Berty's OEM+ Build Thread
Tire question
So much good info here and your 4R looks great!
I've been thinking about running Spidertrax with my 255/80s and JBA high caster arms. Do you have any tire rubbing at all at full lock with your setup?
I have the standard JBAs.
I did have some rubbing initially, but no more after I pulled my fender liners forward a bit. Was a piece of cake.
The spare is a bit of a tight squeeze, but it fits.
Replaced the passenger front differential axle seal. Was my first time pulling out the CV axle. Whole job took about 2.5 hours. I'll post my thoughts later.
Also got to use this Locknlube grease coupler. Total game changer for working with a grease gun to grease the zerk fittings on my car. Wish I had gotten it earlier. Made the entire process a breeze. No more busted knuckles, stuck fittings, or grease leaks.
y4mBodCIG2wunyHMsi32ZrB4HjRysPn9b9F7Jh_8vIg-T03t9eNIvnwptw26caVqYNH1RAO-anMeBJo6BX4XblbOIkmJlgmp_NMWHLHgr6byjASLaVQIvXfn_u9r5sV4RPJ9GGW-esWvbXaPh0jfltBkuqJq8c0QKtCmXRy3E7ZQcR86XH83XV5sA1Egi7zvHv2
Adding a Transmission Cooler
Finally added a transmission cooler. Felt my transmission was struggling last summer with my 33” tires and roof top tent (which I recently upsized).
My goal was a clean, OEM look. I really wanted to avoid ugly brackets. I’m very happy how the install turned out.
Here's what I needed for the install:
  • Derale 13503 Plate & Fin Cooler. Tube and fin coolers are the least efficient, then plate and fin (what I bought), then stacked plate.
  • Hayden 106, 4' Transmission Line
  • .25 Quart ATF Fluid
  • 1 Rivnut (I used an M8 because I didn't have an M6)
  • 30 mm M6 Spacer
  • M6 Nuts: 40 mm (for offset mounting), 20-25 mm for mount to crossmember
  • M8 Nut: 20-25 mm into rivnut
  • Abrasion protection sleeve for transmission line
  • Other tools for checking transmission oil level (see referenced link
Tips for the install:
  • This is an in-series install. Not a bypass (not recommended based on my research). Transmission cooler comes after the radiator, and the output from the cooler goes back to the transmission.
  • Bottom inlet is the input and top is the output. This orientation is recommended to minimize chances of an air bubble gets stuck in the cooler, thereby decreasing efficiency
  • As far as I understand, you cannot over-cool transmission fluid. So, I chose not to install a bypass valve for the transmission cooler, which bypass the transmission cooler on startup to help it get up to temp faster.
  • I only needed to drill one hole and install one Rivnut (I used an M8 because I didn't have an M6 Rivnut. Bothers my OCD but whatever.) Other two mounting points used already threaded holes. See my pic. I needed a 30 mm spacer for one of the mounting points (see pic)
  • When you add ATF and run the ATF fluid temperature check process, expect to wait MUCH longer. I waited 45 minutes (normally around 20 min) for the temp to come up to “measuring temp.” Towards the end of the process, I realized I could speed up the process by restricting flow to the transmission cooler with a fancy, high tech piece of cardboard. Place cardboard infront of the cooler to block airflow through it.
  • Took about 3 hours for the entire process
  • Remove the bumper. Its annoying but the extra space made the install much easier
  • Remove bottom skid plate for easier plumbing
  • IMPT: When drilling into the cross member, realize the AC condenser is inches away from the tip of your drill bit. IF you puncture the AC condenser, you're going to have a very bad day. Work around is simple. Take a piece of steel, aluminum, plywood, etc and wedge between the condenser and cross member.
Some helpful links I referenced
Now for some pictures
In the process:
y4mJ8M8B2uEIkGSdFVt11QDc22QAiZlySDfxhxFlvwsVarKBPE83qr7R0EUkW-CQyZMTmeS5C2U3pac4SRHMzaN9R03nlDmoWp8XC-W9FMn2b-HEudkLDWnz0EbpmRm1nWgbKQdktVpNCw-fcczECyqVLw4bpFBeOy5e9xGk4W_rQSzBdewmXOUnx2eWlazyOfV
Close-up of mounted cooler:
y4mIC6ZKWmTjqLHA01K6h10vJkiPoFWrGNgcLHshOi0vo5owI5bmF_8UCtpfLUJrI_0L7C0CVh_CMTDNx6CT9m8OtxOf-RpAmO0oGDYPHWHPP1gIuKSNWkAoPvv6qu3G-erc83gTC-jouGLS5Vd3S7uxxnQ11chT2h_O8Li-9ZOANveh_gdBtdWpX3s-drbibSY
30 mm Spacer:
y4mT8NUsaFWId_reDbTQ-XqsBC_M2r54seBLYgjOETJf8Gu-Mj_FoAAYGWUJ0Zt57v_8nkISlzKV2aB4dkviTUel36_GP0anjN0HMbXQIV3BbplA3GShO_gp8F2kKqvUjzNENXBryuUIEHHGb1D7SgPjVp9TrqJ2S-EXzwhqm1nnNJvR4vkb9qdiQTVnoipJHVq
Finally added a transmission cooler. Felt my transmission was struggling last summer with my 33” tires and roof top tent (which I recently upgraded).
For my install, I used a Derale 13503 cooler and bought and extra 4' of transmission line (glad I did this). Specifically, I bought Hayden 106 line off Amazon. Also used another ~.25 quarts of ATF to top off the fluid.
-This is an in-series install. Not a bypass (not recommended based on my research). Transmission cooler comes after the radiator, and the output from the cooler goes back to the transmission.
-Bottom inlet is the input and top is the output to minimize changes an air bubble gets stuck.
-Tube and fin coolers are the least efficient, then plate and fin (what I bought), then stacked plate
-As far as I understand, you cannot overcool transmission fluid.
-I only needed to drill one hole and install one Rivnut (I used an M8 because I didn't have an M6 Rivnut. Bothers my OCD but whatever.) Other two mounting points used already threaded holes. See my pic. I needed a 30 mm spacer for one of the mounting points (see pic)
-When you add ATF and run the ATF fluid temperature process, expect to wait MUCH longer. I waited 45 minutes for the temp to come up to “measuring temp.” Towards the end of the process, I realized I could speed up the process by restricting flow to the transmission cooler with a fancy, high tech piece of cardboard.
-Took about 3 hours for the entire process
Proper tune routing instructions:
2006 4.0L Transmission cooler installation, with some pics. - Toyota 120 Platforms Forum
Helpful general DIY
How To: 4th Gen V6 Radiator Replacement/Tranny Cooler Install | Toyota 4Runner Forum [4Runners.com]
How to put car in ATF Temp Check mode
How to Drain/Refill Automatic Transmission | Tacoma World
In the process:
40 mm Spacer:
Looks great! I've been telling myself I need to add an extra tranny cooler, I just have't yet. My thought was to do a much bigger one in place of the one in the radiator. My background in Volvos with trans/oil coolers built into the radiator tells me that removing extra connections and or failure points isnt a bad idea.
Extended rear links finally going in... 3 years aftery lift was installed. Oops.
These are non-adjustable and custom. If people are interested, I'd consider making more to sell. Made out of 3/8" hardware.
y4mo-H3-zYEsuk-stcwXBI3TYgG3jTONe2suIhna1Shr1qs3X5DHyNOimSyTga8fuIZm7N4VQuNzUf88J0ihiuoz94XFBeqpAC3Ma3eCJJsMU1WThDtuFAVvEKtNzdGIbDP8_VyCRSYQbmu5FgJT769CtguPRXRSgXJ2HhfikjafozjeDAbitNb-vUL7BTU52YF
Morimoto Mini D2S
New projectors are installed. I went with Morimoto Mini D2S 5.0 bixenon projectors with Osram Xenarc CBI bulbs. I chose the Morimoto over the G5R because I wanted a more balanced output.
The projectors were retrofitted into my projector housings. Bracket was from Custom Bracket Designs.
Comparison picture of OEM projector (in my hand) and Morimoto D2S 5.0 projector (mounted in housing).
y4mM5_BpbsBAMgJh48KGAsW9YWfDP-6lEfOOci_CWpUFYVVJ0GUarE-Yz24Yh_A11UwJLSiSH8-77JYUs6rfwPmIKKonLBTN31BCD14qgz1uOUeLpl3jHzahiHZL04aZoae_bZ9klkMmu4fxfYwZnYVZaUcMdjudT4IKdKprCyoUpvKNySZ_pWEc7w-RWhwTVes
Here's how I originally mounted the projector & bracket
y4m9GnDXKA8ovf7m31nKujZUxUBFqF-m-dq7h8i5JqtAbe1e0ImfEmE2tN-uEROYts6G9OYsyRn1cAPong-SbpEMvMhoiym8mZe1ceCVIdNB32_suwos3ry7s1CLW6BeEDrKgyimEppzHqTMFqikKBV7CnN4w27YQ5Tz_hdDwChRMdWouX1zzSGGRX4bRcAxVMx
Unfortunately, this created clearance issues for me with the factory shroud and lens
y4mluT-yG4desY0AuRmZeByObNy-Ef67otyq2MwnJaMGbigOED56erH9YOmqR_CyWFyUNdiHbZcdbPyfxuPoscXepTYyE3UPjLDxWkEt1IEBi_4s8L1YxKP74na8QUil0YlXx2OgsZ2H-BQFrX_24PJRtKpLipMeFh0udwznc66tSc1RiErZzd6m_AEmWz-i0Lz
The shroud touching the lens is no problem, but I was getting alignment issues on the passenger side due to the shroud interference. My solution:
  • Move bracket to front of projector (some dremeling was required to open up the bracket)
  • Open up the plastic backing on the old projector (image below)
y4mDdceNBh1fwxiAKDS41gCrrL8akJ2Evxavo71v-c3fLMeCD5W-flhcur4xXKGX0DYCiJBze8T3P7eL_Qwg2GzykVbJ8ukKXPklSpUl_myw1AaNjOBnH3XufP_uJWHqQNmufFL1FqFht1moKjKOqtr5Vm_sZrqVjHFk4lhPV40CfH8FYmiCVt9S9KclKP4KXwl
Output shot:
y4m6IxqGp9k1VwR4MsdLWJAhkcyTf8rHZoW0LJumKbteme4A8xfc21TPFrugtJoUPx0OV9OyfPP-kMKTG77NhKwpbvDcOlhLD2hKnUtWn7KyBMTWz8kKSXbZPuiE7leHG3u-5AckakJFMfbsI2Ra_OwvSFvACL3cfD8LsRPMqCGMNfH3g1wOplk2-q_YMXmnwJ4
Overall, I'm very happy with the setup and well worth the cost and time. Huge difference in output (both low and highbeam).
Suspension Air Lift
With the extra weight on my 4Runner, I noticed some significant squatting on my last trip. The ride wasn't great and my headlight aim was completely off. I decided to purchase a Air Lift 1000 kit to fix the squatting.
Which Kit to buy
For our stock 4Runners, Air lift recommends their 60809 Kit. However, many of us (including me) are running a rear lift. I, for example, have about 1.5 to 2 inches of lift in the rear. As such, I chose to go with a kit with a slightly taller bag: 60744 Air Lift Kit. This kit is about 1" taller.
Installation is relatively straight forward. I won't cover the steps here, but will share some helpful DIY's I referenced:
Some helpful information I'd like to provide.
  1. I found a lot of conflicting information on how many "pucks" to cut off of the rear bump stops. Cut them all off. Air lift suspension works by filling the gaps between the coils, preventing them from compressing. This essentially make the coil stiffer, helping keep your rear end from squatting. The bump stops shouldn't be compressing the air bags. According to Air Lift, its better to be slightly undersized than oversized (see third bullet).
  2. Linked vs Unlinked Bags: Linked means air can transfer from side to side. Unlinked means air cannot transfer from side to side. There are pros and cons to both. Linked- More articulation off road as air can transfer between bags. Unlinked- Similar to adding a stiffer sway bar, also independent control of air pressure means you can fine tune for uneven weights. I used an air switch from McMaster-Carr to be able to link & unlink the bags: 6791T13
My next big "project" will be rust treatment. I'll be documenting my research and work here.
Will be curious to see what you'll end up doing.
My buddy and I found a shop near fox lake that is certified by fluid film. I think we're going to clean up the surface rust and pay them a 100 and have them spray it.
Really enjoy your thorough updates! I can't wait to see what the processes you take to do the rust treatment, something I need to do.
Thanks! Trying to pay it forward. I've learned so much from this forum.
$100 isn't bad actually when you consider a 6 pack of FF costs about $50. I'm not looking forward to dealing the nasty smell, overspray, etc.
Battery Box
After flirting with the idea of adding a dual battery under the hood, I realized a battery box would be (1) simpler to implement and (2) a better overall solution than having another battery under the hood.
I have a plywood drawer system and was able to mount everything in the nook between the 2nd row seats and the drawer system.
This is my first time working on electrical components. I thought I could get away with solder and not a proper wire crimper. After trying to solder one connection, I decided to buy a proper crimper. While soldering connections may be cheaper if you have everything you need, soldered connections are messy and they create a rigid connection which is prone to failure from vibration-- solder isn't flexible.
Plenty of people shit on the Harbor Freight crimper because the die sizes aren't correct (they aren't), but you can easily get around this by using a bigger die size. Don't make the same mistake I did. Buy the damn crimper.
I used 6 and 4 AWG wiring cable along with the following key components:
  1. Go Wise 1000W Pure Sine Inverter (Link)
  2. Victron Isolated 18 AMP DCDC Smart Charger(Link)
  3. Duracell 24M Deep Cycle AGM Battery (Link)
Wiring Schematic:
y4mwtcbYAAYrvGhhJlGCWam_OSUVpjQ0clS7XKMUlTElGKjALI0gdqOOnU-0LMN4ZC1rYYVkgxyaq63-lOFGZ6xiOkN3-SA3ZKcCRH-hHXK6PYMklZqO8hf5_pTqFEchXh9oNpcAkr1B8-grSj15Mwh9lx30TZFgRj-dBYzwmGGEq8
Final Product:
y4mkjZBB1UDZowpReXWK_yZsXYPkMCfmRYAipPbsRgraQ3P58JovB1RIQivWQtWNZCaMpdUzB-kn5STSIa__UJWARIu3evuAJN7tmI2i1hR__P9IamEILa6nDhzXeVzWH0c8fAOwZH8dYZj3Q7NQfXagEzy561xEZp0iUlUqQPGEps
Rust Treatment
Overall, this was a massive pain. Make sure you don't skimp on PPE! I had a full tyvek suit, eye/ear protection, and a p100 respirator. This stuff is nasty.
  1. Scrap off all rust (This was easily half the project)
  2. Clean with acetone
  3. Paint on a layer of Eastwood Rust Encapsulator Platinum
  4. Dry for 4-48 hours
  5. Paint with Extreme Chassis Black
For scraping, I'd recommend a flap disc and wheel brush on an angle grinder.
y4moYLjnqCXwPvHkkOrm6NNIvf4X1fVlrEvAhSFYofWbXhN9wFHFwFJGKCCsMmrh9aYymCxdZi4DpbedZvlmZrMA3257w2efCl814CVYbN0Ibwjc_pmoukmQSzdNJC631JXvH8MXNZ3IvLVzCouZJhnaO5crU3nNCo5X11KOH5YGNM
Brake Bleeding
Planning on doing this for the first time this weekend (oops). Notes go here.
Materials
  1. DOT 4 Brake Fluid (Link)
  2. Motive Power Bleeder (Link)
Procedure
  1. Attached Motive Power Bleeder (dry) to master cylinder, pressurize to 15 PSI, and check for leaks
  2. Remove Power bleeder
  3. Remove old Brake Fluid from master cylinder with turkey baster
  4. Fill Power Bleeder with clean fluid
  5. Pressurize to 15 PSI
  6. Bleed in following sequence: passenger rear, driver side rear, passenger front, driver side front
Reference: Toyota 4Runner Brake Fluid Flush
Materials
  1. DOT 4 Battery Fluid (Link)
Procedure
This is the first time I ever heard of anyone flushing their brake system using "battery fluid"....but your brakes should get a hell of a charge doing that way, definitely a new meaning to "power brakes"!!! :rapture:
LOL. Not enough sleep or coffee.
tuṣṭāva
