OffRoadGuy
And you still want to take your rig on a desert safari? Anything above 50% I'd still be worried. Read up on how to remove trapped air from cooling system.
Also what are "LBJ's"?
Should I post that code in a new thread?
The search was helpful. I bookmarked it. Thanks!
Apparently I am the only person in the world who has ever gotten a P0155. Search it yourself.......lol. I'm just that lucky! I still think it may have something to do with my work. It only showed up after I took everything apart for the compression test, unless that is just when it (whatever "it" is) decided to poop out..
Our 4Runners have a single exhaust, therefore we DON'T HAVE any Bank 2 exhaust sensors. For this reason, it is not even listed in the FSM. I have NO IDEA how this is possible--missing pixels in display, not a 3G truck, idk...)..
I will go ahead and check my fan out but are there any tips on checking it? It is currently somewhat stiff when I turn it.
Josh- with the engine warmed up and turned off, try to spin the fan by hand: grab a fan blade and try to spin it. It should spin less than 1/4 turn or so before coming to a stop after you release the fan blade. If it spins more than that it's bad.
As far as your CEL- I think it's the O2 sensor you're using. Maybe someone else will chime in soon to give you a 2nd opinion.
