What to do with current HID system?
Here's the current set up turned on. Fogs don't work.
http://www.youtube.com/watch?v=v6ZzYVCpquc
I contacted xenendepot about running HIDS of the High beams. They said that they didn't recommend HIDS for the high beams because they would be running at all times and would to bright and blind oncoming traffic. They also said that the DRL function would be disabled.
You can PM me you email and I could forward the emails they sent me
I appreciate everyone's input. I think I'll source everything I need from XD. Let me know what you think of this menu:
Lows: 9005 HID w/ Phillips 4300
Highs: 9005 LED Headlight Kit or Phillips H11 Bulbs
Fogs: Phillips H11 LED Bulbs
DRL: 9005 LED bulb
This list is incorrect. Do more research.
Low: H11 (projector)
High/DRL: 9005, they are together, you need one that is compatible with dual voltage, and this is bare reflector, so if you stick an LED or HID in there, you need to make sure that the beam pattern works
Fogs: H11/H16 whatever, but you need to make sure that the one you order fits
tuṣṭāva
