ChildrenOfBodom
Moderator
I'm in the midst of restoring a 1994 Supra turbo, and the 4Runner needs some love. The Supra is going to be the same color as the 4Runner, Imperial Jade Mica.
A woman driving a 2017 Highlander merged into my lane on a dual turn. This is the aftermath, her right quarter panel VS the shrockworks.
The rear end bushings are completely trashed, and Energy Suspension makes a rear control arm bushing kit # 8.3133R with 3 piece bushings. They're supposed to really be good at flexing.
I installed the bushings into an extra set of arms I had from my last parts truck. The reason I am using these, other than not having to take my truck apart, is because these arms are perfectly scratch and bend free, plus the uppers are slight shorter for 4WD models (I'm still running the 2WD upper links after all these years)
Upper link bushings burned and pushed out:
Uppers installed by hand.
The lowers going together with help from a fancy new harbor freight 20 ton press.
Ready to install.
If you have any issues with your rear bushings, there is no better way. The truck is SOLID with these things! Next up, panhard bar. Also replaced the dipstick (I broke the handle off), but I didn't get pictures. I will get pics next oil change.
Ready to install.
