rando
Senior Member
Re: Blade Fuse taps
Sure, I know there are all kinds of 'other' ways to hook it up. I was specifically referring to the terminals inside the factory connectors. You can order these things from Molex, Amp, ... but you need to know which ones. Alternatively, you can do some guess work; as kmvreter indicated he did.
ToolmanJohn said:You can get a blade fuse tap from radio shack for a $1.49. After you crimp your wire into it (I solder it as well for security), they are made to be inserted into a blade type automotive fuse for power tapping purposes.
I just found these a week ago while picking through a parts drawer for something else.
http://www.radioshack.com/search.asp?find=ATC+Fuse+Tap&hp=search&SRC=1&image1.x=30&image1.y=34
