Scion FRS Radio
OK. Im gonna start to order the harnesses. Maybe Ill order the two harnesses above and see if I can get those to work instead of the TYTO...
right on [MENTION=113957]MrRoo[/MENTION], keep us updated! i will closely follow your lead if it works
anyone looking for a e7009...mine will be up for sale if this works out!!
Metra doesn't have RCAs. Several of the pictures show it with them but it comes with open wires that you connect to whatever you need them to be. The only reason you would convert to RCA would be to try that other, cheaper harness that would be used instead of the TYTO.
Found a T10015 FRS touchscreen for $80. Ordering my harnesses this week. Also looking into the factory OEM Toyota FIT backup camera setup. My wife is used to her backup camera in her Highlander and cant stand how mine doesn't have one. So I "have" to install one with the new FRS radio. Hopefully all goes well with the install soon!!
oh heck yes! score on the unit, very excited to see if you can get it all to work out. Thanks for the update [MENTION=113957]MrRoo[/MENTION]!
i will be close behind you if you can get this to work!
It should work as CRW7096 has his working. Im using what he said works. I looked into the cheaper harness options that he said he was gonna try. The http://www.amazon.com/Rockford-Fosg...TF8&qid=1448318162&sr=8-3&keywords=RCA+female
Amazon.com: Metra 70-8113 Amplifier Integration Harness for Select 2000-2004 Toyota Vehicles: Car Electronics. But looking at Crutchfield and other sites says this is for deleting the JBL setup.
That's strange that some sites say that...the description on Amazon says it's used to retain the factory amplifier.
I'm glad you found a T10015 for such a good price! I'll be watching to see how the install goes and when you get the camera, I'll probably follow suit. Let me know if you need anything or have questions as you go!
oh, bummer, i was hoping you would be a guinea pig and figure out how to make it work without the TYTO harness.
I still might get those two harnesses and try. But want to have all on hand first. Ive been out of the stereo game for awhile now. Crazy how much has changed in 15 years. I don't like guessing at stuff. and I want stuff to be right. Don't want to go plugging in a harness that might not work and then back feeds the wiring and screws something up.
This is what Crutchfield says about the Metra 70-8113. Installation Note: This harness uses your factory amplifier; your new stereo must have two pairs of preamp outputs to connect this harness. As far as I know the T10015 does not have preamp outputs. Correct me if im wrong.
No, you're right, it does not. However, that is why I thought that if you used the reverse harness and converted them that it *might* work. Many people on here have said that the JBL "amp" isn't really so much like a traditional amp, but more of a controller for the additional speakers (additional being those that you have over the standard non-JBL setup). Either way, I don't blame you for playing it safe and getting the stuff that you know will work.
Forgive my ignorance, what is a "reverse" harness?
No no no that's not what it is. It's a harness that reverses a male connector to a female connector. We could call it the Caitlyn Jenner harness if you'd likes
I have all my harnesses needed now for the FRS install with my JBL setup. Is there a good write up with some pics on which wires and harnesses go where and so forth? What gets soldered where? Sorry for the rookie questions. Just want to make sure i'm doing everything correct. I'm not doing backup camera and usb port for now. That will have to come in a few months. Christmas has me strapped for cash.
Just to keep things clear, would you mind listing the items you purchased please? I'll be doing this soon after I can find one of these cool radios.
