Hopefully I got lucky. Sat. I was under the truck (oil change & re-torquing oil pan & rear diff bolts) & there were no leaks. I took it for a drive around the lake (30min) & parked it over night. Sun. I was putting my gas tank skid back on & noticed a little bit of gear oil in the rear PS wheel. Not sprayed all over like previous pics here. Next Sat. I'm doing the Breather Extension & hopefully the leak stops. I just changed to Red Line Synth oil so that could be a factor as well. This sucks because I haven't wheeled it all summer & now I have 3 wheelin' trips planned for Oct. I'm not driving it at all this week.
I did the breather extension mod & my axle seal isn't leaking any more.
I gotta say I wasn't expecting this. Good job and I hope it lasts. At least if it goes you're not out anything and you've already replaced your breather.
Good to hear Scramble, that is pretty much exactly my scenario. Did the breather mod and have not had any new noticeable leaks. Mine was hardly leaking to begin with.
So, you guys might think this is crazy, but as I mentioned my axel seals were leaking for the past few years. Don't dive the truck that much right now. I filled the rear pumpkin over 2 months ago and was able to add about 22 ounces of diff fluid until it became full again (diff holds 96 ounces total when full, 3 quarts about). It's been 2 months and NO MORE LEAKING. Can this somehow fix itself?
Now 6 months and no leaking. It fixed itself???
How does your breather look? Maybe it became unclogged somehow.
That is a great idea, I wish I thought of that.
The press fit is not tight at all. I don't have a gauge on my 12T press, but it was definitely not stressing it in any way.
Just saw this today under the rig. How soon do I need to fix this? What bad things can happen while driving on something like this? Just wondering how little time I have to save up some cash
Ok cool. Is it going to affect the rear brake at all or is there no way for it to get in there?I had same issue. As long as there's enough fluid in the diff, you could go years with a small leak like that. Mine leaked, and I think diff breather cap was clogged and I cleaned it and jiggled any dirt out of it, filled the fluid back up and no more leaks.
That looks like it went through the bearing and boot. I would pull the wheel and drum to check brakes. Those brake shoes sucks diff fluid and may compromise breaking. Check your diff breather if clog. Think about doing breather mod. Worse case is axle rebuild if bearing is compromised. You may get away with just changing the seal and o-ring. Just 2 cents.![]()
Thank you for the info. Going to do the breather mod atleast. It will help the other side if anything.That looks like it went through the bearing and boot. I would pull the wheel and drum to check brakes. Those brake shoes sucks diff fluid and may compromise breaking. Check your diff breather if clog. Think about doing breather mod. Worse case is axle rebuild if bearing is compromised. You may get away with just changing the seal and o-ring. Just 2 cents.
Sent from my SM-G930P using Tapatalk
