ChildrenOfBodom
Moderator
Welcome to ChildrenOfBodom's 4Runner Timeline. This thread covers my 1999 4Runner from day 1. They say pictures say a thousand words. In this thread, you'll find thousands of pictures.
This was the first vehicle I ever paid for with my own money. I bought it in 2008, 4 days after my 17th birthday.
This truck started life as a 1999 4Runner base model. It came with a naturally aspirated 4 cylinder 3RZ-FE, two wheel drive, and automatic transmission.
Today, the truck most closely resembles a 1999 Highlander Edition, sporting a TRD Supercharger on the same 3RZ-FE, four wheel drive, and R150F 5-speed manual transmission.
CASTROL EDGE: UNLOCK YOUR PERFORMANCE WINNER #1: AUGUST 2010
T4R.ORG TOYOTA 4RUNNER OF THE MONTH: MARCH 2012
4WD TOYOTA OWNERS MAGAZINE PG. 8-14: SEPT 2012
My YouTube Videos
Why I Built Instead of Selling
Why You Should Avoid Purchasing Magnaflow Products
Other Rides:
COB's '87 4Runner Turbo SR5
COB's '90 4Runner SR5 V6 2-Door
COB's '98 4Runner SR5 4WD
COB's '99 4Runner Limited 2WD
COB's '89 Supra Turbo
COB's '94 Supra Turbo
COB's '89 Pickup Deluxe 2WD
Sold:
COB's 02 Ford Mustang GT
COB's '89 Ford Probe GT
R.I.P. (Rest in Pieces) :sadwave:
Donor Truck 1.0 (2000 SR5 4WD 5-speed)
Donor Truck 2.0 (1988 Pickup X-tra Cab 4x4)
Donor Truck 3.0 (2000 SR5 4WD 5-speed)
Donor Supra 1.0 (1989 N/A Hardtop Automatic)
89 Supra Turbo
94 Supra Turbo
For Chapter Selection, please continue scrolling beyond the modification list.
Basic information:
Original:
1999 Toyota 4Runner Base Model
2.7L 3RZ-FE 4 Cylinder
A340E 2WD Automatic Transmission
3.91 Final Drive Gears
Current:
1999 Toyota 4Runner 4WD, SR5 Highlander lookalike
2.7L 3RZ-FE 4 Cylinder, TRD Supercharged @ 8 PSI
R150F 4WD Manual Transmission with J-Shifter transfer case
4.56 Final Drive Gears with Factory Electronic Differential Lock
Modification List
ENGINE
OEM Additions:
330cc Supra 2JZ Fuel Injectors
TRD Billet Oil Cap
Aftermarket:
MAP ECU2 Piggyback Computer
Walbro 190 LPH Fuel Pump
NGK Iridium Spark Plugs
NGK Spark Plug Wires
Koyorad Full Aluminum Radiator
INTAKE + FORCED INDUCTION
OEM Additions:
3RZ TRD/Alpine Supercharger
Aftermarket:
K&N FIPK Cold Air Intake (57-9012)
Black K&N Drycharger
8 PSI Pulley Boys Supercharger Pulley
EXHAUST
OEM Additions:
TRD Catback Piping (PTR06-89990-14)
Aftermarket:
LC Engineering 3RZ Street Header
LC Engineering 17.5"x2.5" Catalytic Converter (CARB Legal)
2.5" Flex Pipe
Spintech Truck/RV Muffler
DRIVETRAIN
OEM Additions:
4.56 Front Differential
R150F 5 Speed Manual Transmission
AISIN Clutch Master + Slave Cylinder + Lines
2TR-FE to R155 Bell Housing
Electronic Rear Differential Locker
Aftermarket:
Toytec 1" Diff Drop
Rear Differential Breather Extension
DOM Rear Driveshaft
Marlin Crawler Clutch + Flywheel
Marlin Crawler HD Shifter Seat/Socket Bushings
NAPA CV Axles
BRAKES
OEM Additions:
Red 13WL Tundra 231mm Brake Calipers
Tundra Brake Pads
Aftermarket:
Brembo Tundra Rotors, Blank
SUSPENSION, STEERING, AND BODY LIFT
Aftermarket:
Old Man Emu 883 Front Springs
Bilstein 5100 Front Shocks
Old Man Emu 891 Rear Springs
Bilstein 5100 Rear Shocks
Old Man Emu 10mm Rear Trim Spacers (2)
1" Toytec Body Lift
Energy Suspension Polyurethane Sway Bar + End Link Bushings
Energy Suspension Polyurethane Steering Rack Bushings
Energy Suspension Polyurethane Front Control Arm Bushings
Energy Suspension Polyurethane Trailing Arm and Link Bushings
Energy Suspension Polyurethane Body Mounts
Energy Suspension Polyurethane Shock Bushings
Energy Suspension Polyurethane Bump Stops
WHEEL + TIRE
OEM Additions:
TRD 17" Wheels - Matte Gray
Aftermarket:
BF Goodrich All Terrain T/A KO2 - 285/70/17 Load C
4 1.25" Spidertrax Wheel Spacers
ARMOR + OFF ROAD
Aftermarket:
Shrockworks Front Bumper with Single Hoop
CBI Offroad Standard Rear Plate Bumper
4xInnovations HREW Rock Sliders with Kickout
Skid Row Offroad Front Skid Plate
Lotus Trailing Arm Mount Skids
EXTERIOR LIGHTING
OEM Additions:
JDM LED 3rd Brake Light
JDM Clear Corners
Aftermarket:
Philips Headlight Bulbs 55W/65W
TYC Headlights
Bosch Turn Signals
Eagle Eyes LED Tail Lights
PIAA 510 4" Ion Crystal Fog Lights (In bumper)
PIAA 580 7" Extreme White Driving Lights (On top of bumper)
ELECTRICAL
OEM Additions:
Towing Harness (4-Flat)
Aftermarket:
LC Engineering High Output Alternator
Power Outlet Relay Bypass
Fiamm/Bosch Horns
1/0 Gauge Battery Cables
Driffter CB Antenna Mount
FireStik Heavy Duty CB Antenna Spring
FireStik CB Antenna Quick Disconnect K-1A
FireStik II Black 4ft. CB Antenna
Blue Sea Fuse Block
MJT Fuse Block Holder
EXTERIOR
OEM Additions:
SR5 "Skinny" Fender Flares
Imperial Jade Grille, 2001-02
Imperial Jade Side View Mirrors, 2001-02
Imperial Jade Mica Door Handles
Sport Hood with Scoop
JDM Rear Spoiler
Black Pearl Emblems
TRD "Supercharged" Decal (Pt.# PTR26-35000)
Aftermarket:
Full Length Roof Rack
INTERIOR
OEM Additions:
SR5 Sun Visors with mirror
SR5 Cloth Front Buckets and Rear Bench
SR5 Leather Steering Wheel
Rear Cargo Area Panels (Cargo Cover Compatible)
Cargo Cover Mount Brackets
Oak Cargo Cover with Headrest Flaps
Manual Brake and Clutch Pedals
Clutch Pedal Linear Spring Mod
Gauge Cluster Bezel (PRND2L Delete)
Center Dash Bezel (ECT PWR Button Delete)
Manual Shifter Boot Bezel
TRD Leather Shift Knob
2000 SR5 Sport Seats
2000 SR5 Door Panels
Aftermarket:
Broadway Wide Rear View Mirror
Stainless Steel Air Conditioning Vent Knobs
Leather Shift Boot
Dash Designs Dash Cover
CB Microphone Mount
Paranoid Fab Single DIN Carling Switch Panel
INTERIOR LIGHTING
Aftermarket:
#24 White LEDs for Gauge Cluster
#74 White LEDs for Climate Control, Key Ring, Ashtray, Blinkers, and Glovebox
Neo-Wedge LED's for Rear Window, ECT/Rear Defrost, and A/C Button
Oznium Superflux Warm White 25 LED Dome Lights and Map Lights
Red Clock
INTERIOR ELECTRICAL
OEM Additions:
Automatic Disconnecting Differential Relay (wiring from 2000 SR5 4WD "Donor Truck 1.0")
4WD ECU for Diff Lock Functions (wiring from 2000 SR5 4WD "Donor Truck 3.0")
Gray Wire Mod
RR Diff Lock Button
Clutch Start Cancel Button
SR5 Door Harnesses for Heated Mirrors
Rocker Switches for fog/driving lights
Turn Signal Stalk with fog switch
TRD Boost Gauge
Aftermarket:
Viper 791XV 2-Way Alarm
Scangauge II
Cobra 19 DX IV CB Radio
Autometer A-Pillar Boost Gauge Pod
Constant Power Outlet Mod
OTRATTW Auxiliary Light Switches
SOUND SYSTEM
OEM Additions:
Mirror Pods for Tweeters
Tweeters
Power Antenna Mast
Aftermarket:
Kenwood KDC-BT778HD w/ Bluetooth
JL Audio 12" Subwoofer
Diamond Audio Technologies M5 Series Front Speakers
Volfenhag 800W 2 Channel Subwoofer Amp
Alpine 4 Channel Speaker Amp
OTRATTW Antenna Switch
My YouTube Videos
Other Rides:
Sold:
89 Supra Turbo
94 Supra Turbo
Basic information:
Original:
Current:
Modification List
ENGINE
OEM Additions:
TRD Billet Oil Cap
Aftermarket:
OEM Additions:
Aftermarket:
EXHAUST
OEM Additions:
Aftermarket:
2.5" Flex Pipe
DRIVETRAIN
OEM Additions:
Aftermarket:
Toytec 1" Diff Drop
DOM Rear Driveshaft
NAPA CV Axles
BRAKES
OEM Additions:
Tundra Brake Pads
Aftermarket:
Aftermarket:
1" Toytec Body Lift
WHEEL + TIRE
OEM Additions:
Aftermarket:
ARMOR + OFF ROAD
Aftermarket:
EXTERIOR LIGHTING
OEM Additions:
JDM Clear Corners
Aftermarket:
TYC Headlights
Bosch Turn Signals
ELECTRICAL
OEM Additions:
Aftermarket:
Fiamm/Bosch Horns
Blue Sea Fuse Block
EXTERIOR
OEM Additions:
JDM Rear Spoiler
Black Pearl Emblems
Aftermarket:
INTERIOR
OEM Additions:
Aftermarket:
Leather Shift Boot
CB Microphone Mount
INTERIOR LIGHTING
Aftermarket:
Red Clock
INTERIOR ELECTRICAL
OEM Additions:
Gray Wire Mod
RR Diff Lock Button
TRD Boost Gauge
Aftermarket:
Scangauge II
SOUND SYSTEM
OEM Additions:
Tweeters
Power Antenna Mast
Aftermarket:
