3rd Gen T4R DIY Maintenance, Repair and Modification Videos
@BrianSD_42
gave me an idea when he started a thread, "List of 3rd Gen Builds with the most DIY help/advice".
@infamousRNR
(aka Sean) and I (aka Timmy the Toolman) have done a fair amount of DIY videos now and I was thinking it would be helpful to put them all in one place, so if somebody finds this thread, they'll find every DIY video we've done to date and maybe one of them will help them out.
So, sit back, relax and enjoy some "Toyota Time" with Timmy the Toolman and Sean. Edit 04/19/16 - Other members have expressed interest in posting their DIY videos on this thread as well and I say go right ahead. Edit 05/06/16 - It was suggested that a Table of Contents listed in the first post with permalinks to the videos would be beneficial to people visiting this thread and looking for a particular video without having to browse through all the pages. So, here it goes: TABLE OF CONTENTS 1) Sleeve Yoke Binding Fix (aka Slip Yoke Binding Fix) Video 1 of 2 3rd Gen Toyota 4Runner DIY Videos - Toyota 4Runner Forum - Largest 4Runner Forum 2) Video 2 of 2 to solve your Sleeve Yoke Binding 3rd Gen Toyota 4Runner DIY Videos - Toyota 4Runner Forum - Largest 4Runner Forum 3) 3.4 Liter V6 5VZ-FE Valve Cover Gaskets How-To Video 3rd Gen Toyota 4Runner DIY Videos - Toyota 4Runner Forum - Largest 4Runner Forum 4) Steering Rack and Front Sway Bar Bushing Replacement Video Tutorial 3rd Gen Toyota 4Runner DIY Videos - Toyota 4Runner Forum - Largest 4Runner Forum 5) Instrument Panel Light Bulb Replacement 3rd Gen Toyota 4Runner DIY Videos - Toyota 4Runner Forum - Largest 4Runner Forum 6) Restoring Color to Your Plastic Trim http://www.toyota-4runner.org/3rd-ge...ml#post2323347 7) Low-Tech Power Steering Fluid Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2323348 8) Sea Foam Engine Treatment http://www.toyota-4runner.org/3rd-ge...ml#post2323349 9) Lower Ball Joint Replacement Tutorial http://www.toyota-4runner.org/3rd-ge...ml#post2329586 10) Tranny Pan Gasket and Drive Belt Replacement Videos by @stir_fry_boy (See Video #70 for another video on replacing the Automatic Transmission Filter by Timmy the Toolman and Sean) http://www.toyota-4runner.org/3rd-ge...ml#post2337128 11) Tranny Cooler Install with Radiator and Thermostat Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2344949 12) CV Axle Replacement Video by @stir_fry_boy (There's also another CV Axle video w/ Reboot Procedure at #27) http://www.toyota-4runner.org/3rd-ge...ml#post2348519 13) Lower Balljoint Inspection http://www.toyota-4runner.org/3rd-ge...ml#post2351611 14) Rear Coil Spring Replacement and Rear Shock Bushing Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2352671 15) Starter Removal and Solenoid Repair http://www.toyota-4runner.org/3rd-ge...ml#post2352954 16) Adjusting drum brakes so you can get the drums off the axle http://www.toyota-4runner.org/3rd-ge...ml#post2393975 17) 30,000 Mile Service (Fluid Changes, Driveshaft Greasing, Brake Insp., etc) http://www.toyota-4runner.org/3rd-ge...ml#post2406402 18) Suspension Lift (Coils and Shock Replacement) http://www.toyota-4runner.org/3rd-ge...ml#post2419099 19) Brake Fluid Flush/Bleed http://www.toyota-4runner.org/3rd-ge...ml#post2425758 20) Fan Clutch Test and Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2425759 21) Automatic Transmission Fluid Flush http://www.toyota-4runner.org/3rd-ge...ml#post2456925 22) Diagnosing High Coolant Temps http://www.toyota-4runner.org/3rd-ge...ml#post2457202 23) Alternator Brushes Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2458869 24) AC Condenser Cleaning http://www.toyota-4runner.org/3rd-ge...ml#post2461564 25) Rear Differential Extended Breather Mod http://www.toyota-4runner.org/3rd-ge...ml#post2496258 26) Dash Cam Install http://www.toyota-4runner.org/3rd-ge...ml#post2500796 27) CV Axle Reboot w/ Extended Boot Mod and Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2525143 28) Lower Control Arm Bushing Replacement Part 1 (See #72 for Part 2 of this repair) http://www.toyota-4runner.org/3rd-ge...ml#post2534670 29) Front Driveshaft U-Joint Replacement Video by @stir_fry_boy http://www.toyota-4runner.org/3rd-ge...ml#post2538004 30) Drive Belt Replacement (Power Steering, AC, and Alternator) http://www.toyota-4runner.org/3rd-ge...ml#post2538317 31) Tundra Brake Upgrade aka TBU http://www.toyota-4runner.org/3rd-ge...ml#post2551280 32) 3rd Gen Toyota Tacoma Whip Mod Video by @sambishop http://www.toyota-4runner.org/3rd-ge...ml#post2573999 33) Toytec 2" Body Lift Installation http://www.toyota-4runner.org/3rd-ge...ml#post2576976 34) ToyTec Boss Complete Suspension Lift Installation http://www.toyota-4runner.org/3rd-ge...ml#post2592808 35) Overdrive Off = Transmission Temp Drop http://www.toyota-4runner.org/3rd-ge...ml#post2595599 36) Rear Sway Bar Bushing Replacement Video by @sambishop http://www.toyota-4runner.org/3rd-ge...ml#post2603536 37) Front Differential Axle Seal Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2603920 38) Power Steering Rack Bushing Replacement (Also See #4 on List for Similar Video) Video by @sambishop http://www.toyota-4runner.org/3rd-ge...ml#post2612883 39) Steering Rack Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2617174 40) Sammy's Comedic Automatic Transmission Fluid Exchange (Also See #21 on List for Similar Video - just with no comedy or profanity) Video by @sambishop http://www.toyota-4runner.org/3rd-ge...ml#post2632637 41) Bilstein 6112 Coilover Install - Video by @sambishop http://www.toyota-4runner.org/3rd-ge...ml#post2641994 42) Cooling System Flush http://www.toyota-4runner.org/3rd-ge...ml#post2652394 43) How To Fit Bigger Tires On Your Truck/SUV Video by @sambishop http://www.toyota-4runner.org/3rd-ge...ml#post2653628 44) 3rd Member Swap http://www.toyota-4runner.org/3rd-ge...ml#post2654954 45) Rear Axle Seal/Bearing Replacement (ABS and Non-ABS Rearends) http://www.toyota-4runner.org/3rd-ge...ml#post2676823 46) Manual Hub Conversion http://www.toyota-4runner.org/3rd-ge...ml#post2679984 47) Automatic Transmission Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2705015 48) Wheel Lug Nut Stud Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2706410 49) Steering Rack Guide Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2708565 50) Toyota 3.4 Rear Main Seal Replacement Video by @sambishop http://www.toyota-4runner.org/3rd-ge...ml#post2709122 51) Toyota 3RZ Header Install http://www.toyota-4runner.org/3rd-ge...ml#post2724566 52) Front Differential Replacement For another video for this job, check out #115 http://www.toyota-4runner.org/3rd-ge...ml#post2763608 53) Transmission and Engine Mount Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2765814 54) Air Conditioning Recharge http://www.toyota-4runner.org/3rd-ge...ml#post2776586 55) Fuel Filter Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2782415 56) Drum Brake Shoe Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2797480 57) Starter Replacement (Also see #15 on the list for a similar Starter Repair Video) Video by @sambishop http://www.toyota-4runner.org/3rd-ge...ml#post2806929 58) Toyota Timing Belt Replacement (PART 1) for 3.4L V6 5VZ-FE http://www.toyota-4runner.org/3rd-ge...ml#post2831265 59) Toyota Timing Belt Replacement (PART 2) for 3.4L V6 5VZ-FE http://www.toyota-4runner.org/3rd-ge...ml#post2844795 60)V8 Swap (5VZ-FE 3.4L V6 to 2UZ-FE 4.7L V8) http://www.toyota-4runner.org/3rd-ge...ml#post2849655 61) Sunroof Drain Cleaning http://www.toyota-4runner.org/3rd-ge...ml#post2851552 62) Rear Lower Control Arm Bushing Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2852260 63) ARB Bumper Install http://www.toyota-4runner.org/3rd-ge...ml#post2873937 64) 5VZ-FE 3.4L V6 Compression Test http://www.toyota-4runner.org/3rd-ge...ml#post2876106 65) Power Steering Flush and Reservoir Cleaning http://www.toyota-4runner.org/3rd-ge...ml#post2881368 66) Steering Wheel Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2891855 67) Headliner Removal and Sunroof Leak Fix http://www.toyota-4runner.org/3rd-ge...ml#post2892743 68) Toyota 5VZ-FE 3.4 Liter V6 Supercharger Installation http://www.toyota-4runner.org/3rd-ge...ml#post2904621 69) Supercharger Nose Cone Oil Plug Mod Video by @sambishop http://www.toyota-4runner.org/3rd-ge...ml#post2906288 70) Automatic Transmission Filter Replacement (A340F) http://www.toyota-4runner.org/3rd-ge...ml#post2920560 71) Fuel Sending Unit Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2924278 72) Lower Control Arm Bushing Replacement Part 2 http://www.toyota-4runner.org/3rd-ge...ml#post2949883 73) Automatic Transmission Temperature Gauge Installation http://www.toyota-4runner.org/3rd-ge...ml#post2953940 74) CBI Dual Swing Arm Rear Bumper Install (Part 1) http://www.toyota-4runner.org/3rd-ge...ml#post2960331 75) CBI Dual Swing Arm Rear Bumper Intall (Part 2) http://www.toyota-4runner.org/3rd-ge...ml#post2970457 76) Rear Upper Control Arm Bushing Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2970821 77) Front Upper Control Arm Bushing Replacement http://www.toyota-4runner.org/3rd-ge...ml#post2971841 78) CBI Weld-on Rock Slider Install http://www.toyota-4runner.org/3rd-ge...ml#post2992751 79) CBI Hybrid Front Bumper Install http://www.toyota-4runner.org/3rd-ge...ml#post2992752 80) Panhard Correction Kit (PCK) Install - Brackets made by @eimkeith http://www.toyota-4runner.org/3rd-ge...ml#post3001350 81) CBI Skid Plate Install http://www.toyota-4runner.org/3rd-ge...ml#post3003530 82) Lil' Skip's Offroad Gas Tank Skid Plate Install http://www.toyota-4runner.org/3rd-ge...ml#post3005617 83) Stripped Differential Drain Plug Removal http://www.toyota-4runner.org/3rd-ge...ml#post3008720 84) O2 Sensor Replacement http://www.toyota-4runner.org/3rd-ge...ml#post3008723 85) E-Locker Swap http://www.toyota-4runner.org/3rd-ge...ml#post3017345 86) Warn M8000 Winch Install on a CBI Front Hybrid Bumper http://www.toyota-4runner.org/3rd-ge...ml#post3027599 87) BudBuilt Rear Differential Skid Plate Installation http://www.toyota-4runner.org/3rd-ge...ml#post3041148 88) Manual Hub Swap Part 2 - A.D.D. Hub Bearing Replacement http://www.toyota-4runner.org/3rd-ge...ml#post3048117 89) Lotus RCAMS (Rear Control Arm Mount Skid) Installation http://www.toyota-4runner.org/3rd-ge...ml#post3096549 90) Engine Misfire Diagnosis & Fuel Injector Replacement http://www.toyota-4runner.org/3rd-ge...ml#post3124082 91) Inner and Outer Tie Rod Replacement http://www.toyota-4runner.org/3rd-ge...ml#post3140173 92) E-Locker Bench Test http://www.toyota-4runner.org/3rd-ge...ml#post3141426 93) Durobump Bump Stop Installation http://www.toyota-4runner.org/3rd-ge...ml#post3162308 94) Upper Balljoint Replacement Video http://www.toyota-4runner.org/3rd-ge...ml#post3169433 95) Phone Mounting Options http://www.toyota-4runner.org/3rd-ge...ml#post3180028 96) ECGS Clamshell CV Axle Bushing install http://www.toyota-4runner.org/3rd-ge...ml#post3190504 97) Steering Play Fix http://www.toyota-4runner.org/3rd-ge...ml#post3190506 98) U-Joint Replacement http://www.toyota-4runner.org/3rd-ge...ml#post3192345 99) ECU Replacement http://www.toyota-4runner.org/3rd-ge...ml#post3193944 100) Hood Lift Strut Mod https://www.toyota-4runner.org/3rd-g...ml#post3194957 101) Center Console Mod - Cup Holder Mod for 96-98 Toyota 4Runner's https://www.toyota-4runner.org/3210521-post570.html 102) 4Lo and Your Automatic Transmission https://www.toyota-4runner.org/3218324-post572.html 103) Toyota Rear Axle Seal/Bearing Replacement (Part 2) by jearred.foruria url]https://www.toyota-4runner.org/3230931-post577.html[/url] 104) Reat Hatch Strut Replacement https://www.toyota-4runner.org/3237696-post587.html 105) Savage Off-Road Front Hybrid Winch Bumper Install https://www.toyota-4runner.org/3237697-post588.html 106) Savage Off-Road Hybrid Rear Bumper Install Part 1 https://www.toyota-4runner.org/3247310-post590.html 107) Savage Off-Road Hybrid Rear Bumper Install Part 2 https://www.toyota-4runner.org/3247315-post591.html 108) Toyota 3RZ-FE Valve Adjustment https://www.toyota-4runner.org/3247320-post592.html 109) Engine Cylinder Leak Down Test https://www.toyota-4runner.org/3256936-post593.html 110) Transfer Case Output Shaft Seal Replacement https://www.toyota-4runner.org/3264335-post603.html 111) Engine Ignition Timing Check / Timing Belt Inspection https://www.toyota-4runner.org/3288673-post631.html 112) Coastal Offroad High Clearance Front Bumper Build Video by @jearred.foruria https://www.toyota-4runner.org/3330217-post677.html 113) OME 891 Rear Coil Install Video by @jearred.foruria https://www.toyota-4runner.org/3330220-post678.html 114) How to paint your 3rd Gen Wheels Video by @jearred.foruria https://www.toyota-4runner.org/3330223-post679.html 115) East Coast Gear Supply Front Diff install Video [email protected] For another video for this job, check out #52 https://www.toyota-4runner.org/3347174-post692.html 116) Clutch Replacement https://www.toyota-4runner.org/3375555-post725.html 117) Disk Brake Service https://www.toyota-4runner.org/3378030-post733.html 118) Pinion Seal Replacement https://www.toyota-4runner.org/3390837-post748.html 119)Toyota 5VZ-FE 3.4L V6 TRD Supercharger Nose Cone Rebuild https://www.toyota-4runner.org/3417804-post779.html 120) IAC Valve Testing and Cleaning https://www.toyota-4runner.org/3421982-post789.html 121) Defogger Fix Video by @Hebrews 6:20 https://www.toyota-4runner.org/3436411-post805.html 122) Radiator Support Replacement (Front End Collision Repair) Video by @Theallsmith https://www.toyota-4runner.org/3438839-post811.html 123) Auto Climate Control Repair https://www.toyota-4runner.org/3462653-post815.html 124) Alternator Rebuild Video by @weekendclimber https://www.toyota-4runner.org/3481484-post839.html 125) Auto Trans Shifter Bushing Replacement & Transfer Case Shifter Seat Replacement https://www.toyota-4runner.org/3483573-post843.html 126) Key Lock Cylinder Replacement https://www.toyota-4runner.org/3484756-post847.html 127) Hilux 167 Snorkel Install https://www.toyota-4runner.org/3490640-post850.html 128) Rear Hatch Wiring Repair https://www.toyota-4runner.org/3507847-post872.html 129) Outbound Nevada Molle Panel Installation https://www.toyota-4runner.org/3527920-post879.html 130) Door Lock Actuator Repair https://www.toyota-4runner.org/3530920-post880.html 131) Clutch Pedal Rebuild / Replacement https://www.toyota-4runner.org/3537421-post885.html 132) Toyota 3.4 Liter 5VZ-FE Engine Replacement https://www.toyota-4runner.org/3565233-post909.html 133) ARB Bumper Winch Install https://www.toyota-4runner.org/3580898-post917.html 134) Front Wheel Bearing Replacement https://www.toyota-4runner.org/3588997-post921.html 135) Door Stopper Repair https://www.toyota-4runner.org/3594835-post933.html 136) Trac Off Switch Install https://www.toyota-4runner.org/3598148-post940.html 137) Borla Muffler Install https://www.toyota-4runner.org/3603821-post949.html 138) Rear Door Window Glass Replacement https://www.toyota-4runner.org/3617259-post963.html 139) Total Chaos Weld-on Spindle Gusset Install https://www.toyota-4runner.org/3617805-post966.html 140) Opt Off Road Rear Control Arm Install https://www.toyota-4runner.org/3620823-post967.html 141) Yota1 Performance ARB Air Compressor Bracket Install https://www.toyota-4runner.org/3634013-post983.html 142) Freel Good Performance Outboard Shock Relocation Kit https://www.toyota-4runner.org/3649133-post1001.html 143) JBA Offroad Upper Control Arm Installation https://www.toyota-4runner.org/3653942-post1002.html 144) CS144 + Big 3 Wiring Upgrade https://www.toyota-4runner.org/3660683-post1005.html 145) Marlin Crawler Dual Transfer Case Assembly (TACOBOX) https://www.toyota-4runner.org/3662793-post1006.html 146) AC Condenser and Receiver Dryer Replacement with AC System Recharge Video by @weekendclimber https://www.toyota-4runner.org/3666520-post1007.html For another video on the subject of AC Recharging here's this one: https://www.toyota-4runner.org/2776586-post372.html 147) Valve Clearance Inspection and Adjustment (3.4L 5V-FE) https://www.toyota-4runner.org/3682439-post1022.html 148) Marlin Crawler Dual Transfer Case Install (Part 2 - Installation) Check out List #145 for Part 1. https://www.toyota-4runner.org/3693929-post1030.html 149) How to Check Lower Balljoint Play with a Dial Indicator https://www.toyota-4runner.org/3704829-post1032.html 150) Transmission Cooler Install (Bypassed and Used Metal Brackets for Mounting) https://www.toyota-4runner.org/3708966-post1035.html 151) Moroso Air/Oil Separator Installation (Catch Can) https://www.toyota-4runner.org/3720494-post1055.html 152) Transgo 340HD2 Reprogramming Kit Install - A343F A340E ('85-'08) https://www.toyota-4runner.org/3725406-post1064.html 153) Knock Sensor and Knock Sensor Wiring Harness Replacement https://www.toyota-4runner.org/3732937-post1068.html 154) Arcworxs Rear Shock Outboard Relocation Kit https://www.toyota-4runner.org/3734860-post1069.html 155) ECGS Toyota 8" Rear Differential Regear / Rebuild https://www.toyota-4runner.org/3756045-post1077.html 156) ECGS Toyota 7.5" Front Differential Regear w/ Eaton E-Locker Install https://www.toyota-4runner.org/3757969-post1080.html 157) Front Differential Replacement (Part 2) https://www.toyota-4runner.org/3760958-post1088.html 158) Eaton E-Locker Wiring How-to https://www.toyota-4runner.org/3760961-post1089.html 159) How to Install an Auxbeam 6 or 8 Gang Switch Panel https://www.toyota-4runner.org/3770308-post1090.html 160) Cargo Hatch Lock Actuator Repair https://www.toyota-4runner.org/3771439-post1098.html 161) How to Install Auxbeam Lights (Mounting and Wiring) https://www.toyota-4runner.org/3773741-post1101.html 162) Eimkeith Rear Bumper Build w/ Hot Metal Fab https://www.toyota-4runner.org/3781949-post1110.html 163) Pilot Bearing Removal https://www.toyota-4runner.org/3790231-post1112.html 164) Head Gasket Failure Diagnosis https://www.toyota-4runner.org/3791174-post1113.html Continued in Post #2 |
Table of Contents Continued
I exceeded the allowable character limit in Post #1, so I'm continuing the video table of contents here. 165) Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE) - Part 1 https://www.toyota-4runner.org/3800433-post1114.html 166) Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE) - Part 2 https://www.toyota-4runner.org/3800711-post1115.html 167) Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 3 https://www.toyota-4runner.org/3801437-post1116.html 168) Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 4 https://www.toyota-4runner.org/3802122-post1117.html 169 Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 5 https://www.toyota-4runner.org/3803209-post1118.html 170) Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 6 https://www.toyota-4runner.org/3803890-post1121.html 171) Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 7 https://www.toyota-4runner.org/3804694-post1125.html 172) TEQ Customs Retrofit Headlight Install https://www.toyota-4runner.org/3810338-post1128.html 173) Koyorad Aluminum Radiator Upgrade https://www.toyota-4runner.org/3810678-post1129.html 174) R150F Manual Transmission Rebuild (Part 1 & 2) https://www.toyota-4runner.org/3813341-post1138.html 175) 3RZ-FE Water Pump & Thermostat Replacement https://www.toyota-4runner.org/3819134-post1145.html 176) RCI Skid Plate Install https://www.toyota-4runner.org/3823140-post1150.html 177) Windshield Replacement https://www.toyota-4runner.org/3823141-post1151.html 178) Solo Motorsports LCA Install https://www.toyota-4runner.org/3831750-post1157.html 179) Brake Booster Replacement https://www.toyota-4runner.org/3831751-post1158.html 180) 333 Fabrications HD Billet Steering Rack Clamp Install https://www.toyota-4runner.org/3831752-post1159.html 181) Rear Hatch Glass Replacement https://www.toyota-4runner.org/3831753-post1160.html 182) Rear Dome Light Repair https://www.toyota-4runner.org/3831817-post1165.html 183) Iconic Fab Transmission Cooler Mount https://www.toyota-4runner.org/3834071-post1166.html 184) UCA Uniball Replacement https://www.toyota-4runner.org/3834802-post1167.html |
<iframe width="560" height="315" src="https://www.youtube.com/embed/Jyltxe2nPEg" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/N5fAXAuGozI" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/YywcR0E9bM4" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/H4EVITIgA3Q" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/3V-fiBPU56w" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/GOb5yF2Xv8Y" frameborder="0" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/J5BvNwyIqmY" frameborder="0" allowfullscreen></iframe>
Quote:
I started this thread so if somebody stumbled across it, they might find something inside that was useful to them. |
This is a cool idea. I don't understand the @----- in the title though.
haha...license to drive
Quote:
Quote:
"Steering Rack and Front Sway Bar Bushing Replacement Video Tutorial"
Thanks for the video. You are risking your life under the truck which is just on 2 jack stands. |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
