Easy Weekend Mods
Almost there...
RKW6cUKal5iuVOBwWLEndOTCnzGYREnE5IbYNm07BrI1XOaA0ihdOib5hcjtYze67hVwDclcOO1Fa_pB5WRebAKy-swjHheotK4fVeKgKCbzw8CKuvbl1N8qpZyaeBqCeakYX4eAoyMdzZcWLBPdRFpEGAYnZXyvJnaNShEHFYs37T9Ecnv6Z98Y62XWV8peNicMtdtqSEnKuZ67YCwO4PhYtB2huM43WQ3grqvPiKifSvttYH1GW98r7liPT6m_kQm0iP04w_wZxSMhblOuWG629Xz4AvssJLSjgA9-RASEW1rirJDN7sfnVYWoZSGV2lVy0NxSoKZv_0Amqy1hDhjKN7MI70XKGxQ6A30srtyivZ6CBuS3WZ4ypTHSvUY6H-XHkPjBL3-KiNsDE8gYhkG94xd7VtB4hnFU-umQQDqufgfCYYIVO91GizIr_jiNhXUAAYBWnqYU39WDJOah7sbB7i88KMftf29gnsPmt63h7D6Z13jIdBZNIe3lJXCG6_Ck-BO5q8FQ94YPhoM69t8gXKDTeApENGwEmWv2iTFiBTC_4VJci6O6GFPbetkiDsXHY1hwZsCR_zkh8ImEhnxOHSuaF3NLSYj2dNPlVFEuf2OSxfrkGXli7UxypIiJM693pjHnqJWKqGSpDhAkPoveZxz0eiyRgF2w0jWEykAVcCsB6tynTjY=w1251-h938-no
I really need to order some Plio Grip and the Plio gun for mine. Was it as easy to work with as they make it seem?
Here is my parts list:
1. Remote operated electric hoist (880lb double line/440lb single) - Harbor Freight. It's overkill, but I had a coupon
2. Unistrut 20ft (1 5/8 slotted) - Home Depot
3. Stainless Steel 316 Round Ring Welded 3/8" x 3"
4. 1/8 Inch Aluminum Crimping Loop Sleeve for Wire Rope
5. Stainless Steel Thimble for 3/32" and 1/8" Diameter Wire Rope
6. T316 Marine grade 1/8 inch Stainless Steel Aircraft Wire Rope Cable, 100ft
7. 100Pcs 1/8" Aluminum Crimping Loop Sleeve Crimps
8. 16Pcs M3 Stainless Steel Thimble Rigging for Wire Rope Cable
9. 3/8" X 1 1/4" DROP FORGED MACHINERY EYE BOLTs, qty 8 (Chicago Hardware)
10. Threaded Quick Link Carabiner 5/16-Inch Diameter, 2-Pack x 2
11. IWISS Wire Rope Tool for Swaging
12. All thread, 3/8 (1ft)
Thanks! Looks like I've got a new project for this weekend!
It's fairly easy to work with Plio Grip. Flows very well but dries quickly so get a few extra mixing tubes.
Sanding is OK, takes a bit of time but not bad. Lots of dust, though. I used a mask when I was sanding.
If you have all the parts the whole thing can be done, ready to paint, in one easy day.
Black is the new... well, not silver #20dollarsaturday
Could you provide details of your mod? If you blacked out your front and back bumper valances, I’d like to know a little about how you did it. I’m interested in doing the same thing. Plasti dip rattle can?
Yep, that's the long and the short of it. Followed this video's process, and everything applied and excess peeled away exactly as shown. Took maybe an hour for both front and back.
https://www.youtube.com/watch?v=ImfTdT7R5bs
I considered the trim paint option, but the weather cooled off significantly, so I wasn't really in the mood to disassemble the vehicle (those bumper valances clip in through and behind the main bumper). In time, those bumpers, especially the front, will be replaced with something different, so the quick option was the winner.
Did my front 4 or 5 years ago with Plasti-Dip. It’s taken a beating but still going strong. This is the day I crushed my “extra” front skid.
Replaced all lower door speakers with Rockford Fosgates
Replaced all bulbs on HVAC panel
Cleaned MAF
Things to do:
Remove running boards...might still do that today
Order a set of 5100s or find some 2nd hand
What speakers did you choose? Was there a big difference is sound? Thanks.
My easy weekend mods.
HCF delete and drop in K&N filter.
Fog light mod.
Refinish head light covers and H9 conversion.
DIY 1/2" UHMW body lift.
Running board delete.
Front swaybar delete.
Body Mount chop.
Extended rear SS brake lines.
Hand woven Paracord attic cargo net.
Kydex firearm holster in center console.
Many of these mods are from this thread and I've been working on them for years. I finally, this week, finished reading through the entire thread lol. I want to thank everyone for the great ideas and trailblazing work you've all done here.
I’d love to see pics of the holster and the cargo net.
Also, why delete the sway bar?
Sent from my iPhone using Tapatalk Pro
I've been meaning to get some pics of the mods added here. If I wasn't lazy Id actually start a build thread lol.
Like kcdehart said it adds a little more travel to the suspension and the effect of the on road manners hasn't suffered.
It definitely doesn't seem to teeter as much when the trail gets twisty. I have a 3" Toytec suspension lift.
Inner fender liners
Cavalry blue ;)
Sry if blurry, getting a multihundred clip kit w tool for securing them that ive been meaning to get for garage. Plastic rivets.
Satoshi grille mod done, finally. Fitting the mesh was a royal PITA even though it was pre-cut and pre-bent. I'm very satisfied with the outcome.
1WktNWQPG8Oc0v3EkzW3t4JIWc77MoO54kF6nHlfwvj0UYLt6cXYB1jVI6dQyla0_7nFgXJegKAnHUwacFXgcPJuDHJGNedOxy_ecBBj17g_M-Ra2T4gH5MBqts65pVb8Lj4JscIxJZn4yro1LJyx6ZnX_qcHEfj0LWYM7Ggww8JiWPzHMKcQbOIr-wHlqRhuCsNpnqjGPwRYaepEo5W9HCk6bFRg1NDFY6bZE_aOTqFAfQKduTTmTTvWd3nrd6UpWMSu9afvZ31qQgybc6PY5AijE_Gr72cbNd3wWss5R-nhdpSXxYF5-6WRgtnDMxZ5eG25bvS3JXJGSw3JxMCZRj5o8XeBc-4TQMrxgZkgDS4z4Ul4g2rj4r_8pWUEalgJ7tb4v0vjjMoRZsdVOqNvnupA8UtqdDyeIR342NC4ZJV9xdAUIuDpiPSyB8W-rc53lejhrp9SiK2wcGKpMExMv92-5I25axAO5whePJuzJpbl-G8d3sURiFCCttrIIpz0eSoZbpMHRKeQowkIKOBTiCMB_dUvlqtSBtzvXf-fIZdX85mOmGPvbJ1Qf9jRQUuxNPn7mOfAmTSHIk5L5dYf26k4pCs4WB-BZYzAmt9bhdEJM_nSEnjKos89DenARkcdTTmQVdRJt_9vWxaQtu0w52-ozzrnlVSyODvvWpVsGQtAyrbJepsJ3N1zhHBlJEcxat6fDMT2c6UgJpWyIYNxcvwZs99C4HrmCcgF3qjMrBXPjsm=w1186-h889-no
ENLCdjJOC4pMLf_vts8QWUnGSHV6gw7ZHEVhbiLF99Ua_iTOctF8pAPV0hKSZr4kQR1uroJE_unq9UiAN0loI6cqTVHBqCtVuHA4cmw8afqWW-8upKGXPr57jHcjfABKcql-9DfjwyGQ_xcpej48HfmWHt8vF-2PaLfThjCwI34IgFkwzZKuTZG636PKRf134m9v-doO3fBRF7fVaa21-eMGCVeJcaImJCnh6FbyXyQ-s1EEPmNCQoPgYRKzYAbQ8QS-Jd9wm9cBOsu6AT5f-QI17qb5_XLnvS6Y-4_Kyo9PdWrt3U_sZM9Fj-fytn5dsUWP9bpm0zTgWdX_Zj-F5_8oLot8q9Q-uQ07pQQqaFqi22p-uHEyjND2Os3LgB-LTvpvxC8BIEw7FbS6JkRfRRv4-WnC00nxI4pQC-NZzis8-yHxNVuJzHtF82UFFk98iJS-Bq7UbatGvORXQEBXEDVla3JWawURoV2rx4AGr1s71uQAAtIoqlIz5akUJAW_lyl2Vn8UsJvYveEZv-TcstljrjKX_EUDJFxPoWsaIsDw8UOE5b5DYoTbZtdJZjfcM6n_YSa0-Jtx2niLX3w7d54lV4yCadO9rUD1n90MmQ-sPhC1F5IA9gj9vdwy0b5uInW4eNFifwd3UNMdaVrxb_HjEMkqqygQnQE_y28t7on2qiWHuoqss0U2sm2rPEgW1uXSs5qKI1kkg4S4OwkVqOtGdMyII024saBjlRgQXpcL-x4p=w1186-h889-no
Crookedcat
