COB's 87 4Runner Turbo
Very small list of things left before smog:
  1. Install cat/catback from 3rd gen (temporary smog purposes only)
  2. Bleed brakes
Yesterday:
  1. Tracked down a coolant leak to the turbo coolant line (water pump side) seeping very lightly, tightened clamp.
  2. Tightened up the valve cover which was oddly loose and seeping some oil down the block
  3. Ran the wideband wiring through the cab and connected to oxygen sensor. Felt painful poking through that nice clean grommet.
  4. Adjusted idle (warm) to 750RPM. Properly cycles between open/closed loop.
Later today I will wire the wideband to power and make a temporary place to mount, for now it will be loose until I can get an A pillar gauge pod/boost gauge.
This is 100% fully warmed up idle temp. This is after letting it warm up, going for about 2 miles worth of driving, and then idle for about 5 minutes. The aluminum radiator keeps temps down very nicely.
null_zps3f932768 by cobblewagen, on Flickr
null_zps940cc6db by cobblewagen, on Flickr
A couple pics while it was out of the garage. I love looking at this truck! In stock shape, it's more aesthetically pleasing than it's plastic, huge-bodied 5th gen younger brother. 3rd gen + 1st gen = best gens. Now I just gotta get to finishing painting the plastic trim pieces (rear bumper ends, rear wheel well things, mirrors, and window frames)
null_zpsa7a24b0d by cobblewagen, on Flickr
null_zpsf459fe65 by cobblewagen, on Flickr
Wideband. No pillar pods yet.
null_zps5ea30994 by cobblewagen, on Flickr
null_zps9561990e by cobblewagen, on Flickr
Turbo 4Runners come with a dual diaphragm booster from the factory... lucky me. Scored this brand new OEM 1 1/16" master for $26!!
null_zps81fe4d44 by cobblewagen, on Flickr
null_zps0f00a5f9 by cobblewagen, on Flickr
Powerstop Rotors/Pads (2nd gen V6 upgrade) EDIT: They sent the wrong ones! See future posts.
null_zpsdd1a989f by cobblewagen, on Flickr
f7f3d477-ed8f-4a82-9f23-54991cad9f92_zps1789c219 by cobblewagen, on Flickr
S13WB calipers also pictured. Going to paint them red. Also going to refinish the manual hubs while they're off
null_zps4531a899 by cobblewagen, on Flickr
Hi COB. Looking good as always.
A few questions though: Why she had to be towed both ways? And why you didn't let the folks at the muffler shop deal with the rest of the piping? Still gonna use the old one?
Cheers from Brazil,
Gustavo.
Cheers from Brazil,
Gustavo.
Thanks!
The truck had terrible brakes, and is registered non operational, meaning a $1,000 fine and automatic impound if it gets pulled over. Towing was the safest option.
The rest of the piping will come after the brakes. Just need more money and time.
Progress is looking good! I'm glad you held on to it and didn't sell it.
It does make me a little sad though looking through the build... :moping:
Thanks Jeremiah! Sure wish I had the resources you did for your build, I'm glad you like it.
Sad? I can bring it over and you can re-enact some of the awesome fab work you did :P Haha I'm so down for a road trip once this thing is going strong.
He did sell it! He sold it to me, he just doesn't know it yet... :nod:
I have no doubt that you would make it one of the sickest 1st gens around. Who knows, maybe one day the urge for a Supra might get to me.
Mmmm Supra...
Finally received my 54mm socket. Huge is the only way to describe this thing. Only things left to order are front wheel bearings, inner and outer races, and a wheel bearing packer.
null_zps80f1c8ad by cobblewagen, on Flickr
null_zpsbdf7580d by cobblewagen, on Flickr
null_zpse0d0a0bf by cobblewagen, on Flickr
The pile! Soon :)
Left to right: Rear shocks, brake master and caliper clips, brake pads, rotors, 100 pack gloves, brake fluid (DOT 4), brake cleaner, energy suspension sway bar bushings, wheel bearing grease, lock ring pliers, VHT ceramic coating (silver), VHT red caliper paint, S13WB calipers, 54mm socket, front shocks, and steering stabilizer.
null_zpsdd5b24c2 by cobblewagen, on Flickr
The pile! Soon :)
Nice i did the same thing last year. Except i also replace the TRE's, control arm bushings, etc.
I used this packing tool, decent price, fast shipping, works great EZ Squeeze Bearing Packers | Original E-Z Squeeze Bearing Packer Tool | A to Z Tool
You might also want to replace this seal
http://www.rockauto.com/catalog/moreinfo.php?pk=498822&cc=1272248 they are $10 each from rockauto and from toyota they are $100+. (they are the main seal that keeps water/debris out of the hub). (you need 2 total).
More Information for BECK/ARNLEY 0523487 they are $10 each from rockauto and from toyota they are $100+. (they are the main seal that keeps water/debris out of the hub). (you need 2 total).
Thanks for the links! That's the packer tool I was looking at, someone was recommending it in a YouTube video. I'll have to pick one up. I made the order for the bearings today and got the seals as well.
man i'm crazy jealous of your find, i love the turbo runners! those digital guages are frekin cool! :fro:
I agree, 80's retro electronic clusters are just awesome. Haha so you can see why I couldn't say no to buying it, thanks for the comments man.
Ordered Timken front wheel bearings, races, and 2 wheel seals. Just under $80 for everything.
Duralast FA5040 idler arm and 4Crawler bronze bushings coming their way, too. Also about $80 worth.
Had a little time to mess with it, figured I'd take off one side since I have the socket. The hardest part was getting the cone spacers to pop out. There was also a lot of silicone all over them, too.
Overall, it's not bad in there (to my surprise). Gotta do some extra cleaning and repainting before it all goes back together, it'll look pretty good.
null_zps9c29b69c by cobblewagen, on Flickr
Take note of the nasty brake caliper.
null_zps935e0ec4 by cobblewagen, on Flickr
Hub coming apart. Those cone spacers were pretty annoying. I wanted to use the air hammer, but it was far too late to use the compressor.null_zps5aa12056 by cobblewagen, on Flickr
null_zps80393f3e by cobblewagen, on Flickr
null_zpsb067b2dd by cobblewagen, on Flickr
There was a black widow living in there, he ran into one of the vents in the rotor and I never saw him again :spider:
null_zps631bcdd0 by cobblewagen, on Flickr
That was a good time to find something else to do
Good progress. I've found a small propane torch to be a good solution to a black widow problem. I hate those suckers.
null_zpsf2cdffc5 by cobblewagen, on Flickr
Going without the dust shields. They came off on the 3rd gen and I never looked back. Cleaned a ton of build up: bugs, webs, dirt, grime, etc.
null_zps5375d74a by cobblewagen, on Flickr
Basically the whole truck looks pretty darn good underneath all of the dirt. The lower shock bushing was completely shifted away from the little metal tube that once ran through it.
null_zps05cef292 by cobblewagen, on Flickr
null_zpsa5c15c82 by cobblewagen, on Flickr
Comparison to the other side, that's how the other control arm looked before cleaning it
E8D6B99D-D2C8-45DA-86DF-5A9B22734074-24010-00000E08ED2179DF_ by cobblewagen, on Flickr
Bearing races are next. I've also gotta get the other side off and torn apart. The new bearings and races haven't come in the mail yet so there's time.
null_zps8efcd8c0 by cobblewagen, on Flickr
null_zps56433a55 by cobblewagen, on Flickr
Haven't really been on much lately. Good to see you're keeping it! I'd love to have a fully stock 1st gen. Hard to find these days. They're all lifted on 35's.
GTA V came out... it was hard to pull away.
Dash cover. Misplaced my velcro for the time being, will update with an installed pic
null_zps46f5a85a by cobblewagen, on Flickr
Parts that came in:
Wheel bearings, races, and wheel seals
null_zpsd6e03223 by cobblewagen, on Flickr
Locking hub seals
null_zps0db5c0d3 by cobblewagen, on Flickr
Duralast FA5040 Idler arm
null_zps10297898 by cobblewagen, on Flickr
4Crawler bronze idler arm bushings
null_zps128d85ed by cobblewagen, on Flickr
Anyway I did some stuff today
Other side apart. Before cleanup.
null_zpscdb23dea by cobblewagen, on Flickr
null_zps616ee7d3 by cobblewagen, on Flickr
null_zpsb75bac42 by cobblewagen, on Flickr
Dirt cleaned up:
null_zps0a94288d by cobblewagen, on Flickr
Hub clean and disassembled, races removed.
null_zps19c0392f by cobblewagen, on Flickr
Talyn
