Post your LIFTED pix here!
What's the garage height? I'm moving into an apartment in April with a 6' 8" height limit which should be enough for the no-rise Gobi I ordered but if I lift mine it won't be more than 1" in the rear (if at all) so I'm not too concerned. But I'll definitely be getting close at that point.
Mine staggers. It starts at 6'10", then drops to 6'7" and then to 6'5". I'll be in the 6'7" area, but I'm not 100% sure their measurements are accurate. That was the clearance before they changed the lighting, which hangs even lower!!
Even though I literally said I can't lift this morning, I just saw and jumped on the TRD PRO kit in another thread. People are saying between .75 - 1" of lift on that. So I'm going to put that on, then the Gobi and see where I am at for tires. I only want to go 275s, so it'll be REALLY close to the max height, if not slightly over. Maybe I need to get up 2 hours earlier to get a parking spot on the 6'10" floor. :Cry:
2" Icon Stage 3 Lift
Do you personally run the ultimate? I'm looking at purchasing it but I'm stuck between the Boss and Ultimate. Although it kinda sounds like the ultimate is a bit more "user friendly" no? Lol
Sent from my SM-G955U using Tapatalk
Yes, have had it for about 10 months and 7500 miles, no complaints at all. Just add a 3/4" spacer to the back if you plan on going 3" up front to avoid negative rake. Below are pictures without the rear spacer and with. The rear end squat drove me crazy.
Do you have any side pictures like this with your Nitto RG 295s? Thanks
Stay Lifted
Wooooo! Couldn't wait to post in this thread.
Front Bilstein 5100 Shocks
Toytec Ultimate fully adjustable coilover
SPC UCA
Diff drop
Rear Bilstein 5100 shocks
2" OEM medium load rear coil
Toytec bumpstops
Pro Comp Predator 17" wheels
Duratrac 285/70R/17 tires
Did the install myself this past weekend. Front 100% alone and the rear I had some help for most of it!
Thinking about making a build thread with more pics and to answer any first-timers questions.
It's absolutely possible as a beginner to install yourself. definitely feel more comfortable working on the car in general as well.
SPC UCA
Diff drop
Toytec bumpstops
Dang, and it can even climb vertically!!
