Front and Rear Diff fluid change
Watch out for milk jugs, they will break down in time when they are filled with oil. Fine for short term use.
Thanks. I had planned on immediately taking them for recycling but I may just put the oil back in the original containers then recycle. Didn't know about breaking down.
My ‘01 Tundra with the 4.7 iForce engine has 381K on her with original motor and drivetrain, I know as I bought it new from the dealer. I have been running Mobil 1 5W30 with Toyota oil filers since new. Does not leak a drop. My change intervals are always between 3 and 5K. Mobil 1 is solid oil, Toyota makes incredible engines!
I have the same pan posted above to use when actually changing the oil. Once it's done I throw a funnel on and put oil in these. I have 2 of them now so I don't have to go recycle as frequently.
https://shop.advanceautoparts.com/p...gclsrc=aw.ds&dclid=CPPqzvX_ld4CFca2swodLWkNpQ
FYI, The Advance Auto Parts near me allow you to recycle your oil there, they have huge containers in the back of the store if you come in with a container like above!
Thanks for the info.
I did my own gear oil service because the dealer screwed up my front skid plate, torqueing the bolts too tightly. When I tried to work on the lift I had to cut the skid plate off. Last night when I removed the engine oil canister that was torqued on pretty tightly too. It was probably more than the spec torque (in my notes at home).
Does Toyota do this just to piss us off or is it so only they can work on it, ie, job security?
Nope, they are just Impact Air wrench happy !
I use clothes wash liquid soap containers about 2 gallon size .. has a big hole and the small hole.. very strong these never leaked. using water or milk type plastic containers will over time leak.
also I did one time mixed some antifreeze into a distilled plastic water container .. 60% anti freeze and 40% distilled water so I could top off my vehicles. well after several months it leaked ...
Similarly, I use one of these along with the jug you provided a link to so I can transport oil in either container (I occasionally change oil in multiple vehicles at the same time). I just make sure I wrap a paper towel around the spout cap with a rubber band, as the oil will slosh into the spout during transport and may leak.
Thanks, I will start saving those for next time. Noted.
One quick question: the mobile 75w-90 mentioned in this thread are the $10 per quart LS one? Is there a non-LS version?
Not in synthetic that i'm aware of. There is nothing wrong with using LS gear oil in a non LS diff though. Just don't use it anywhere there are brass parts as LS additive eats them up. One of the reasons it doesn't belongs in a lot of transfer cases and manual transmissions.
That's a great idea. I don't have oil gallon containers but have been saving milk jugs to do that. I just had nothing to drain it in. Thanks.
if you somewhere somehow for some reason work in the restaurant industry or know of a cousin, friend, in-law, person that works in the restaurant industry then you should ask them to save one of these for you..
these guys change the fryer oils and these just wind up in the trash.. ive kept a couple of these for years and they never broke down..
milk jugs are a bad idea..
Will the milk jugs work for 2 hours or do this disintegrate fast? I plan on changing on at a time and immediately taking it for disposal, about 4 miles away.
Crookedcat
