InfamousRNR's 2002 Limited BU!LD THREAD
we will have more trips! i promise!!!
like Pismo Jamboree in September and i really want to get some dudes together for a weekend trip to Bald Mountain!
definitely love the air raid tube and paired with the DECK PLATE mod on the air box the thing is very loud.... it almost sounds likes i have an exhaust system or something... it definitely feels faster and sounds way louder...
Dynamat is still in the works but i only order one bulk pack from eBay and i will be order 1 more to complete the job...
1 order did my rear and 1-2 doors....
I have something in the works so stay tuned!!!
Did you get a chance to how much that would cost?
Tomorrow morning...pm me your cell and I will text you when I am there...if you are game I will just leave it with them to get sprayed... Sound good?
Pismo
Photo cred : DAVID CHICK
EDIT cred: ME
If you are in fresno area Pm me I'll can do a bald mountain run with you ! Am from fresno
i REALLY want to go there and I am planning on putting together a camping/4wheel run the weekend of
AUGUST 5/6/7th...
i want to plan far ahead in advance because soo many people say they didn't know far enough in advance...
are you part of the 559YOTA team or whatever?...
[MENTION=91623]CenCalifoothill15[/MENTION] please chime in on this date.
Am on the 559 yota but that about it. I can on those days! Am trying to do the pismo jamboree and LC jamboree or something can't remember the exact name for the event.
30,000 mile service
thanks to [MENTION=120071]mtbtim[/MENTION] , we changed all our fluids
mileage at time of service: 150,000
front differential fluid
rear differential fluid
transfer case fluid
transmission fluid
engine oil
engine oil filter
air filter
tire rotation
video coming soon...
transfer case fluid
transmission fluid
engine oil
engine oil filter
air filter
tire rotation
Truck looks good. I just changed a bunch of fluids on mine too, got to keep them running strong!
Got a little overzealous with my car washing and the soaped up sponge ripped off my "L" to my limited badging...
I guess I have the worlds first "imited" lol.
This should be there on Sat! Looking forward to seeing your install pics bro!!
So it is partially installed... Far from perfect and very frustrated
It's not sitting flush against the rear hatch...
Plan B is to JB Weld some bolts in place of the push pin clips ...
That way I can tighten down down a nut, instead of a flimsy plastic clip pushing through a hole
Added some dynamat to the rear hatch
I put some Dynamat on the rear hatch metal panels while I had them off.
Kicked it with [MENTION=120071]mtbtim[/MENTION] and check out my rear drum brakes. Inspected & cleaned
Also, I gained another 6" of lift!!!! (Temporarily)
Neither of us had much experience with drum brakes, but I did remember something from my Chevron Gas Station days. Sean's drums wouldn't come off so we had to pull the rubber grommets of the backing plates and turn the adjuster to get the drums off. Like usual, we turned it the wrong way the first time and tightened the brakes even more. Loosening them was problematic but I finally remembered you need to push the adjuster plate away from the adjuster wheel with a screwdriver so you can turn the wheel with another screwdriver or actual brake adjuster tool and loosen the brakes.
I think I'll be investing in some drum brake tools now.
Talyn
