fourfive
Senior Member
I have come to believe that a good alignment tech is about as easy to find as a ****ing unicorn. Correction - a competent alignment tech. A good alignment tech is beyond my comprehension at this point.
Have you tried doing some of the rough adjustments yourself before taking it in? If not, doing this will make getting the alignment within spec much easier. It shouldn't have to be this way but that's the nature of the beast with alignment techs I guess. It's a mystery that I've got no good answer for. Bandit Runner did a great job outlining how to get your alignment within range so that the alignment shop is less likely to screw things up. I copied his instructions below.
Well, I finally got my alignment the way it should be. This is what I had to do:
Step 1: Set the SPC UCA's to "G" setting. This basically gives you the same amount of clearance to the firewall that you had with the OEM UCA's. Do this yourself, because the alignment shop won't have a clue.
Step 2: Maximize positive caster by adjusting all 4 LCA cams bolts.
- Both rear cams pushed outward as far as possible
- Both front cams pulled inward as far as possible
You can easily do this yourself also. Just loosen the nuts, turn the cam bolts, and re-tighten the nuts.
Step 3: Raise the front of vehicle and adjust camber, by adjusting the bolt in the slot at top of UCA. Do this yourself. The alignment shop won't want to mess around with this. It is easy to do, just takes some time. All I needed was a tape measure, level, and some trigonometry (an angle finder would have been easier, but I didn't have one). This does take some trial and error. You have to measure camber, raise the vehicle, adjust the bolt in the slot, lower the vehicle, roll it back-and-forth to let it settle, and re-measure. Repeat until you get it right. It took me 2 tries to get the passenger side right, and 4 tries for the driver side. Tighten top ball joint nut to 150 ft-lbs.
Step 4: Now bring it to the alignment shop. Have them tweak the camber if needed and set the toe. My crude setting of the camber was actually in spec, so all they had to do was set the toe.
If you perform these steps you will maximize the firewall clearance, and at the same time, get the most positive caster possible. I got 1.6 degrees caster on one side and 2.2 degrees on the other. The truck drives great like this.
