chassis wiring, you do not want to put a '98 engine/trans harness in your '00. (to be clear, the engine/trans wiring and connectors are VERY similar - it is the chassis connections that totally change)
You should use the '98 harness as a 'donor' for the trans connectors you need and find a 99/00 MT ECU to run the engine.
-Charlie
good to see you're still on here spreading your wealth of knowledge.. im glad we got to feature your rear axle seal/bearing job on our YouTube channel!!!
tobasko556
