Thanks to Darkie for getting them installed for me! Car looks like sex from the inside out.
I started out by changing out the HVAC control LEDs and LCD screen LEDs. The HVAC controls worked fine, the LCD screen Neo LEDs wouldn't work. Flipped them around, no luck. Put the OEM ones in and they light up as soon as they hit the circuit board. Sigh..
have you tested the LED's to make sure they actually work? You might just have some bad LED's or the leads on the holder might not be making contact. Otherwise, check if the voltage from the HVAC is 12V.
Decided to switch to blue interior lighting because my HU has blue, and I can't (and wouldn't want to) change the lighting inside of the Pioneer HU. I have to say, I really love the blue LEDs compared to the Snooki-Orange crap that Toyota forced on us poor bas****s. I only got around to doing the HVAC tonight, I need to order LEDs for the rear window switch and the 4WD selector soon.
Here's what I've got so far! Also, thanks to Darkie and everyone else for the tips and tricks for this mod.![]()
So since my voltage is 6V, is there any way to make it work?
Finished up the dash Saturday night into Sunday morning (finished at 4:30 AM,
including te extra hour from setting the clocks back). I messed up with the
tach, accidentally putting in a white LED, but I like the mistake! It fades from
white to blue as the RPMs increase. From now on, I'm gonna say I meant to do
that haha.
But the dash gauges is a different story I did not solder mine I did a little trick with the flat 505 LED's so I can easily pull out the blue and put it back top factory in just a few min's.
They come with a sticky tape backing what I did is stick them over the factory lights (others have posted the pic's of them) the factory is so small and I just don't trust myself to do that kind of soldering. So I used about 6 LED's, they are prewired, with a resistor. So I ran the wires out of the case, put it all back together and then put a inline fuse on and wired it to the dimmer switch. So the factory lights are still on and working they are just covered up to block out the amber color it's much brighter than factory. I also used these same lights for the cup holder. I think I must of added about 40 lights and could put another 10 in. I'm pretty happy with the way the dash gauges have turned out its been a few months and still working great!
Also.. anyone know if it would be possible to fit a potentiometer in somewhere to control the voltage for the LED's? Guess it would depend on the LED's being dimmable, but it would be nice to have the option.
Would anyone here happen to know a part number or a place where I can get the steering wheel radio controls? I was replacing the LEDs on the steering wheel control yesterday and I held the soldering iron on too long for one of the lights. I fried the board.
Any info would be greatly appreciated! And if someone doesn't have a tremor in their hands and wouldn't mind soldering 3 LEDs on that tiny board... Let me know!
Those tremors didn't stop you from doing the cluster :bigok: Can't help you with the part number though
