Post your LIFTED pix here!
Took some updated pics today.
3in toytec coil lift. Firestone destination m/t 285 tires. Spidertrax spacers.. Quite happy with how she turned out!
2014 trail T4R
Here's one of the latest I designed. Almost sold before I could even get it to the alignment rack. The streets need their Queens!
Woot woot! I can finally post my baby here. :hello:
Toytec 112-620 coils in front on 5100s @ 0" w/ 1/4" spacers on each side. 5100s and 1.5" Daystar spacers in the rear. About 2.25" in front now, should settle around 2" in a bit.
Got it installed by Toy-Crawlers in Broomfield, CO.
Do you know approximately how much of a lift would i get if bilstein 5100 set at .85 and went with toytec 112620s?
Assuming you have the same model I do, then I imagine that the 112620s (which are 1.6" higher and have a higher spring rate than OEM), will give you 1.8"-1.9" inches. (I'm at 2.25" w/ the 1/4" spacer). Add 0.85" onto that and that gives you 2.65", but that actually might get you at 3" (the same reason the 1/4" spacer yields up to 1/2").
Without actually doing it, who knows. But it would probably be close to 3". You would need UCAs too at that height unless you want a shitty ride.
But... I'm no expert in what and what can't be done, so call Toytec and ask what they think.
Talyn
