Formidable 2008 V8 Nautical Blue Metallic Limited Edition URD Build
Thanks for the kind words.
Just to clarify, the URD Y pipe does not require an O2 sensor sim or spacer. The Doug Thorley long tube headers will require an O2 sim or spacer.
URD sells an O2 sim for the 4.0 and a universal one for the 4.7L:
URD Rear Sensor Simulator UNIVERSAL - Underdog Racing Development
I got the URD universal O2 sim but also saw the following product posted in a similar thread inquiring about this exact same topic.
https://www.amazon.com/dp/B07QNJJQCT/ref=cm_sw_r_cp_api_i_0ZH4Cb1J2NJS1
Will tackle the DT long tube installation either next week or some time in June if time permits.
Depending on your location, keep in mind the car will not pass the sniffer test or visual inspection.
Any chance you would document that header install? You have brought good insight to things you have done thus far, and I would love to see what you have to say about this
Ah... Well there it is! When I ordered the insert it came with the air guide. Apparently there is an OEM hood scoop grille I need to order. Can’t find the part number though
You can take the factory plastic scoop cup thing and drill out a few rivets and put the mesh part of the hood scoop grille back in in front of the light bar. That's what I did so it protects/camouflages the LED bar from rocks etc.
That’s the plan... BUT from what I’m reading it’s a ***** of an install. So if I can find someone to do it for under 1k that’s the route I will take.
I ordered the air guide thinking the mesh was part of it. I have no idea why the mesh comes as a separate piece. You would think it would be riveted in stock. Ah well.
Thanks for adding this. I’d be pissed if I ordered it only to find out it didn’t come complete! So now I guess you have to order the mesh piece, or are you just going to use something different?
Ordered the mesh... leaving the air guide off. Going to experiment a little bit. Ordered a cheap open intake with 4” pipe off eBay. Will see how it bolts up and if fabricating a duct is possible. I’ve seen it done on a Tacoma. Probably minimal to no benefit other than cool factor. Haha
And possibly a regear with Nitro gears...
Toyota Nitro Gear Package
Maybe and ARB rear locker
ARB(R) Toyota 8" IFS Air Locker - ARB #RD111 Diff Locker 30 Spline (3.92 & Up)
This ARB locker fits the 8" axle housing and won't fit the 9.5" Diamond Axle, there are ARB lockers for the 9.5" axle housing.
With an ARB compressor kit for rear locker...
ARB CKMTA12 Dual High Output Air Compressor Kit for ARB Air Lockers
With compressor mount...
2005-2009 4th Gen Toyota 4Runner ARB Compressor Mount – Rago Fabrication
Some rear shocks guards wouldn't hurt..
BPF 4runner 04-19 /FJ 07-14 Shock Guards
Need a dual battery kit?
https://www.offgrid4x4.com/collecti...2-09-lexus-gx470-complete-dual-battery-system
Getting ready for installation.
-Doug Thorley long tube headers
-Half depth sockets
-Stubby ratchet wrenches
-Stubby swivel head 14mm ratchet
-Standard length swivel head 14mm ratchet
-Backup OEM studs - M10 1.25 40mm
-Titanium works titanium exhaust manifold studs
-Back up M10 1.25 thread tap
-Hewitt tech AIS delete
Will install the Hewit tech AIS delete now. Might as well install the URD O2 sim now as well. If it fails, backup below.
-Stainless mini catalytic converters
90 Degree CEL Check Engine Light... https://www.amazon.com/dp/B07QNJJQCT?ref=ppx_pop_mob_ap_share
Nice! Can't wait to see it installed!
Really curious to see how the URD o2 simulator is installed. I have Doug Thorley headers and was thinking of this.
Good lord, that thing has to growl without resonators. Would love to hear what it sounds like. So many fun things us California people don't get to participate in.
OEM scoop mesh installed with stainless hardware.
Of note, sequoia 4” intake didn’t work out. It’s going back to eBay
for all the kookiness (im in MA, right there with you) at least you have the landscapes and ocean...we have the ocean
From the Toyota parts page on the previous page, to get this hood scoop 'mesh' did you order the hood scoop 'plate'? I'm kind of confused what to get if I want to get the mesh.
