3rd Gen T4R DIY Maintenance, Repair and Modification Videos
mtbtim
[MENTION=65101]BrianSD_42[/MENTION] gave me an idea when he started a thread, "List of 3rd Gen Builds with the most DIY help/advice". [MENTION=102606]infamousRNR[/MENTION] (aka Sean) and I (aka Timmy the Toolman) have done a fair amount of DIY videos now and I was thinking it would be helpful to put them all in one place, so if somebody finds this thread, they'll find every DIY video we've done to date and maybe one of them will help them out.
So, sit back, relax and enjoy some "Toyota Time" with Timmy the Toolman and Sean.
Edit 04/19/16 - Other members have expressed interest in posting their DIY videos on this thread as well and I say go right ahead.
Edit 05/06/16 - It was suggested that a Table of Contents listed in the first post with permalinks to the videos would be beneficial to people visiting this thread and looking for a particular video without having to browse through all the pages. So, here it goes:
TABLE OF CONTENTS
1) Sleeve Yoke Binding Fix (aka Slip Yoke Binding Fix) Video 1 of 2
3rd Gen Toyota 4Runner DIY Videos - Toyota 4Runner Forum - Largest 4Runner Forum
2) Video 2 of 2 to solve your Sleeve Yoke Binding
3) 3.4 Liter V6 5VZ-FE Valve Cover Gaskets How-To Video
4) Steering Rack and Front Sway Bar Bushing Replacement Video Tutorial
5) Instrument Panel Light Bulb Replacement
6) Restoring Color to Your Plastic Trim
http://www.toyota-4runner.org/3rd-gen-t4rs/217550-3rd-gen-toyota-4runner-diy-videos.html#post2323347
7) Low-Tech Power Steering Fluid Replacement
http://www.toyota-4runner.org/3rd-gen-t4rs/217550-3rd-gen-toyota-4runner-diy-videos.html#post2323348
8) Sea Foam Engine Treatment
http://www.toyota-4runner.org/3rd-gen-t4rs/217550-3rd-gen-toyota-4runner-diy-videos.html#post2323349
9) Lower Ball Joint Replacement Tutorial
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-2.html#post2329586
10) Tranny Pan Gasket and Drive Belt Replacement Videos by [MENTION=48234]stir_fry_boy[/MENTION]
(See Video #70 for another video on replacing the Automatic Transmission Filter by Timmy the Toolman and Sean)
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-2.html#post2337128
11) Tranny Cooler Install with Radiator and Thermostat Replacement
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-2.html#post2344949
12) CV Axle Replacement Video by [MENTION=48234]stir_fry_boy[/MENTION]
(There's also another CV Axle video w/ Reboot Procedure at #27)
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-2.html#post2348519
13) Lower Balljoint Inspection
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-2.html#post2351611
14) Rear Coil Spring Replacement and Rear Shock Bushing Replacement
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-3.html#post2352671
15) Starter Removal and Solenoid Repair
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-3.html#post2352954
16) Adjusting drum brakes so you can get the drums off the axle
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-3.html#post2393975
17) 30,000 Mile Service (Fluid Changes, Driveshaft Greasing, Brake Insp., etc)
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-3.html#post2406402
18) Suspension Lift (Coils and Shock Replacement)
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-3.html#post2419099
19) Brake Fluid Flush/Bleed
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-4.html#post2425758
20) Fan Clutch Test and Replacement
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-4.html#post2425759
21) Automatic Transmission Fluid Flush
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-4.html#post2456925
22) Diagnosing High Coolant Temps
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-4.html#post2457202
23) Alternator Brushes Replacement
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-4.html#post2458869
24) AC Condenser Cleaning
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-4.html#post2461564
25) Rear Differential Extended Breather Mod
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-5.html#post2496258
26) Dash Cam Install
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-5.html#post2500796
27) CV Axle Reboot w/ Extended Boot Mod and Replacement
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-7.html#post2525143
28) Lower Control Arm Bushing Replacement Part 1 (See #72 for Part 2 of this repair)
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-8.html#post2534670
29) Front Driveshaft U-Joint Replacement Video by [MENTION=48234]stir_fry_boy[/MENTION]
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-9.html#post2538004
30) Drive Belt Replacement (Power Steering, AC, and Alternator)
http://www.toyota-4runner.org/3rd-g...-toyota-4runner-diy-videos-9.html#post2538317
31) Tundra Brake Upgrade aka TBU
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-12.html#post2551280
32) 3rd Gen Toyota Tacoma Whip Mod Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-14.html#post2573999
33) Toytec 2" Body Lift Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-15.html#post2576976
34) ToyTec Boss Complete Suspension Lift Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-15.html#post2592808
35) Overdrive Off = Transmission Temp Drop
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-16.html#post2595599
36) Rear Sway Bar Bushing Replacement Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-16.html#post2603536
37) Front Differential Axle Seal Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-16.html#post2603920
38) Power Steering Rack Bushing Replacement (Also See #4 on List for Similar Video) Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-16.html#post2612883
39) Steering Rack Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-16.html#post2617174
40) Sammy's Comedic Automatic Transmission Fluid Exchange (Also See #21 on List for Similar Video - just with no comedy or profanity) Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-16.html#post2632637
41) Bilstein 6112 Coilover Install - Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-17.html#post2641994
42) Cooling System Flush
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-17.html#post2652394
43) How To Fit Bigger Tires On Your Truck/SUV Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-18.html#post2653628
44) 3rd Member Swap
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-18.html#post2654954
45) Rear Axle Seal/Bearing Replacement (ABS and Non-ABS Rearends)
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-20.html#post2676823
46) Manual Hub Conversion
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-21.html#post2679984
47) Automatic Transmission Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-22.html#post2705015
48) Wheel Lug Nut Stud Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-22.html#post2706410
49) Steering Rack Guide Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-23.html#post2708565
50) Toyota 3.4 Rear Main Seal Replacement Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-23.html#post2709122
51) Toyota 3RZ Header Install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-24.html#post2724566
52) Front Differential Replacement For another video for this job, check out #115
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-25.html#post2763608
53) Transmission and Engine Mount Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-25.html#post2765814
54) Air Conditioning Recharge
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-25.html#post2776586
55) Fuel Filter Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-25.html#post2782415
56) Drum Brake Shoe Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-26.html#post2797480
57) Starter Replacement (Also see #15 on the list for a similar Starter Repair Video) Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-26.html#post2806929
58) Toyota Timing Belt Replacement (PART 1) for 3.4L V6 5VZ-FE
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-27.html#post2831265
59) Toyota Timing Belt Replacement (PART 2) for 3.4L V6 5VZ-FE
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-27.html#post2844795
60)V8 Swap (5VZ-FE 3.4L V6 to 2UZ-FE 4.7L V8)
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-27.html#post2849655
61) Sunroof Drain Cleaning
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-28.html#post2851552
62) Rear Lower Control Arm Bushing Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-28.html#post2852260
63) ARB Bumper Install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-28.html#post2873937
64) 5VZ-FE 3.4L V6 Compression Test
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-29.html#post2876106
65) Power Steering Flush and Reservoir Cleaning
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-29.html#post2881368
66) Steering Wheel Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-30.html#post2891855
67) Headliner Removal and Sunroof Leak Fix
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-30.html#post2892743
68) Toyota 5VZ-FE 3.4 Liter V6 Supercharger Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-30.html#post2904621
69) Supercharger Nose Cone Oil Plug Mod Video by [MENTION=122062]sambishop[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-31.html#post2906288
70) Automatic Transmission Filter Replacement (A340F)
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-32.html#post2920560
71) Fuel Sending Unit Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-32.html#post2924278
72) Lower Control Arm Bushing Replacement Part 2
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-32.html#post2949883
73) Automatic Transmission Temperature Gauge Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-32.html#post2953940
74) CBI Dual Swing Arm Rear Bumper Install (Part 1)
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post2960331
75) CBI Dual Swing Arm Rear Bumper Intall (Part 2)
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post2970457
76) Rear Upper Control Arm Bushing Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post2970821
77) Front Upper Control Arm Bushing Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post2971841
78) CBI Weld-on Rock Slider Install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post2992751
79) CBI Hybrid Front Bumper Install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post2992752
80) Panhard Correction Kit (PCK) Install - Brackets made by [MENTION=28464]eimkeith[/MENTION]
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-33.html#post3001350
81) CBI Skid Plate Install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-34.html#post3003530
82) Lil' Skip's Offroad Gas Tank Skid Plate Install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-34.html#post3005617
83) Stripped Differential Drain Plug Removal
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-34.html#post3008720
84) O2 Sensor Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-34.html#post3008723
85) E-Locker Swap
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-34.html#post3017345
86) Warn M8000 Winch Install on a CBI Front Hybrid Bumper
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-34.html#post3027599
87) BudBuilt Rear Differential Skid Plate Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-35.html#post3041148
88) Manual Hub Swap Part 2 - A.D.D. Hub Bearing Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-35.html#post3048117
89) Lotus RCAMS (Rear Control Arm Mount Skid) Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-35.html#post3096549
90) Engine Misfire Diagnosis & Fuel Injector Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-35.html#post3124082
91) Inner and Outer Tie Rod Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-35.html#post3140173
92) E-Locker Bench Test
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-36.html#post3141426
93) Durobump Bump Stop Installation
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-37.html#post3162308
94) Upper Balljoint Replacement Video
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-37.html#post3169433
95) Phone Mounting Options
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-37.html#post3180028
96) ECGS Clamshell CV Axle Bushing install
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-38.html#post3190504
97) Steering Play Fix
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-38.html#post3190506
98) U-Joint Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-38.html#post3192345
99) ECU Replacement
http://www.toyota-4runner.org/3rd-g...toyota-4runner-diy-videos-38.html#post3193944
100) Hood Lift Strut Mod
https://www.toyota-4runner.org/3rd-...toyota-4runner-diy-videos-38.html#post3194957
101) Center Console Mod - Cup Holder Mod for 96-98 Toyota 4Runner's
https://www.toyota-4runner.org/3210521-post570.html
102) 4Lo and Your Automatic Transmission
https://www.toyota-4runner.org/3218324-post572.html
103) Toyota Rear Axle Seal/Bearing Replacement (Part 2) by jearred.foruria
url]https://www.toyota-4runner.org/3230931-post577.html[/url]
104) Reat Hatch Strut Replacement
https://www.toyota-4runner.org/3237696-post587.html
105) Savage Off-Road Front Hybrid Winch Bumper Install
https://www.toyota-4runner.org/3237697-post588.html
106) Savage Off-Road Hybrid Rear Bumper Install Part 1
https://www.toyota-4runner.org/3247310-post590.html
107) Savage Off-Road Hybrid Rear Bumper Install Part 2
https://www.toyota-4runner.org/3247315-post591.html
108) Toyota 3RZ-FE Valve Adjustment
https://www.toyota-4runner.org/3247320-post592.html
109) Engine Cylinder Leak Down Test
https://www.toyota-4runner.org/3256936-post593.html
110) Transfer Case Output Shaft Seal Replacement
https://www.toyota-4runner.org/3264335-post603.html
111) Engine Ignition Timing Check / Timing Belt Inspection
https://www.toyota-4runner.org/3288673-post631.html
112) Coastal Offroad High Clearance Front Bumper Build Video by [MENTION=407898]jearred.foruria[/MENTION]
https://www.toyota-4runner.org/3330217-post677.html
113) OME 891 Rear Coil Install Video by [MENTION=407898]jearred.foruria[/MENTION]
https://www.toyota-4runner.org/3330220-post678.html
114) How to paint your 3rd Gen Wheels Video by [MENTION=407898]jearred.foruria[/MENTION]
https://www.toyota-4runner.org/3330223-post679.html
115) East Coast Gear Supply Front Diff install Video [email protected] For another video for this job, check out #52
https://www.toyota-4runner.org/3347174-post692.html
116) Clutch Replacement
https://www.toyota-4runner.org/3375555-post725.html
117) Disk Brake Service
https://www.toyota-4runner.org/3378030-post733.html
118) Pinion Seal Replacement
https://www.toyota-4runner.org/3390837-post748.html
119)Toyota 5VZ-FE 3.4L V6 TRD Supercharger Nose Cone Rebuild
https://www.toyota-4runner.org/3417804-post779.html
120) IAC Valve Testing and Cleaning
https://www.toyota-4runner.org/3421982-post789.html
121) Defogger Fix Video by [MENTION=137795]Hebrews 6:20[/MENTION]
https://www.toyota-4runner.org/3436411-post805.html
122) Radiator Support Replacement (Front End Collision Repair) Video by [MENTION=321447]Theallsmith[/MENTION]
https://www.toyota-4runner.org/3438839-post811.html
123) Auto Climate Control Repair
https://www.toyota-4runner.org/3462653-post815.html
124) Alternator Rebuild Video by [MENTION=116195]weekendclimber[/MENTION]
https://www.toyota-4runner.org/3481484-post839.html
125) Auto Trans Shifter Bushing Replacement & Transfer Case Shifter Seat Replacement
https://www.toyota-4runner.org/3483573-post843.html
126) Key Lock Cylinder Replacement
https://www.toyota-4runner.org/3484756-post847.html
127) Hilux 167 Snorkel Install
https://www.toyota-4runner.org/3490640-post850.html
128) Rear Hatch Wiring Repair
https://www.toyota-4runner.org/3507847-post872.html
129) Outbound Nevada Molle Panel Installation
https://www.toyota-4runner.org/3527920-post879.html
130) Door Lock Actuator Repair
https://www.toyota-4runner.org/3530920-post880.html
131) Clutch Pedal Rebuild / Replacement
https://www.toyota-4runner.org/3537421-post885.html
132) Toyota 3.4 Liter 5VZ-FE Engine Replacement
https://www.toyota-4runner.org/3565233-post909.html
133) ARB Bumper Winch Install
https://www.toyota-4runner.org/3580898-post917.html
134) Front Wheel Bearing Replacement
https://www.toyota-4runner.org/3588997-post921.html
135) Door Stopper Repair
https://www.toyota-4runner.org/3594835-post933.html
136) Trac Off Switch Install
https://www.toyota-4runner.org/3598148-post940.html
137) Borla Muffler Install
https://www.toyota-4runner.org/3603821-post949.html
138) Rear Door Window Glass Replacement
https://www.toyota-4runner.org/3617259-post963.html
139) Total Chaos Weld-on Spindle Gusset Install
https://www.toyota-4runner.org/3617805-post966.html
140) Opt Off Road Rear Control Arm Install
https://www.toyota-4runner.org/3620823-post967.html
141) Yota1 Performance ARB Air Compressor Bracket Install
https://www.toyota-4runner.org/3634013-post983.html
142) Freel Good Performance Outboard Shock Relocation Kit
https://www.toyota-4runner.org/3649133-post1001.html
143) JBA Offroad Upper Control Arm Installation
https://www.toyota-4runner.org/3653942-post1002.html
144) CS144 + Big 3 Wiring Upgrade
https://www.toyota-4runner.org/3660683-post1005.html
145) Marlin Crawler Dual Transfer Case Assembly (TACOBOX)
https://www.toyota-4runner.org/3662793-post1006.html
146) AC Condenser and Receiver Dryer Replacement with AC System Recharge Video by [MENTION=116195]weekendclimber[/MENTION]
https://www.toyota-4runner.org/3666520-post1007.html
For another video on the subject of AC Recharging here's this one: https://www.toyota-4runner.org/2776586-post372.html
147) Valve Clearance Inspection and Adjustment (3.4L 5V-FE)
https://www.toyota-4runner.org/3682439-post1022.html
148) Marlin Crawler Dual Transfer Case Install (Part 2 - Installation) Check out List #145 for Part 1.
https://www.toyota-4runner.org/3693929-post1030.html
149) How to Check Lower Balljoint Play with a Dial Indicator
https://www.toyota-4runner.org/3704829-post1032.html
150) Transmission Cooler Install (Bypassed and Used Metal Brackets for Mounting)
https://www.toyota-4runner.org/3708966-post1035.html
151) Moroso Air/Oil Separator Installation (Catch Can)
https://www.toyota-4runner.org/3720494-post1055.html
152) Transgo 340HD2 Reprogramming Kit Install - A343F A340E ('85-'08)
https://www.toyota-4runner.org/3725406-post1064.html
153) Knock Sensor and Knock Sensor Wiring Harness Replacement
https://www.toyota-4runner.org/3732937-post1068.html
154) Arcworxs Rear Shock Outboard Relocation Kit
https://www.toyota-4runner.org/3734860-post1069.html
155) ECGS Toyota 8" Rear Differential Regear / Rebuild
https://www.toyota-4runner.org/3756045-post1077.html
156) ECGS Toyota 7.5" Front Differential Regear w/ Eaton E-Locker Install
https://www.toyota-4runner.org/3757969-post1080.html
157) Front Differential Replacement (Part 2)
https://www.toyota-4runner.org/3760958-post1088.html
158) Eaton E-Locker Wiring How-to
https://www.toyota-4runner.org/3760961-post1089.html
159) How to Install an Auxbeam 6 or 8 Gang Switch Panel
https://www.toyota-4runner.org/3770308-post1090.html
160) Cargo Hatch Lock Actuator Repair
https://www.toyota-4runner.org/3771439-post1098.html
161) How to Install Auxbeam Lights (Mounting and Wiring)
https://www.toyota-4runner.org/3773741-post1101.html
162) Eimkeith Rear Bumper Build w/ Hot Metal Fab
https://www.toyota-4runner.org/3781949-post1110.html
163) Pilot Bearing Removal
https://www.toyota-4runner.org/3790231-post1112.html
164) Head Gasket Failure Diagnosis
https://www.toyota-4runner.org/3791174-post1113.html
Continued in Post #2
Table of Contents Continued
I exceeded the allowable character limit in Post #1, so I'm continuing the video table of contents here.
165) Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE) - Part 1
https://www.toyota-4runner.org/3800433-post1114.html
166) Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE) - Part 2
https://www.toyota-4runner.org/3800711-post1115.html
167) Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 3
https://www.toyota-4runner.org/3801437-post1116.html
168) Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 4
https://www.toyota-4runner.org/3802122-post1117.html
169 Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 5
https://www.toyota-4runner.org/3803209-post1118.html
170) Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 6
https://www.toyota-4runner.org/3803890-post1121.html
171) Engine Head Gasket / Cracked Head Repair (Toyota 3.4L V6 5VZ-FE ) - Part 7
https://www.toyota-4runner.org/3804694-post1125.html
172) TEQ Customs Retrofit Headlight Install
https://www.toyota-4runner.org/3810338-post1128.html
173) Koyorad Aluminum Radiator Upgrade
https://www.toyota-4runner.org/3810678-post1129.html
174) R150F Manual Transmission Rebuild (Part 1 & 2)
https://www.toyota-4runner.org/3813341-post1138.html
175) 3RZ-FE Water Pump & Thermostat Replacement
https://www.toyota-4runner.org/3819134-post1145.html
176) RCI Skid Plate Install
https://www.toyota-4runner.org/3823140-post1150.html
177) Windshield Replacement
https://www.toyota-4runner.org/3823141-post1151.html
178) Solo Motorsports LCA Install
https://www.toyota-4runner.org/3831750-post1157.html
179) Brake Booster Replacement
https://www.toyota-4runner.org/3831751-post1158.html
180) 333 Fabrications HD Billet Steering Rack Clamp Install
https://www.toyota-4runner.org/3831752-post1159.html
181) Rear Hatch Glass Replacement
https://www.toyota-4runner.org/3831753-post1160.html
182) Rear Dome Light Repair
https://www.toyota-4runner.org/3831817-post1165.html
183) Iconic Fab Transmission Cooler Mount
https://www.toyota-4runner.org/3834071-post1166.html
184) UCA Uniball Replacement
https://www.toyota-4runner.org/3834802-post1167.html
185) Body Mount Replacement
https://www.toyota-4runner.org/3840973-post1168.html
186) Solo Motorsports Rear Outboard Shock Relocation Kit Install
https://www.toyota-4runner.org/3840974-post1169.html
187) Fiberglass Fender Install
https://www.toyota-4runner.org/3842274-post1172.html
188) Eimkeith Rear Control Arm Reinforcement Bracket Install
https://www.toyota-4runner.org/3845193-post1174.html
189) Complete Coolant Hose Replacement (3.4L V6 5VZ-FE)
https://www.toyota-4runner.org/3846421-post1178.html
190) Oil Cooler Gasket & Hose Replacement (Toyota 3.4L 5VZ-FE V6)
https://www.toyota-4runner.org/3846946-post1179.html
191) Brake Master Cylinder Replacement (1996-2000)
https://www.toyota-4runner.org/3849031-post1181.html
192) LSPV (Load Sensing Proportioning Valve) Replacement)
https://www.toyota-4runner.org/3849032-post1182.html
193) Total Chaos Uniball Lower Ball Joint Install
https://www.toyota-4runner.org/3849276-post1184.html
194) Door Sensor Replacement
https://www.toyota-4runner.org/3893712-post1188.html
195) Eimkeith Front Lower Control Arm Reinforcement
https://www.toyota-4runner.org/3893713-post1189.html
196) TEQ Offroad Center Console Molle Panel
https://www.toyota-4runner.org/3893714-post1190.html
197) Oil Pump Replacement
https://www.toyota-4runner.org/3893715-post1191.html
198) 7th Injector Install
https://www.toyota-4runner.org/3893716-post1192.html
199) R150F Dyna 5th Gear Mod
https://www.toyota-4runner.org/3896731-post1197.html
200) Modified Fan Clutch by Redline Land Cruisers
https://www.toyota-4runner.org/3896732-post1198.html
201) W59 Transmission Rebuild (Part 1)
https://www.toyota-4runner.org/3904205-post1202.html
202) Solid Axle Swap (Parts 1-6)
See Post #1205 (Page 61)
203) Solid Axle Swap (Part 7)
See Post #1207 (Page 61)
204) Power Antenna Replacement
See Post #1208 (Page 61)
205) Here's a simple technique to get your front differential drain plug broken free without a fight.
See Post #1209 (Page 61)
206) Power Steering Pump Rebuild
See Post #1212 (Page 61)
Hey Tim, I love your idea. The key to "finding" the videos is in the title and the body of the text. A good test is to google some videos you have done and see what comes up.
It's important to put yourself in the end users shoes and second guess what they might put in the google search field. Most don't even bother to use the advanced features. Or worse yet, they start a new thread.
I think the other part of that is referencing the FSM or (cough...Haynes) for validity. I look forward to seeing how this progresses.:thumb3:
EDIT: In a blink of an eye and you had already posted the videos! Once you read this I'll delete it so I don't clutter this thread.
I find the whole search engine thing problematic. For instance, when I do a Google search for the valve cover gasket video Sean and I did, I don't find it anywhere. When I search for it via YouTube, it comes up on the first page. And, our titles are usually pretty descriptive and we put every keyword imaginable to help people find it. I'm pretty sure our videos via a Google search aren't coming up because they haven't had that many views yet or something like that.
I started this thread so if somebody stumbled across it, they might find something inside that was useful to them.
"Steering Rack and Front Sway Bar Bushing Replacement Video Tutorial"
Thanks for the video. You are risking your life under the truck which is just on 2 jack stands.
We did have a tire underneath the truck too in that video as a backup, but you do bring up a valid point. The likelihood of a 6 ton jack failing is probably slimmer than slim, but having a backup is a good idea. Usually where people get into trouble is relying solely on a hydraulic jack, mainly the small one that comes with the truck or car for emergency vehicle repairs. Maybe keeping the hydraulic jack in place on a cross member or a second pair of stands would be good, but I probably have a much better chance being struck by lightning than experiencing a failure of a 6 ton jack stand.
Philthyphilthy
