InfamousRNR's 2002 Limited BU!LD THREAD
new tires for Tundra Rims
got some new rubberz for ma split spoke tundra rims
....thanks [MENTION=53337]SCRunner12[/MENTION] . this guy knows about every deal that ever exists
SLEE stainless steel brake lines
well it has been years since santa has stopped by my house to deliver gifts.. i think he must have lost my address, but UPS sure hasn't...
Slee brake lines for my TBU...
Toytec lift installation
got my lift on thanks to [MENTION=100687]Konkordmusk[/MENTION]
what a beast!!!!!
got a lotta rake with 9 wraps in the rear
Most of the new double dins aren't constant ground detection, all you need is a momentary ground switch. BUTTTT I can't say for sure on that deck, most either need a ground constant to simulate parking brake switch continuity or I had a double din before that needed only a momentary ground.
This is right. What i had to do for mine awhile back was install a switch so i could ground and un-ground it when i was wanting to use the DVD function or to play movies while driving/not having the E-Brake engaged.
mounted tires and alignment
mounted my used duratracs on some tundra rims and got my alignment done.
now I'm just waiting for my spacers (thanks for looking out for these [MENTION=53337]SCRunner12[/MENTION]) and thanks to [MENTION=48920]Big John[/MENTION] for the sale and shipping them out today.
much thanks to the master tech [MENTION=100687]Konkordmusk[/MENTION]!! for doing my alignment and tire mounting and balancing
1.5" Spidertraxx wheel spacers
wheel spacers!
now i can finally mount my new shoes!
tires mounted!
went over to [MENTION=100687]Konkordmusk[/MENTION] 's place to mount my spacers and tires.. also had Caleb slap in my PCV valve. what a guy!
big THANKS to this ^^^ dude.
you know what they say... pictures or it didn't happen
. . . :flamethrwoer2:
how did the plastydip smoke work for you? i like what you have done and am thinking about blacking out some of my lights now
went over to [MENTION=100687]Konkordmusk[/MENTION] 's place to mount my spacers and tires.. also had kaleb slap in my PCV valve. what a guy!
You spelled my name wrong :cry2:
Don't forget we did the diff drop too. You're missing out on extra scene points
sounds great! but my bypass that i made for the dvd player didn't end up working :(...
does anyone have any ideas why it wouldn't?
i used a 12v relay.
BLUE REMOTE WIRE --- 85 ON RELAY
GREEN HANDBRAKE WIRE -- 30 ON RELAY
BLACK GROUND WIRE -- 86 ON RELAY ALSO ATTACHED TO 87..
used a wiring harness that i got from ebay for toyota's so i didn't have to splice any factory wiring.
1987 - 2012 Toyota 4Runner Radio Wiring Harness Adapter #1761
1987 2012 Toyota 4Runner Radio Wiring Harness Adapter 1761 | eBay
I have the same deck. Have never been able to get it to play a dvd. (it came with the 4runner when I bought it)
[MENTION=102606]infamousRNR[/MENTION] your runner looks good. Where in the bay area are you guys. I'm in the East Bay. It would be nice to meet some other people with 4runners. How was installing your lift? I did the same lift in my drive way a couple weeks ago and it was a pain in the ass.
Responses
>>>> its fine.. my only advice is do super light coats approximately 12” away and mask off really good because the over spray is still on my car from doing my emblems :-(..
but it can come off super easily with a little rubbing alcohol and a micro fiber cloth.... so no biggie
>>>> still working on my English skills bro. it will never happen again Caleb
>>>>> i tried to make a relay switch but it didn’t end up working… i noticed i connected some extra stuff that i shouldn’t have and fixed that but still no luck on getting a DVD to play in my deck either…
i’ve had luck with just buying a relay someone else made off ebay with my last deck. super simply to connect but i got lazy and haven’t bought it yet… but i thank you for the reminder and I’m going to purchase one today!!! > click here <
do you have Homelink on your visor? oem or aftermarket?
>>>>> i’m 99% positive that it is an OEM home link however i haven’t even attempted to try and program it because i never use my garage to park my rig. but it would be nice to have an extra option to get into the house if i don’t have my key. have you programmed yours successfully?
>>>> I’m mainly in the south bay area for work but i travel from san jose to half moon bay. those are my 2 spots.. I’m going to try and get some 4runners together either for a MOD day or a wheeling day or maybe just a drive down the coast… i’ve always wanted to get a bunch of 4runners and drive down hwy 1.. maybe start in SF and go to Santa cruz. installing the lift wasn’t too bad on because i had the best TECH in the bay area [MENTION=100687]Konkordmusk[/MENTION] to lend a helping hand and pretty much do the heavy lifting. LOL . the hardest part i think when installing lifts is reaching the top of the rear shock mount. My body lift made it way easy to get in there.
Aw, I remember when the truck was just a babby.
Def this^
4runner RUN
Def this^
haaahahah ... i wish i knew about T4R when i got my first 4runner 10+ years ago...... would have saved me a bunch of grief ...
i was thinking either meet in SF or Santa Cruz and drive either up or down highway 1.... stop by the brewery 1/2 way down and stop by the beach for a pic-nic of sorts.....lots of pics for sure....
first weekend in FEB?,,,,,?......
beer @ the beach
Stopped by the beach today.. had a Lagunitas w/ my bae
044runner4
