DIY: Interior LED swap (cluster, HVAC, switches, window, *steering wheel)
Thanks for the quick response!
Dingulus, Here is a list of what lights/LEDs you'll need, along with links.
9 of the NEO-3 bulbs (3mm): NeoWedge series LED Lamp Specifications
3 of the NEO-5 bulbs (5mm): NeoWedge series LED Lamp Specifications
About 25-30 of the PLCC-2 LEDs (depending on how many LEDs on your gauges you want to switch): Surface Mount PLCC-2 SMT LEDs
If there is anything else I/we can help you with, don't be afraid to ask!
Alex
Alex -
Thanks very much for the quick response!
Rob
P.S. Darkie, noticed you’re a boarder. Me too (well, I have a 6 month old now so not lately) but I can probably hook you up with lodging if you ever get out here to Vail. … not that we have much snow this year yet.
emelianenkov was able to answer your questions so no need for me to repeat anything. I love snowboarding. I head to Colorado and Utah every season. Unfortunately, I'm out this year due to full knee reconstruction surgery. Vail is my favorite in CO so I might take you up on your offer next season. :cheers:
Kevin
Kevin
I live in Boston. We. Don't. Have. Snow!!!! My board is so lonely sitting in the garage. So depressing :(
You want to hear something depressing...This is what is happening around me while I'm unable to snowboard:
Stevens Pass - 16" over past 48 hours - 99" base
Mt Baker - 95" over the past 10 days - 181" base
Mt Bachelor - 100" over the past 7 days - 114" base
Whistler - 41" over the past 7 days - 98" base
You poor poor poor poor soul! Here's to your healed knee and good snow next year! :cheers:
You're welcome when you're ready - let me know! May check out the X-games later today but the crowd's a little too 'radster' for me. I'm sort of an old fogey traditionalist after living here 20 years... Of course, now it's dumping in Vail:
11 "28 cms
NEW SNOW
Last 24 hrs: 11 " 28 cms
Last 48 hrs: 11 " 28 cms
Last 7 days: 30" 76 cms
SNOW CONDITIONS
Powder
Base Total 137" 348 cms
Good luck with the knee rehab!
11 "28 cms
NEW SNOW
SNOW CONDITIONS
Powder
I would give anything to trade the mostly-snowless, icy, rainy and muddy New England skiing conditions for the abundance of powdery amazingness out west. This winter freakin sucks! I'm sure being out for the season with a healing knee is much worse though. My condolences, Darkie.
Neo bulb question Alex...
Seems there are 2 options:
1. NEOx-x: NEOx LED Instrument bulb
2. NEOx-xHP: NEOx High Power LED Instrument bulb
You know I want bright - esp with the LCD - but I also want to minimize hotspots. So do you think option 1? ...or highpower 6 lumen, option 2?
Thanks again!
Thanks again!
Well, I went the blue route for my lights, and I really have no issues with the regular powered ones. Now that being said, I think that the white LEDs are slightly underpowered in almost all of their applications. I would suggest that you try the high powered ones, but my only concern is I've heard that The high powered lights don't even light up when they're put in the hvac because of some power draw issue. Might as well try em though!
So if I'm going for the white look but blue needles , high powered white ones for the gauges but low powered ones for the HVAC ?
No, use the regular plcc-2 white and blue leds for the gauges, and you can use the regular-powered NEO-3/NEO-5's. It really won't make a difference. No need to complicate your build!
Alex - thanks again. Ordered.
...now let's see what sort of damage I can do next week!
Have a good one.
I just ordered the cluster gauge LED's and the others for the HVAC and buttons.
Which ones of the LED's are for the buttons - power window switch, DAC, rear window defrost, rear window power and gear selection leds beside the shifter?
The NEO's are for the hvac etc. You didn't buy anything for the window switch. I didn't change that bulb yet. It's a different kind of led that I think darkie could help you with better.
Power window switch LED should be a 3mm. you can buy them individually at any electronics store or online in bulk.
Factory:
window-img4.jpg~original
Replaced:
window-img5.jpg~original
Factory:
Replaced:
Wait, Silver, did you mean the REAR window switch or the SIDE window switch? You need a few more NEO-5's for the light for the REAR window switch, BUT I recommend Darkie's work for the switches in the cabin (DAC, Diff Lock, 4wd switch)
ghengiskhan
