I heard that Toyota just takes away a few things on each generation and they are just preparing us for the 6th gen. It will not have a hood at all.
Uh Guys,
Before you get too carried away the sheet metal on our 4Runners, including the hood, is a structural component. Here's how:
Hood - While not designed to carry any load, it is integral in a front end collision as it is designed to fold and offer resistance to the incoming force of whatever you hit (or hits you)
Fenders, Doors Quarter Panels and Roof- Sheetmetal "skin" is attached to door frame by welds and adhesive to stiffeners which will hold them together during a side impact, causing them to act together to resist bending in an impact.
Imagine driving your 4Runner around with no sheetmetal, just the inner stiffeners, and getting hit. Yes, the sheetmetal plays an integral part of the vehicle's structure.
Thickness of the metal is not as important as the rigidity of the metal, which is accomplished through metallurgy and what we usually think of as "creases" or "curves" of the sheetmetal. Ever wonder why a panel is not perfectly flat on any vehicle?
And finally, hail damage. I have seen hail dent a fire truck hood and break plywood. 1/4" steel plate is what you need to be impervious to hail.
Another 4th Gen vs. 5th Gen comparison bash?
The hood is non structural.They put the extra steel and money in something that matters like a stronger frame with new doublers and supports and a 12 bolt rear end with a bigger/stronger ring and pinion which are known weak points on the older 120 platform. I'd take that trade off any day of the week. Where do you think the added 400lb+ is in a 5tth Gen compared to a 4th Gen??. I'd bet it went into the extra safety like full air bag protection,the new 8.2" 12 bolt rear end and from Toyota's own words "extensive frame and body reinforcements have been added, using high-tensile materials to add strength." Curious to see where other people think the extra weight came from because as noted it wasn't the hood?
So your like a 20-22 year old college kid that owns a 2004 Land Cruiser | 2007 V8 SE 4Runner | 2011 Subaru WRX | 2011 Audi S5 Prestige w/ Drive Select according to your signature and you sit around all day on forums bragging about it and stirring up shat all day?
Did you get permanently banned for being a social misfit from the other forums and and resign up under a new user ID there too like you did here?
I see your still eskimochaos and wfarrell4 on the 120 and alot of the other forums and twitter.Man you are a forum junky bra!Why don't you give us a break here on the 5th Gen sub forum once in a while?
A. Lives with parents
B. Claims parents rides on innerweb forums
C. Hates on New Hotness while driving Old and Busted model
If you wanted all that but the black carpet, why didnt you buy a 4th gen? The 4th gen seems like it would fit your pickyness a lot better.
It does not matter what it is. My 1995 f-350 got hail damage when I was in KS, how thick do you think sheet metal should be? My 1971 chevy truck even got hail damage and that darn hood weighed a ton. Try new Volvos,all body panels made with high streight steel, we got caught in heavy hail storm, not a single dent, amazing, I wishe every car was made like that, here in Colorado - hail capital of he world.
The hood is actually designed to crumple. If you look at the underside/outer edge about half way you will see the added crumple zones. One little bump (from the front) on that hood and it's history (can not be repaired).
As far as insulation, it has two purposes; to prevent heat damage to the paint over time and reduce engine noise. The only purpose for removing it, is cost.
BTW - The insulation for a non-scoop hood will have to be modified to work on a hood with a scoop and the scoop area does not get insulation. Also the OEM insulation is very expensive. I would use an aftermarket stick-back insulation, if you want it insulated.
Koz
That scoop isn't functional in the least
wait, the hood scoop isn't functional???
My scoop is functional.
It functions to increase wind resistance and it functions to look cool.
