Dual Battery - a la Bulldog
tlflow
I copied most of this idea from Bulldog (thanks) on the other forum. I adapted it a little bit by ripping off mace. (thanks too) I really like the WiredWagon power distribution box, he used on his lights, so I added that.
It was a little like a puzzle trying to use all the existing holes to keep from drilling (had to drill one hole).
I took these crappy cell phone pics so Antman would know what he is looking at. (no I have not hooked anything up the the relay box ... yet).
there are more crappy cell phone pics here:
http://s977.photobucket.com/albums/ae254/tlflow/dual battery setup/
Nice clean install. Just wondering why decided to put the battery back there instead of in front which seems like the logical spot.
With the bumper and winch I have a lot of weight up front already, so keeping behind the front axle helps a little bit.
I thought about mounting in the front (a long time). Harper made a nice mounting bracket for that location. There is a aussy that has a really nice kit (he's very proud of it too).
There are a lot of FJ guys that mount the second one in this location (Dirty Larry makes a kit). Bulldog did this on his rig. More I thought about it more I liked it. Required a little more work.
Nice work. When you mounted the relay box, did you're screws/bolts come through the wheel well? I used short sheet metal screws and they are visible in the well. I put a huge glop of silicone on them. Is that enough to keep it from rusting or should I clean it off and use something else?
I went to ace hardware and got some stainless bolts/washers (like $2) and use blue lock-tite on them. What you did will work for a good while, but will eventually rust. I would not sweat it though probably good for a couple of years at least.
That is a sweet relay box and switches, glad you posted it up! !
Daniel Frost
